[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-103-g9967380
Mon May 4 10:56:38 PDT 2020
the project "PostGIS".
       via  99673801108be0fa2a68e7f40fa08954c724bb42 (commit)
      from  10c405f3faa48485354be22dc648daafb5a0b3f4 (commit)
revisions in full, below.
commit 99673801108be0fa2a68e7f40fa08954c724bb42
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 4 19:40:20 2020 +0200
    Make run_test.pl fail if -pre.pl scripts fail
    ... fix those which may fail for no reason ...
diff --git a/raster/test/regress/loader/TiledAutoSkipNoData-pre.pl b/raster/test/regress/loader/TiledAutoSkipNoData-pre.pl
index 78c6cfa..7f040fe 100755
--- a/raster/test/regress/loader/TiledAutoSkipNoData-pre.pl
+++ b/raster/test/regress/loader/TiledAutoSkipNoData-pre.pl
@@ -1 +1,2 @@
-link "loader/testraster2.tif", "loader/TiledAutoSkipNoData.tif";
+link "loader/testraster2.tif", "loader/TiledAutoSkipNoData.tif"
+unless -f "loader/TiledAutoSkipNoData.tif";
diff --git a/regress/run_test.pl b/regress/run_test.pl
index dd7cdb0..17a4e18 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -478,7 +478,12 @@ foreach $TEST (@ARGV)
 	$TEST_OBJ_COUNT_PRE = count_postgis_objects();
 	# Check for a "-pre.pl" file in case there are setup commands
-    eval_file("${TEST}-pre.pl");
+	unless ( eval_file("${TEST}-pre.pl") )
+		chop($@);
+		fail("Failed evaluating ${TEST}-pre.pl: $@");
+		next;
 	# Check for a "-pre.sql" file in case there is setup SQL needed before
 	# the test can be run.
@@ -529,7 +534,7 @@ foreach $TEST (@ARGV)
 	# Check for a "-post.pl" file in case there are teardown commands
-    eval_file("${TEST}-post.pl");
+	eval_file("${TEST}-post.pl");
 	$TEST_OBJ_COUNT_POST = count_postgis_objects();
@@ -743,12 +748,10 @@ sub eval_file
     my $pl;
     if ( -r $file )
-        #open(PL, $file);
-        #$pl = <PL>;
-        #close(PL);
-        #eval($pl);
-				do $file;
+				do $file or return 0;
+				#system($^X, $file) == 0 or return 0;
+		1;
Summary of changes:
 raster/test/regress/loader/TiledAutoSkipNoData-pre.pl |  3 ++-
 regress/run_test.pl                                   | 17 ++++++++++-------
 2 files changed, 12 insertions(+), 8 deletions(-)
hooks/post-receive
