[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-123-g7feaa9d
Tue May 26 05:28:16 PDT 2020
the project "PostGIS".
       via  7feaa9d82c37efb5d5454e0ac144878062487bde (commit)
      from  16121bf7939891022824152c0ca095aeebbad2ed (commit)
revisions in full, below.
commit 7feaa9d82c37efb5d5454e0ac144878062487bde
Author: Raúl Marín <git at rmr.ninja>
Date:   Tue May 26 11:36:15 2020 +0200
    Fix GetGenericCacheCollection call from composite_to_geojson
    Closes #4965
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index 4d82148..0c24319 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -54,10 +54,14 @@ static void array_dim_to_json(StringInfo result, int dim, int ndims, int *dims,
 				  bool use_line_feeds);
 static void array_to_json_internal(Datum array, StringInfo result,
-static void composite_to_geojson(Datum composite,
-					 char *geom_column_name, int32 maxdecimaldigits,
-					 StringInfo result, bool use_line_feeds,
-					 Oid geom_oid, Oid geog_oid);
+static void composite_to_geojson(FunctionCallInfo fcinfo,
+				 Datum composite,
+				 char *geom_column_name,
+				 int32 maxdecimaldigits,
+				 StringInfo result,
+				 bool use_line_feeds,
+				 Oid geom_oid,
+				 Oid geog_oid);
 static void composite_to_json(Datum composite, StringInfo result,
 static void datum_to_json(Datum val, bool is_null, StringInfo result,
@@ -98,7 +102,7 @@ ST_AsGeoJsonRow(PG_FUNCTION_ARGS)
 	result = makeStringInfo();
-	composite_to_geojson(array, geom_column, maxdecimaldigits, result, do_pretty, geom_oid, geog_oid);
+	composite_to_geojson(fcinfo, array, geom_column, maxdecimaldigits, result, do_pretty, geom_oid, geog_oid);
 	PG_RETURN_TEXT_P(cstring_to_text_with_len(result->data, result->len));
@@ -107,8 +111,14 @@ ST_AsGeoJsonRow(PG_FUNCTION_ARGS)
  * Turn a composite / record into GEOJSON.
 static void
-composite_to_geojson(Datum composite, char *geom_column_name, int32 maxdecimaldigits,
-					 StringInfo result, bool use_line_feeds, Oid geom_oid, Oid geog_oid)
+composite_to_geojson(FunctionCallInfo fcinfo,
+		     Datum composite,
+		     Oid geom_oid,
+		     Oid geog_oid)
 	HeapTupleHeader td;
 	Oid			tupType;
@@ -166,8 +176,14 @@ composite_to_geojson(Datum composite, char *geom_column_name, int32 maxdecimaldi
 			val = heap_getattr(tuple, i + 1, tupdesc, &isnull);
 			if (!isnull)
-				appendStringInfo(result, "%s",
-					TextDatumGetCString(DirectFunctionCall2(LWGEOM_asGeoJson, val, Int32GetDatum(maxdecimaldigits))));
+				appendStringInfo(
+				    result,
+				    "%s",
+				    TextDatumGetCString(CallerFInfoFunctionCall2(LWGEOM_asGeoJson,
+										 fcinfo->flinfo,
+										 InvalidOid,
+										 val,
+										 Int32GetDatum(maxdecimaldigits))));
 			else
diff --git a/regress/core/Makefile.in b/regress/core/Makefile.in
index 46bfdf5..bf2c851 100644
--- a/regress/core/Makefile.in
+++ b/regress/core/Makefile.in
@@ -166,7 +166,8 @@ TESTS = \
 	regress_brin_index_geography \
 	minimum_clearance \
 	oriented_envelope \
-	point_coordinates
+	point_coordinates \
+	out_geojson
 # Slow slow tests
 TESTS_SLOW = \
diff --git a/regress/core/out_geojson.sql b/regress/core/out_geojson.sql
index e6f5375..5c235e5 100644
--- a/regress/core/out_geojson.sql
+++ b/regress/core/out_geojson.sql
@@ -35,4 +35,9 @@ SELECT 'gj03', i, to_json(g.*) AS rj3
 SELECT 'gj04', i, to_jsonb(g.*) AS rj4
 	FROM g ORDER BY i;
+SELECT '4695', ST_ASGeoJSON(a.*) FROM
+    SELECT 1 as v, ST_SetSRID(ST_Point(0,1),2227) as g
+) a;
 DROP TABLE g;
diff --git a/regress/core/out_geojson_expected b/regress/core/out_geojson_expected
index 085261e..25a2259 100644
--- a/regress/core/out_geojson_expected
+++ b/regress/core/out_geojson_expected
@@ -27,3 +27,4 @@ gj04|4|{"d": "2004-04-04", "f": 4.4, "g": {"type": "GeometryCollection", "geomet
 gj04|5|{"d": "2005-05-05", "f": 5.5, "g": {"type": "Point", "coordinates": []}, "i": 5, "t": "five"}
 gj04|6|{"d": "2006-06-06", "f": 6.6, "g": null, "i": 6, "t": "six"}
 gj04|7|{"d": "2007-07-07", "f": 7.7, "g": {"type": "GeometryCollection", "geometries": [{"type": "Point", "coordinates": []}, {"type": "Point", "coordinates": [1, 2]}]}, "i": 7, "t": "seven"}
+4695|{"type": "Feature", "geometry": {"type":"Point","crs":{"type":"name","properties":{"name":"EPSG:2227"}},"coordinates":[0,1]}, "properties": {"v": 1}}
Summary of changes:
 postgis/lwgeom_out_geojson.c      | 34 +++++++++++++++++++++++++---------
 regress/core/Makefile.in          |  3 ++-
 regress/core/out_geojson.sql      |  5 +++++
 regress/core/out_geojson_expected |  1 +
 4 files changed, 33 insertions(+), 10 deletions(-)
hooks/post-receive
