[postgis-tickets] [PostGIS] #4691: Segfault when creating an index on geography(Point, 4326) column that contains empty points
PostGIS trac at osgeo.org
Wed May 20 03:28:32 PDT 2020
  Reporter:  aktiur   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  low      |  Milestone:
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by aktiur):
 Here is the shell output when running the script
 {{{#!sh
 root at agir-test:~/postgresql# sudo -u postgres psql crash_test < script.sql
 could not change directory to "/root/postgresql": Permission denied
 NOTICE:  extension "postgis" already exists, skipping
 CREATE EXTENSION
 CREATE TABLE
 COPY 11000
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 connection to server was lost
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4691#comment:1>
