[postgis-tickets] [PostGIS] #4587: dronie docker images proj needs to be upgraded
PostGIS trac at osgeo.org
Sat May 23 16:21:16 PDT 2020
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.1.0
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:                         |   Keywords:
Comment (by robe):
 We are using alpine now for at least PG12.  Need to do the same for the
 others then we can close this out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4587#comment:2>
