[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-138-g82ab399
Wed Nov 4 00:16:01 PST 2020
the project "PostGIS".
       via  82ab399eb572d23c204c44b0e44fdc1593234b08 (commit)
      from  9732cf8398a56db784889bc0f91597e6f7a8e5a9 (commit)
revisions in full, below.
commit 82ab399eb572d23c204c44b0e44fdc1593234b08
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Nov 4 09:15:16 2020 +0100
    Do not let travis run parallel check jobs (more tests)
diff --git a/ci/travis/run_nowagyu.sh b/ci/travis/run_nowagyu.sh
index 160afae..6855fb9 100644
--- a/ci/travis/run_nowagyu.sh
+++ b/ci/travis/run_nowagyu.sh
@@ -13,5 +13,6 @@ LDFLAGS="--coverage"
 # Standard build
 ./configure --without-wagyu CFLAGS="${CFLAGS}" CXXFLAGS="${CFLAGS}" LDFLAGS="${LDFLAGS}"
-bash ./ci/travis/logbt -- make -j check RUNTESTFLAGS=--verbose
+bash ./ci/travis/logbt -- make -j
+bash ./ci/travis/logbt -- make check RUNTESTFLAGS=--verbose
 (curl -S -f https://codecov.io/bash -o .github/codecov.bash && bash .github/codecov.bash) || echo "Coverage report failed"
diff --git a/ci/travis/run_usan_clang.sh b/ci/travis/run_usan_clang.sh
index 3357345..f50f158 100644
--- a/ci/travis/run_usan_clang.sh
+++ b/ci/travis/run_usan_clang.sh
@@ -17,4 +17,5 @@ LD_PRELOAD=/usr/lib/clang/9/lib/linux/libclang_rt.asan-x86_64.so \
 # Build with Clang and usan flags
 ./autogen.sh
 ./configure CC=clang CFLAGS="${CFLAGS_USAN}" LDFLAGS="${LDFLAGS_STD}"
diff --git a/ci/travis/run_usan_gcc.sh b/ci/travis/run_usan_gcc.sh
index 333cb3c..3fb7135 100644
--- a/ci/travis/run_usan_gcc.sh
+++ b/ci/travis/run_usan_gcc.sh
@@ -10,4 +10,5 @@ LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro"
 # Build with GCC and usan flags
 ./configure CC=gcc CFLAGS="${CFLAGS_STD}" LDFLAGS="${LDFLAGS_STD}"
Summary of changes:
 ci/travis/run_nowagyu.sh    | 3 ++-
 ci/travis/run_usan_clang.sh | 3 ++-
 ci/travis/run_usan_gcc.sh   | 3 ++-
 3 files changed, 6 insertions(+), 3 deletions(-)
hooks/post-receive
