[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-152-g4c7c065
Fri Nov 6 06:17:13 PST 2020
the project "PostGIS".
       via  4c7c06574de31f50397e128abbadabc38b8ca71e (commit)
       via  22d9f04fcff523d6100f543f4a12ff52ef890b23 (commit)
      from  5b2e3cbd52408a9870a9886e5896123e4ff86118 (commit)
revisions in full, below.
commit 4c7c06574de31f50397e128abbadabc38b8ca71e
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Oct 30 15:00:20 2020 +0100
    Be clever and only deserialize with copy when necessary
    Closes #4775
    Closes https://github.com/postgis/postgis/pull/586
diff --git a/libpgcommon/gserialized_gist.c b/libpgcommon/gserialized_gist.c
index 41db342..093ad50 100644
--- a/libpgcommon/gserialized_gist.c
+++ b/libpgcommon/gserialized_gist.c
@@ -147,7 +147,16 @@ void gbox_from_gidx(GIDX *a, GBOX *gbox, int flags)
 int
 gserialized_datum_get_gidx_p(Datum gsdatum, GIDX *gidx)
-	GSERIALIZED *gpart = (GSERIALIZED *)PG_DETOAST_DATUM_SLICE(gsdatum, 0, gserialized_max_header_size());
+	GSERIALIZED *gpart = NULL;
+	int need_detoast = PG_GSERIALIZED_DATUM_NEEDS_DETOAST((struct varlena *)gsdatum);
+	if (need_detoast)
+		gpart = (GSERIALIZED *)PG_DETOAST_DATUM_SLICE(gsdatum, 0, gserialized_max_header_size());
+	else
+		gpart = (GSERIALIZED *)gsdatum;
 	/* Do we even have a serialized bounding box? */
 	if (gserialized_has_bbox(gpart))
@@ -179,9 +188,9 @@ gserialized_datum_get_gidx_p(Datum gsdatum, GIDX *gidx)
 		/* No, we need to calculate it from the full object. */
 		LWGEOM *lwgeom;
 		GBOX gbox;
-		/* If we haven't, read the whole gserialized object */
-		if (LWSIZE_GET(gpart->size) >= gserialized_max_header_size())
+		if (need_detoast && LWSIZE_GET(gpart->size) >= gserialized_max_header_size())
+			/* If we haven't, read the whole gserialized object */
 			POSTGIS_FREE_IF_COPY_P(gpart, gsdatum);
 			gpart = (GSERIALIZED *)PG_DETOAST_DATUM(gsdatum);
diff --git a/libpgcommon/lwgeom_pg.h b/libpgcommon/lwgeom_pg.h
index fd692f1..96a6647 100644
--- a/libpgcommon/lwgeom_pg.h
+++ b/libpgcommon/lwgeom_pg.h
@@ -89,9 +89,12 @@ void pg_install_lwgeom_handlers(void);
 /* Argument handling macros */
 #define PG_GETARG_GSERIALIZED_P(varno) ((GSERIALIZED *)PG_DETOAST_DATUM(PG_GETARG_DATUM(varno)))
 #define PG_GETARG_GSERIALIZED_P_COPY(varno) ((GSERIALIZED *)PG_DETOAST_DATUM_COPY(PG_GETARG_DATUM(varno)))
-#define PG_GETARG_GSERIALIZED_P_SLICE(varno, start, size) ((GSERIALIZED *)PG_DETOAST_DATUM_SLICE(PG_GETARG_DATUM(varno), start, size))
+#define PG_GSERIALIZED_DATUM_NEEDS_DETOAST(datum) \
+	(VARATT_IS_EXTENDED((datum)) || VARATT_IS_EXTERNAL((datum)) || VARATT_IS_COMPRESSED((datum)))
 #define PG_GETARG_GSERIALIZED_HEADER(varno) \
-	((GSERIALIZED *)PG_DETOAST_DATUM_SLICE(PG_GETARG_DATUM(varno), 0, gserialized_max_header_size()))
+	PG_GSERIALIZED_DATUM_NEEDS_DETOAST(PG_GETARG_DATUM(varno)) \
+	? ((GSERIALIZED *)PG_DETOAST_DATUM_SLICE(PG_GETARG_DATUM(varno), 0, gserialized_max_header_size())) \
+	: ((GSERIALIZED *)(PG_GETARG_DATUM(varno)))
 /* Debugging macros */
 #if POSTGIS_DEBUG_LEVEL > 0
diff --git a/postgis/gserialized_gist_2d.c b/postgis/gserialized_gist_2d.c
index 1c5a74c..198a4e9 100644
--- a/postgis/gserialized_gist_2d.c
+++ b/postgis/gserialized_gist_2d.c
@@ -458,21 +458,19 @@ static double box2df_distance(const BOX2DF *a, const BOX2DF *b)
 int
 gserialized_datum_get_internals_p(Datum gsdatum, GBOX *gbox, lwflags_t *flags, uint8_t *type, int32_t *srid)
-	GSERIALIZED *gpart;
 	int result = LW_SUCCESS;
+	if (need_detoast)
+	else
-	** Because geometry is declared as "storage = main" anything large
-	** enough to take serious advantage of PG_DETOAST_DATUM_SLICE will have
-	** already been compressed, which means the entire object will be
-	** fetched and decompressed before a slice is taken, thus removing
-	** any efficiencies gained from slicing.
