[postgis-tickets] [PostGIS] #4787: Calling ST_GEOMFROMWKB with empty byte array crashes backend
PostGIS trac at osgeo.org
Fri Nov 6 06:38:19 PST 2020
 Reporter:  topogrids  |      Owner:  pramsey
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 3.1.0
Component:  postgis    |    Version:
 Keywords:             |
 SELECT st_geomfromwkb(''::bytea) makes backend crash, all backend
 processes will be terminated, the server goes into recovery mode.
  select postgis_version(), version();
             postgis_version            |
 version
  3.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 | PostgreSQL 12.4 on x86_64-pc-
 linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-39), 64-bit
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4787>
