[postgis-tickets] [PostGIS] #4695: ERROR: GetGenericCacheCollection: Could not find upper context ST_AsGeoJSON and pg13
PostGIS trac at osgeo.org
Mon May 25 22:12:00 PDT 2020
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.1.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Old description:
> I'm running this query on PostGIS 3.1.0dev
> POSTGIS="3.1.0dev 3.1.0alpha1-122-g16121bf79" [EXTENSION] PGSQL="130"
> GEOS="3.9.0-CAPI-1.14.0" PROJ="6.2.1" LIBXML="2.9.9" LIBJSON="0.12"
> LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
> and on PostgreSQL 13beta1 (headish).
> Steps to replicate the issue:
>  CREATE TABLE test AS
>  SELECT row_number()OVER() AS id, 'test' || i::text || j::text AS name,
> ST_SetSRID(ST_Point(i,j),2227) AS geom
>  FROM generate_series(1,10) AS i, generate_series(5,10,2) AS j;
> Yields error:
> SQL state: XX000
> This same query seems to work fine on PostgreSQL 12 with PostGIS 3.1.0.
> I haven't tested with PostGIS 3.0 and 13 yet but assume it has the same
> issue.
> I'm guessing it has to do with the interaction of spatial_ref_sys, since
> this works fine:
>  CREATE TABLE test2 AS
> ST_Point(i,j) AS geom
New description:
 SELECT ST_ASGeoJSON(c)
 FROM test AS c;
 Yields error:
 SQL state: XX000
 This same query seems to work fine on PostgreSQL 12 with PostGIS 3.1.0.  I
 issue.
 this works fine:
 FROM test2 AS c;
Comment (by robe):
 Sorry about that -- I completely forgot to include the actual code :) so
 focused on creating test data.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4695#comment:4>