-	** As of Pg12 we can partially decompress a toasted object
-	** (though we still need to fully retrieve it from TOAST)
-	** which makes slicing worthwhile.
-	gpart = (GSERIALIZED *)PG_DETOAST_DATUM_SLICE(gsdatum, 0, gserialized_max_header_size());
-	if (!gserialized_has_bbox(gpart) && LWSIZE_GET(gpart->size) >= gserialized_max_header_size())
+	if (!gserialized_has_bbox(gpart) && need_detoast && LWSIZE_GET(gpart->size) >= gserialized_max_header_size())
 		/* The headers don't contain a bbox and the object is larger than what we retrieved, so
 		 * we now detoast it completely */
@@ -513,7 +511,16 @@ int
 gserialized_datum_get_box2df_p(Datum gsdatum, BOX2DF *box2df)
+	if (need_detoast)
+	else
@@ -525,7 +532,7 @@ gserialized_datum_get_box2df_p(Datum gsdatum, BOX2DF *box2df)
 	else
 		GBOX gbox = {0};
 			 * we now detoast it completely and recheck */
commit 22d9f04fcff523d6100f543f4a12ff52ef890b23
Date:   Fri Oct 23 16:21:05 2020 +0200
    Re-specialize gserialized_datum_get_box2df_p
index 202ba25..1c5a74c 100644
@@ -474,7 +474,7 @@ gserialized_datum_get_internals_p(Datum gsdatum, GBOX *gbox, lwflags_t *flags, u
-		/* The headers don't contain a bbox and there is the object is larger than what we retrieved, so
+		/* The headers don't contain a bbox and the object is larger than what we retrieved, so
@@ -506,14 +506,41 @@ gserialized_datum_get_gbox_p(Datum gsdatum, GBOX *gbox)
 	return gserialized_datum_get_internals_p(gsdatum, gbox, &flags, &type, &srid);
+/* Note that this duplicates code from gserialized_datum_get_internals_p. It does so because
+ * accessing only the BOX2DF (as floats) is faster and this is a hot path function in indexes
 int
-	GBOX gbox = {0};
-	if (gserialized_datum_get_gbox_p(gsdatum, &gbox) == LW_FAILURE)
-		return LW_FAILURE;
+	int result = LW_SUCCESS;
+	GSERIALIZED *gpart = (GSERIALIZED *)PG_DETOAST_DATUM_SLICE(gsdatum, 0, gserialized_max_header_size());
+	if (gserialized_has_bbox(gpart))
+		size_t box_ndims;
+		const float *f = gserialized_get_float_box_p(gpart, &box_ndims);
+		memcpy(box2df, f, sizeof(BOX2DF));
+		result = LW_SUCCESS;
+	else
+		GBOX gbox = {0};
+		if (LWSIZE_GET(gpart->size) >= gserialized_max_header_size())
+			 * we now detoast it completely and recheck */
+			POSTGIS_FREE_IF_COPY_P(gpart, gsdatum);
+			gpart = (GSERIALIZED *)PG_DETOAST_DATUM(gsdatum);
+		result = gserialized_get_gbox_p(gpart, &gbox);
+		if (result == LW_SUCCESS)
+			result = box2df_from_gbox_p(&gbox, box2df);
-	return box2df_from_gbox_p(&gbox, box2df);
+	return result;
Summary of changes:
 libpgcommon/gserialized_gist.c | 15 +++++++--
 libpgcommon/lwgeom_pg.h        |  7 +++--
 postgis/gserialized_gist_2d.c  | 70 +++++++++++++++++++++++++++++++-----------
 3 files changed, 69 insertions(+), 23 deletions(-)
hooks/post-receive
