[postgis-tickets] [PostGIS] #4662: [raster] Fully qualify postgis types in SPI_execute calls
PostGIS trac at osgeo.org
Mon May 25 14:55:00 PDT 2020
  Reporter:  Algunenano  |      Owner:  Bborie Park
      Type:  defect      |     Status:  reopened
  Priority:  medium      |  Milestone:  PostGIS 2.4.9
 Component:  raster      |    Version:  2.4.x
Resolution:              |   Keywords:
Changes (by Algunenano):
 * status:  closed => reopened
 * version:  2.3.x => 2.4.x
 * resolution:  wontfix =>
 * milestone:  PostGIS 2.3.11 => PostGIS 2.4.9
Comment:
 There are still at least 2 issues still in raster code:
 - rtpg_internal.c is using spatial_ref_sys.
 - rtpg_statistics.c is calling _st_summarystats multiple times without the
 schema.
 These 2 inner calls will fail if the Postgis functions are not available
 in the search_path, which might happen if you've moved the extension of
 always if you are calling them through FDW (where only pg_temp is in the
 search_path).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4662#comment:3>
