[postgis-tickets] [PostGIS] #4686: Faster bbox access for PG12+
PostGIS trac at osgeo.org
Tue May 12 09:21:40 PDT 2020
  Reporter:  Algunenano   |      Owner:  Algunenano
      Type:  enhancement  |     Status:  assigned
  Priority:  medium       |  Milestone:  PostGIS 3.1.0
 Component:  postgis      |    Version:  master
Resolution:               |   Keywords:
Comment (by Algunenano):
 A function that could benefit from something like this would be
 ST_ClipByBox2D which has 2 different shortcuts (geom bbox inside box, geom
 bbox fully outsize the bbox).
 One of the common use cases for ST_ClipByBox2D is to clip the webmercator
 world before transforming geometries into 3857, and you expect most of the
 source geoemtries to fall inside the box.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4686#comment:1>
