[postgis-tickets] [PostGIS] #4684: concurrent topology construction routine may result in invalid topology
PostGIS trac at osgeo.org
Fri May 15 02:56:47 PDT 2020
  Reporter:  laopsahl  |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:
 Component:  topology  |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by strk):
 >  So if I have a set of lines to add, how do I  find the edge row and
 >  maybe
 >  face rows to lock ?
 Not easy to tell.
 When adding ONE linestring, records that will possibly be updated are:
   [topo.edge_data]
   - edges that will intersect the line (easy to get)
   - edges of any face that will be affected by the insertion (hard to
     find)
   [topo.face]
   - faces that will be split by the insertion (hard to find)
   [topo.node]
   - isolated nodes that are within tolerance distance from the line
 A pessimistic approach might lock:
   - EVERY FACE whos MBR intersects the input line
   - EVERY EDGE having any of those faces on its right or left side
   - EVERY ISOLATED NODE within tolerance distance from the input line
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4684#comment:7>
