[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-154-g291cb5c
Fri Nov 6 16:58:28 PST 2020
the project "PostGIS".
       via  291cb5c3006c763699f99dcf7c3647bbfc14983f (commit)
      from  aa450be9fb5132225d93ca10b0d6f9b6590adf56 (commit)
revisions in full, below.
commit 291cb5c3006c763699f99dcf7c3647bbfc14983f
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Nov 6 19:58:05 2020 -0500
    Put note about minimum version of protobuf in docs and also in config note that 3.9 is required to have all features
diff --git a/configure.ac b/configure.ac
index bcbc7cd..e5c9271 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1694,9 +1694,9 @@ AC_MSG_WARN([ --------- GEOS VERSION WARNING ------------ ])
 AC_MSG_WARN([  You are building against GEOS ${GEOS_FULL_VERSION}.])
 AC_MSG_WARN([])
 AC_MSG_WARN([  To take advantage of _all_ the features of ])
-AC_MSG_WARN([  PostGIS, GEOS 3.8.0 or higher is required.])
+AC_MSG_WARN([  PostGIS, GEOS 3.9.0 or higher is required.])
 AC_MSG_WARN([])
-AC_MSG_WARN([  For _most_ features, GEOS 3.6.0 is enough.])
+AC_MSG_WARN([  For _many_ features, GEOS 3.6.0 is enough.])
 AC_MSG_WARN([])
 AC_MSG_WARN([  We recommend GEOS 3.8.0 or higher])
 AC_MSG_WARN([])
diff --git a/doc/installation.xml b/doc/installation.xml
index 95ec056..88d0a88 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -178,7 +178,7 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
 	  <listitem>
 		<para>
-		  GEOS geometry library, version 3.6 or greater, but GEOS 3.8+ is recommended to take full advantage of all the new functions and features. GEOS is available for download from
+		  GEOS geometry library, version 3.6 or greater, but GEOS 3.9+ is required to take full advantage of all the new functions and features. GEOS is available for download from
 		  <ulink url="http://trac.osgeo.org/geos/">
 		  </ulink>.
@@ -256,7 +256,7 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
 		<listitem>
 			<para>
-			  To enable ST_AsMVT protobuf-c library (for usage) and the protoc-c compiler (for building) are required.
+			  To enable ST_AsMVT protobuf-c library 1.1.0 or higher (for usage) and the protoc-c compiler (for building) are required.
 				Also, pkg-config is required to verify the correct minimum version of protobuf-c.
 				See <ulink url="https://github.com/protobuf-c/protobuf-c">protobuf-c</ulink>.
 				By default, Postgis will use Wagyu to validate MVT polygons faster which requires a c++11 compiler. It will use CXXFLAGS and the same compiler as the PostgreSQL installation. To disable this and use GEOS instead use the <varname>--without-wagyu</varname> during the configure step.
Summary of changes:
 configure.ac         | 4 ++--
 doc/installation.xml | 4 ++--
 2 files changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
