[postgis-tickets] [PostGIS] #4674: lwgeom_cache doesn't live through not inline functions
PostGIS trac at osgeo.org
Mon May 4 09:25:18 PDT 2020
  Reporter:  Raúl Marín  |      Owner:  pramsey
      Type:  defect      |     Status:  reopened
  Priority:  medium      |  Milestone:  PostGIS 3.1.0
 Component:  postgis     |    Version:  master
Resolution:              |   Keywords:
Comment (by Raúl Marín):
 Pushed the revert.
 The change to ST_AsGML to avoid the issue with the inline blocking the
 cache usage is still pending, so I'm keeping the issue open.
 I'm thinking about changing the signature to also use `LWGEOM_asGML` and
 in there detect if the first parameter is an int or a geometry and act
 accordingly. I remember seeing something similar on some other function
 (iterating over the parameters) but I have to find where.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4674#comment:9>
