[postgis-tickets] [PostGIS] #4779: server process (PID 49666) was terminated by signal 6: Aborted, munmap_chunk(): invalid pointer
PostGIS trac at osgeo.org
Sun Nov 1 21:06:52 PST 2020
  Reporter:  laopsahl  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.1.0
 Component:  postgis   |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by laopsahl):
 Magnus told that postgis depend different versions of proj so I tested
 this and thats correct.
 proj-datumgrid-1.8-6.3.2.4.el8.noarch
 proj71-7.1.1-1.rhel8.x86_64
 proj71-devel-7.1.1-1.rhel8.x86_64
 proj71-static-7.1.1-1.rhel8.x86_64
 maven-project-2.2.1-47.el7.noarch
 proj71-debugsource-7.1.1-1.rhel8.x86_64
 proj-6.3.2-4.el8.x86_64
 proj71-debuginfo-7.1.1-1.rhel8.x86_64
 I am not able to remove proj-6.3.2-4 without removing postgis
  yum remove proj-6*
 Dependencies resolved.
  Package                                        Architecture
 Version
 Repository                               Size
 Removing:
  proj                                           x86_64
 6.3.2-4.el8                                                       @epel
 9.5 M
 Removing dependent packages:
  gdal31                                         x86_64
 3.1.3-2.rhel8                                                     @pgdg-
 common                            830 k
  gdal31-devel                                   x86_64
 common                            1.1 M
  libgeotiff                                     x86_64
 1.5.1-1.el8                                                       @epel
 338 k
  pgrouting_12                                   x86_64
 3.1.0-2.rhel8                                                     @pgdg12
 5.4 M
  postgis31_12-client                            x86_64
 3.1.0-alpha2_2.rhel8                                              @pgdg12
 1.6 M
  postgis31_12-devel                             x86_64
 0
  postgis31_12-utils                             x86_64
 214 k
 Removing unused dependencies:
  armadillo                                      x86_64
 9.700.2-1.el8                                                     @epel
 83 k
  arpack                                         x86_64
 3.7.0-1.el8                                                       @epel
 729 k
  gdal31-libs                                    x86_64
 common                             27 M
  gpsbabel                                       x86_64
 1.6.0-3.el8                                                       @epel
 3.1 M
  libspatialite                                  x86_64
 5.0.0-beta0_1.el8                                                 @epel
 13 M
  libusb                                         x86_64
 1:0.1.5-12.el8                                                    @BaseOS
 68 k
  mariadb-connector-c                            x86_64
 3.0.7-1.el8
 @AppStream                              424 k
  ogdi                                           x86_64
 4.1.0-1.el8                                                       @epel
 865 k
  openblas                                       x86_64
 0.3.3-5.el8
 @AppStream                               27 M
  openblas-threads                               x86_64
 0.3.3-5.el8
 @AppStream                               27 M
  openblas-threads64_                            x86_64
 0.3.3-5.el8
 @PowerTools                              27 M
  perl-DBD-Pg                                    x86_64
 3.7.4-4.module_el8.1.0+268+81255909
 @AppStream                              585 k
  postgis31_12                                   x86_64
 33 M
  proj-datumgrid                                 noarch
 1.8-6.3.2.4.el8                                                   @epel
 7.5 M
  shapelib                                       x86_64
 1.5.0-1.el8                                                       @epel
 185 k
 Transaction Summary
 Remove  23 Packages
 And with proj7
  yum remove proj71*
 Version
 Repository                               Size
 Removing:
  proj71                                         x86_64
 7.1.1-1.rhel8                                                     @pgdg-
 common                             10 M
  proj71-debuginfo                               x86_64
 common                             58 M
  proj71-debugsource                             x86_64
 common                            5.3 M
  proj71-devel                                   x86_64
 common                            564 k
  proj71-static                                  x86_64
 common                            7.7 M
  gdal31                                         x86_64
 common                            830 k
  libgeotiff16                                   x86_64
 1.6.0-1.rhel8                                                     @pgdg-
 common                            340 k
  libgeotiff16-devel                             x86_64
 common                            132 k
  pgrouting_12                                   x86_64
 5.4 M
 1.6 M
 0
 214 k
  gpsbabel                                       x86_64
 1.6.0-3.el8                                                       @epel
 3.1 M
  libtiff-devel                                  x86_64
 4.0.9-17.el8
 @AppStream                              1.5 M
  libusb                                         x86_64
 68 k
  perl-DBD-Pg                                    x86_64
 @AppStream                              585 k
  postgis31_12                                   x86_64
 33 M
  shapelib                                       x86_64
 1.5.0-1.el8                                                       @epel
 185 k
 Transaction Summary
 Remove  18 Packages
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4779#comment:3>
