[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-105-g575ae85
Fri May 8 06:27:07 PDT 2020
the project "PostGIS".
       via  575ae8580b36b093c90fb6fdde7c00c16cf2e755 (commit)
      from  b5bd6836d4617ebc924e804c42b60de637a94f60 (commit)
revisions in full, below.
commit 575ae8580b36b093c90fb6fdde7c00c16cf2e755
Author: Raúl Marín <git at rmr.ninja>
Date:   Mon May 4 18:38:58 2020 +0200
    Change ST_AsGML(geometry) to use a C function direcly
    By using a inline SQL, the cache that lives in the upper context was
    deleted for each processed row (thus being ineffective)
    Closes #4674
diff --git a/postgis/geography_inout.c b/postgis/geography_inout.c
index 2e899ac..08f82ec 100644
--- a/postgis/geography_inout.c
+++ b/postgis/geography_inout.c
@@ -36,7 +36,7 @@
 #include "utils/array.h"
 #include "utils/builtins.h"  /* for pg_atoi */
 #include "lib/stringinfo.h"  /* For binary input */
-#include "catalog/pg_type.h" /* for CSTRINGOID */
+#include "catalog/pg_type.h" /* for CSTRINGOID, INT4OID */
 #include "liblwgeom.h"         /* For standard geometry types. */
 #include "lwgeom_cache.h"
diff --git a/postgis/lwgeom_export.c b/postgis/lwgeom_export.c
index 572be45..650f556 100644
--- a/postgis/lwgeom_export.c
+++ b/postgis/lwgeom_export.c
@@ -31,6 +31,7 @@
 #include "float.h" /* for DBL_DIG */
 #include "postgres.h"
+#include "catalog/pg_type.h" /* for INT4OID */
 #include "executor/spi.h"
 #include "utils/jsonb.h"
@@ -71,37 +72,55 @@ Datum LWGEOM_asGML(PG_FUNCTION_ARGS)
 	char *gml_id_buf, *prefix_buf;
 	text *prefix_text, *gml_id_text;
-	/* Get the version */
-	version = PG_GETARG_INT32(0);
-	if ( version != 2 && version != 3 )
+	 * Two potential callers, one starts with GML version,
+	 * one starts with geometry, and we check for initial
+	 * argument type and then dynamically change what args
+	 * we read based on presence/absence
+	Oid first_type = get_fn_expr_argtype(fcinfo->flinfo, 0);
+	int argnum = 0;
+	if (first_type != INT4OID)
-		elog(ERROR, "Only GML 2 and GML 3 are supported");
-		PG_RETURN_NULL();
+		version = 2;
+	else
+		/* Get the version */
+		version = PG_GETARG_INT32(argnum++);
+		if (version != 2 && version != 3)
+			elog(ERROR, "Only GML 2 and GML 3 are supported");
+			PG_RETURN_NULL();
 	/* Get the geometry */
-	if ( PG_ARGISNULL(1) ) PG_RETURN_NULL();
-	geom = PG_GETARG_GSERIALIZED_P(1);
+	if (PG_ARGISNULL(argnum))
+		PG_RETURN_NULL();
+	geom = PG_GETARG_GSERIALIZED_P(argnum++);
 	/* Retrieve precision if any (default is max) */
-	if (PG_NARGS() > 2 && !PG_ARGISNULL(2))
+	if (PG_NARGS() > argnum && !PG_ARGISNULL(argnum))
-		precision = PG_GETARG_INT32(2);
+		precision = PG_GETARG_INT32(argnum);
 		/* TODO: leave this to liblwgeom ? */
 		if (precision > DBL_DIG)
 			precision = DBL_DIG;
 		else if (precision < 0)
 			precision = 0;
+	argnum++;
 	/* retrieve option */
-	if (PG_NARGS() > 3 && !PG_ARGISNULL(3)) option = PG_GETARG_INT32(3);
+		option = PG_GETARG_INT32(argnum);
+	argnum++;
 	/* retrieve prefix */
-	if (PG_NARGS() >4 && !PG_ARGISNULL(4))
-		prefix_text = PG_GETARG_TEXT_P(4);
+		prefix_text = PG_GETARG_TEXT_P(argnum);
 		if ( VARSIZE(prefix_text) == VARHDRSZ )
 			prefix = "";
@@ -117,10 +136,11 @@ Datum LWGEOM_asGML(PG_FUNCTION_ARGS)
 			prefix = prefix_buf;
+	argnum++;
-	if (PG_NARGS() >5 && !PG_ARGISNULL(5))
-		gml_id_text = PG_GETARG_TEXT_P(5);
+		gml_id_text = PG_GETARG_TEXT_P(argnum);
 		if ( VARSIZE(gml_id_text) == VARHDRSZ )
 			gml_id = "";
@@ -134,6 +154,7 @@ Datum LWGEOM_asGML(PG_FUNCTION_ARGS)
 			gml_id = gml_id_buf;
+	argnum++;
 	srid = gserialized_get_srid(geom);
 	if (srid == SRID_UNKNOWN)      srs = NULL;
@@ -147,7 +168,7 @@ Datum LWGEOM_asGML(PG_FUNCTION_ARGS)
 	if (option & 8)
 		elog(ERROR,
-		     "Options %d passed to ST_AsGML(geography) sets "
+		     "Options %d passed to ST_AsGML(geometry) sets "
 		     "unsupported value 8",
 		     option);
 		PG_RETURN_NULL();
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 523ed6c..3d72810 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4659,8 +4659,8 @@ CREATE OR REPLACE FUNCTION _ST_AsGML(int4, geometry, int4, int4, text, text)
 -- Changed: 2.0.0 to have default args
 CREATE OR REPLACE FUNCTION ST_AsGML(geom geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0)
 	RETURNS TEXT
-	AS $$ SELECT @extschema at ._ST_AsGML(2, $1, $2, $3, null, null); $$
-	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
+	AS 'MODULE_PATHNAME','LWGEOM_asGML'
+	LANGUAGE 'c' IMMUTABLE PARALLEL SAFE
 	_COST_MEDIUM;
 -- ST_AsGML(version, geom, precision, option)
@@ -4672,8 +4672,8 @@ CREATE OR REPLACE FUNCTION ST_AsGML(geom geometry, maxdecimaldigits int4 DEFAULT
 -- Availability: 2.1.0
 CREATE OR REPLACE FUNCTION ST_AsGML(version int4, geom geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0, nprefix text DEFAULT null, id text DEFAULT null)
 	RETURNS TEXT
-	AS $$ SELECT @extschema at ._ST_AsGML($1, $2, $3, $4, $5, $6); $$
-	LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE
 	_COST_MEDIUM;
Summary of changes:
 postgis/geography_inout.c |  2 +-
 postgis/lwgeom_export.c   | 53 +++++++++++++++++++++++++++++++++--------------
 postgis/postgis.sql.in    |  8 +++----
 3 files changed, 42 insertions(+), 21 deletions(-)
hooks/post-receive
