[postgis-tickets] [PostGIS] #4681: Have ST_GetFaceGeometry print a WARNING if face edges are found but no polygon can be built
PostGIS trac at osgeo.org
Mon May 4 08:25:32 PDT 2020
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:
 Component:  topology     |    Version:  master
Resolution:               |   Keywords:
Comment (by strk):
 Being ST_GetFaceGeometry now implemented in liblwgeom, we don't have the
 infrastructire required to raise a WARNING. Instead we can only print a
 NOTICE or raise an EXCEPTION.
 According to #3221 we had in the past avoided EXCEPTION so not to prevent
 ValidateTopology to continue inspecting the topology. It's debatable
 whether it should be ValidateTopology catching exceptions (probably saner)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4681#comment:1>
