[postgis-tickets] [PostGIS] #4684: Topology construction routine results invalid topology
PostGIS trac at osgeo.org
Fri May 8 21:42:14 PDT 2020
  Reporter:  laopsahl  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:
 Component:  postgis   |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by laopsahl):
 So far I have only tested in a multi thread environment .
 If I read you correct I have to be able produce an invalid Topology by
 running in a single thread ?
 Can I run in partly in multiple threads by doing it this way ?
 1) Break the input up into many grid cell
 2) Insert lines lines that are inside each cell and with min a distance
 like tolerance to cell border
 3) Insert the rest of the lines in a single thread
 Lars
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4684#comment:2>
