[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-126-g3e63713
Sun Nov 1 21:30:19 PST 2020
the project "PostGIS".
       via  3e63713997083aa2d1f08cf96a9fe3762d72d8f0 (commit)
      from  f19ada929bc8842ec01fd3968a3e914fb042a673 (commit)
revisions in full, below.
commit 3e63713997083aa2d1f08cf96a9fe3762d72d8f0
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Nov 2 00:30:14 2020 -0500
    Drop sect2 for ref entries in raster, preventing testing, also get rid of nested reffunsynopsis in ST_Union. Add more logging to xslt.  References #4780 for PostGIS 3.1
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index 1f3baa4..d4ebc82 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -9080,11 +9080,8 @@ FROM dummy_rast WHERE rid=2;
 		</refentry>
 	</sect1>
-	<sect1 id="Raster_Processing">
-		<title>Raster Processing</title>
-		<sect2 id="Raster_Processing_MapAlgebra">
-			<title>Map Algebra</title>
+	<sect1 id="Raster_Processing_MapAlgebra">
+		<title>Raster Processing: Map Algebra</title>
 			<refentry id="RT_ST_Clip">
 				<refnamediv>
@@ -12091,39 +12088,35 @@ UPDATE wind
 				<refsynopsisdiv>
 					<funcsynopsis>
-					  <funcprototype>
-							<funcdef>raster <function>ST_Union</function></funcdef>
-							<paramdef><type>setof raster </type> <parameter>rast</parameter></paramdef>
-					</funcprototype>
-					</funcsynopsis>
-					<funcsynopsis>
-					  <funcprototype>
-							<paramdef><type>unionarg[] </type> <parameter>unionargset</parameter></paramdef>
-					  </funcprototype>
-					</funcsynopsis>
-					<funcsynopsis>
-					  <funcprototype>
-							<paramdef><type>setof raster</type> <parameter>rast</parameter></paramdef>
-							<paramdef><type>integer</type> <parameter>nband</parameter></paramdef>
-					  </funcprototype>
-					</funcsynopsis>
-					<funcsynopsis>
-					  <funcprototype>
-							<paramdef><type>text</type> <parameter>uniontype</parameter></paramdef>
-					  </funcprototype>
-					</funcsynopsis>
-					<funcsynopsis>
-					  <funcprototype>
-					  </funcprototype>
+                        <funcprototype>
+                            <funcdef>raster <function>ST_Union</function></funcdef>
+                            <paramdef><type>setof raster </type> <parameter>rast</parameter></paramdef>
+                        </funcprototype>
+                        <funcprototype>
+                            <paramdef><type>unionarg[] </type> <parameter>unionargset</parameter></paramdef>
+                        </funcprototype>
+                        <funcprototype>
+                            <paramdef><type>setof raster</type> <parameter>rast</parameter></paramdef>
+                            <paramdef><type>integer</type> <parameter>nband</parameter></paramdef>
+                        </funcprototype>
+                        <funcprototype>
+                            <paramdef><type>text</type> <parameter>uniontype</parameter></paramdef>
+                        </funcprototype>
+                        <funcprototype>
+                        </funcprototype>
 					</funcsynopsis>
 				</refsynopsisdiv>
@@ -12188,9 +12181,9 @@ WHERE ST_Intersects(rast,  ST_GeomFromText('LINESTRING(230486 887771, 230500 887
 				</refsection>
 			</refentry>
-		</sect2> <!-- /map algebra -->
+		</sect1> <!-- /map algebra -->
-		<sect2 id="Raster_Processing_MapAlgebra_Callbacks">
+		<sect1 id="Raster_Processing_MapAlgebra_Callbacks">
 			<title>Built-in Map Algebra Callback Functions</title>
         <refentry id="RT_ST_Distinct4ma">
@@ -12926,10 +12919,10 @@ WHERE rid = 2;
 			</refsection>
 		</refentry>
-		</sect2> <!-- /callback -->
+		</sect1> <!-- /callback -->
-		<sect2 id="Raster_Processing_DEM">
-			<title>DEM (Elevation)</title>
+		<sect1 id="Raster_Processing_DEM">
+			<title>Raster Processing: DEM (Elevation)</title>
 			<refentry id="RT_ST_Aspect">
 				<refnamediv>
@@ -13502,10 +13495,10 @@ GROUP BY t1.rast;
 				</refsection>
 			</refentry>
-		</sect2> <!-- /DEM -->
+		</sect1> <!-- /DEM -->
-		<sect2 id="Raster_Processing_Geometry">
-			<title>Raster to Geometry</title>
