[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-142-g4ec4fbc
Wed Nov 4 13:39:51 PST 2020
the project "PostGIS".
       via  4ec4fbc15c9b867f980cbc2c4d4d430f18637cb4 (commit)
      from  3600f05614d259078b16b1b27fbbe84b81a88ebe (commit)
revisions in full, below.
commit 4ec4fbc15c9b867f980cbc2c4d4d430f18637cb4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Nov 4 13:39:47 2020 -0800
    Remove sub-test that provides different result in GEOS 3.9 and 3.8 since Komzpa asserts that the change is unimportant/desireable.
diff --git a/regress/core/subdivide.sql b/regress/core/subdivide.sql
index e61aabf..bfab9da 100644
--- a/regress/core/subdivide.sql
+++ b/regress/core/subdivide.sql
@@ -52,7 +52,7 @@ create table big_polygon_sliced as (
 SELECT '4' As rn,
 	(select ST_Area(geom)::numeric(12,1) from big_polygon) as orig_area,
 	SUM(ST_Area(gs.geom))::numeric(12,1) as pieces_area,
-	COUNT(gs.geom) as num_pieces,
+--	COUNT(gs.geom) as num_pieces,
 	MAX(ST_NPoints(gs.geom)) as max_vert
 FROM big_polygon_sliced gs;
diff --git a/regress/core/subdivide_expected b/regress/core/subdivide_expected
index 10fc0e5..5e19d2f 100644
--- a/regress/core/subdivide_expected
+++ b/regress/core/subdivide_expected
@@ -4,7 +4,7 @@
 ERROR:  lwgeom_subdivide_prec: cannot subdivide to fewer than 5 vertices per output
 #3522|POINT(1 1)
 #3744|1600000000000000
-4|29321996468.6|29321996468.6|1857|256
+4|29321996468.6|29321996468.6|256
 #4211|0.00008316000
 #4217|0.00002463668
 #4301|0.00213614552
Summary of changes:
 regress/core/subdivide.sql      | 2 +-
 regress/core/subdivide_expected | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
