[postgis-tickets] [PostGIS] #4790: 3D measuring functions doesn't recognize identical vertex points correctly
PostGIS trac at osgeo.org
Fri Nov 13 04:21:29 PST 2020
  Reporter:  nicklas  |      Owner:  nicklas
      Type:  defect   |     Status:  assigned
  Priority:  medium   |  Milestone:  PostGIS 3.1.0
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:
Comment (by nicklas):
 The problem is that the shared vertex is not identified but calculated
 which gives floating point error.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4790#comment:1>