+		<sect1 id="Raster_Processing_Geometry">
+			<title>Raster Processing: Raster to Geometry</title>
 			<refentry id="RT_Box3D">
 				<refnamediv>
@@ -13915,9 +13908,7 @@ MULTIPOLYGON(((3427928 5793243.85,3427928 5793243.8,3427928 5793243.75,3427927.8
 				</refsection>
 			</refentry>
-		</sect2> <!-- /misc -->
-	</sect1>
+	</sect1> <!-- /misc -->
 	<sect1 id="RT_Operators">
 	<title>Raster Operators</title>
diff --git a/doc/xsl/raster_gardentest.sql.xsl b/doc/xsl/raster_gardentest.sql.xsl
index 78c514e..2b97524 100644
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@ -114,7 +114,7 @@
 		 	(SELECT ST_SetSRID(ST_SetValue(ST_AddBand(ST_MakeEmptyRaster( 100, 100, (i-1)*100, (i-1)*100, 0.0005, -0.0005, 0*i, 0*i), '64BF'), i, (i+1),42949.12345),4326) As rast
 		 		FROM generate_series(1,10) As i)
 		 </pgis:pixeltype>
-		 <pgis:pixeltype ID="NULLRaster" PixType="64BF" createtable="true" nodata="NULL">
+		 <pgis:pixeltype ID="NULLRaster" PixType="null" createtable="true" nodata="NULL">
 		 	(SELECT NULL::raster As rast
 		 </pgis:pixeltype>
@@ -127,7 +127,7 @@ DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />;
 CREATE TABLE <xsl:value-of select="$var_logtable" />(logid serial PRIMARY KEY, log_label text, spatial_class text DEFAULT 'raster', func text, g1 text, g2 text, log_start timestamp, log_end timestamp, log_sql text);
 DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />_output;
 CREATE TABLE <xsl:value-of select="$var_logtable" />_output(logid integer PRIMARY KEY, log_output xml);
-                <xsl:apply-templates select="/book/chapter[@id='RT_reference']" />
+            <xsl:apply-templates select="/book/chapter[@id='RT_reference']" />
         </xsl:template>
 	<xsl:template match='chapter'>
 <!-- define a table we call pgis_rgarden_mega that will contain a raster column with a band for all types of pixels we support -->
@@ -244,7 +244,6 @@ COMMIT;
 				<xsl:variable name='fnargs'><xsl:call-template name="listparams"><xsl:with-param name="func" select="." /></xsl:call-template></xsl:variable>
 				<xsl:variable name='fnname'><xsl:value-of select="funcdef/function"/></xsl:variable>
 				<xsl:variable name='fndef'><xsl:value-of select="funcdef"/></xsl:variable>
-				-- <xsl:value-of select="funcdef"/>
 				<xsl:variable name='numparams'><xsl:value-of select="count(paramdef/parameter)" /></xsl:variable>
 				<xsl:variable name='numparamgeoms'><xsl:value-of select="count(paramdef/type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') ]) + count(paramdef/parameter[contains(text(),'WKT')]) + count(paramdef/parameter[contains(text(),'geomgml')])" /></xsl:variable>
 				<xsl:variable name='numparamrasts'><xsl:value-of select="count(paramdef/type[contains(text(),'raster') ] )" /></xsl:variable>
@@ -267,6 +266,7 @@ COMMIT;
 					</xsl:otherwise>
 				  </xsl:choose>
 				</xsl:variable>
+				SELECT 'Start Considering <xsl:value-of select="funcdef/function" /> <xsl:value-of select="$geoftype" />';
 				<!-- For each function prototype generate a test sql statement -->
 				<xsl:choose>
@@ -287,7 +287,8 @@ SELECT  'Ending <xsl:value-of select="funcdef/function" />(<xsl:value-of select=
 	</xsl:when>
 <!--Start Test aggregate and unary functions -->
 <!-- put functions that take only one raster no need to cross with another raster collection, these are unary raster, aggregates, and so forth -->
-	<xsl:when test="$numparamrasts = '1' and $numparamgeoms = '0'  and not(contains($fnexclude,funcdef/function))" >
+	<xsl:when test="$numparamrasts = '1' and $numparamgeoms = '0' and not(contains($fnexclude,funcdef/function))" >
+		SELECT '<xsl:value-of select="$fnname" />';
 		<xsl:for-each select="document('')//pgis:pixeltypes/pgis:pixeltype">
 		SELECT '<xsl:value-of select="$geoftype" /> <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: Start Testing <xsl:value-of select="@PixType" /> with 1 rast param';
 			<xsl:choose>
Summary of changes:
 doc/reference_raster.xml          | 89 ++++++++++++++++++---------------------
 doc/xsl/raster_gardentest.sql.xsl |  9 ++--
 2 files changed, 45 insertions(+), 53 deletions(-)
hooks/post-receive
