[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-101-g943cda0
Mon May 4 09:02:26 PDT 2020
the project "PostGIS".
       via  943cda089b3dd74b68c805cb935cb00f4a044e43 (commit)
      from  39adc44a3f4ecdd4200e5bccf6dec429eeb39cf9 (commit)
revisions in full, below.
commit 943cda089b3dd74b68c805cb935cb00f4a044e43
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 4 17:59:50 2020 +0200
    ST_GetFaceGeometry: always print corruption information
    Use NOTICE when an exception will prevent ValidateTopology
    from completing (see #3221).
    Also return EMPTY instead of NULL on corruption due to
    partial boundaries (consistently with face without
    boundaries reported in #3221)
    Includes testcase and NEWS item.
    Closes #4681
diff --git a/NEWS b/NEWS
index e893b8e..5f62cb1 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,7 @@ Only tickets not included in 3.1.0alpha1
   - #4656, Cast a geojson_text::geometry for implicit GeoJSON ingestion (Raúl Marín)
 * Enhancements *
+  - #4681, ST_GetFaceGeometry: print corruption information (Sandro Santilli)
   - #4651: ST_Simplify: Don't copy if nothing is removed (Raúl Marín)
   - #4657: Avoid De-TOASTing where possible (Paul Ramsey)
   - #4490, Tweak function costs (Raúl Marín)
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 6106e81..9df1751 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -2784,7 +2784,7 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
 	LWT_ISO_FACE *face;
 	LWPOLY *out;
 	LWGEOM *outg;
-	uint64_t i;
+	uint64_t i, edgeid;
 	int fields;
 	if (faceid == 0)
@@ -2796,6 +2796,7 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
   /* Construct the face geometry */
   numfaceedges = 1;
   fields = LWT_COL_EDGE_GEOM |
+           LWT_COL_EDGE_EDGE_ID |
            LWT_COL_EDGE_FACE_LEFT |
            LWT_COL_EDGE_FACE_RIGHT
@@ -2827,13 +2828,31 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
     /* Face has no boundary edges, we'll return EMPTY, see
      * https://trac.osgeo.org/postgis/ticket/3221 */
+    lwnotice("Corrupted topology: face %"
+        LWTFMT_ELEMID " has no associated edges.", faceid);
     out = lwpoly_construct_empty(topo->srid, topo->hasZ, 0);
     return lwpoly_as_lwgeom(out);
+  edgeid = edges[0].edge_id;
   outg = _lwt_FaceByEdges( topo, edges, numfaceedges );
   _lwt_release_edges(edges, numfaceedges);
+  if ( ! outg )
+    /* Face did have edges but no polygon could be constructed
+     * with that material, sounds like a corrupted topology..
+     * We'll return EMPTY, see
+     * https://trac.osgeo.org/postgis/ticket/3221 */
+        LWTFMT_ELEMID " could not be constructed only from edges "
+        "knowing about it (like edge %" LWTFMT_ELEMID ").",
+        faceid, edgeid);
+      out = lwpoly_construct_empty(topo->srid, topo->hasZ, 0);
+      return lwpoly_as_lwgeom(out);
   return outg;
diff --git a/topology/test/regress/st_getfacegeometry.sql b/topology/test/regress/st_getfacegeometry.sql
index 2bb2c13..14f5a71 100644
--- a/topology/test/regress/st_getfacegeometry.sql
+++ b/topology/test/regress/st_getfacegeometry.sql
@@ -44,4 +44,20 @@ SELECT topology.st_getfacegeometry('', 1);
 -- Non-existent face
 SELECT topology.st_getfacegeometry('tt', 666);
+-- Face with partial rings
+-- See https://trac.osgeo.org/postgis/ticket/4681
+COPY tt.face(face_id, mbr) FROM STDIN;
+4	POLYGON((0 0,2 2,2 2,0 0))
+COPY tt.edge_data(
+	edge_id, start_node, end_node,
+	abs_next_left_edge, abs_next_right_edge,
+	next_left_edge, next_right_edge,
+        left_face, right_face, geom) FROM STDIN;
+4	2	1	1	2	1	-2	4	4	LINESTRING(0 0, 2 2)
+SET client_min_messages TO NOTICE;
+SELECT ST_AsText(topology.st_getfacegeometry('tt', 4));
+SET client_min_messages TO WARNING;
 SELECT topology.DropTopology('tt');
diff --git a/topology/test/regress/st_getfacegeometry_expected b/topology/test/regress/st_getfacegeometry_expected
index 7516763..db4cd09 100644
--- a/topology/test/regress/st_getfacegeometry_expected
+++ b/topology/test/regress/st_getfacegeometry_expected
@@ -7,4 +7,6 @@ ERROR:  SQL/MM Spatial exception - null argument
 ERROR:  SQL/MM Spatial exception - invalid topology name
 ERROR:  SQL/MM Spatial exception - non-existent face.
+NOTICE:  Corrupted topology: face 4 could not be constructed only from edges knowing about it (like edge 4).
+POLYGON EMPTY
 Topology 'tt' dropped
Summary of changes:
 NEWS                                              |  1 +
 liblwgeom/lwgeom_topo.c                           | 21 ++++++++++++++++++++-
 topology/test/regress/st_getfacegeometry.sql      | 16 ++++++++++++++++
 topology/test/regress/st_getfacegeometry_expected |  2 ++
 4 files changed, 39 insertions(+), 1 deletion(-)
hooks/post-receive
