[postgis-tickets] [PostGIS] #4683: ST_SafeSubdivide
PostGIS trac at osgeo.org
Fri May 8 06:43:03 PDT 2020
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  assigned
  Priority:  medium       |  Milestone:  PostGIS 3.1.0
 Component:  postgis      |    Version:  master
Resolution:               |   Keywords:
Comment (by strk):
 Because the idea in this ticket is to use existing vertices, which would
 be a behavioural change from what ST_Subdivide does (it ensures to split
 areas exactly on the given grid).
 If we can get a fully robust ST_Subdivide then I'd be in favour of
 dropping this ticket and do that instead.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4683#comment:2>
