[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.2-16-g5566fb7
Fri Nov 13 05:47:50 PST 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  5566fb734626f1ef93b9990ec6212e17b69669da (commit)
      from  7b6d177b97555fb5918aab553c56eea1dc387699 (commit)
revisions in full, below.
commit 5566fb734626f1ef93b9990ec6212e17b69669da
Author: Nicklas Avén <nicklas.aven at jordogskog.no>
Date:   Fri Nov 13 11:18:08 2020 +0100
    Fix ST_3dintersects calculations with identical vertices
    Short circuit when geometries share points to avoid unnecessary
    calculations that can lead to floating point errors
    References #4790 (3.0)
diff --git a/NEWS b/NEWS
index d3399e4..a1975d9 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,7 @@ PostGIS 3.0.3dev
   - #4769, Fix segfault in st_addband (Raúl Marín)
   - #4748, Fix incorrect axis swapping in polar stereographic (Paul Ramsey)
   - #4727, Fix bug in geocentrix box computation (Paul Ramsey)
+  - #4790, Fix ST_3dintersects calculations with identical vertices (Nicklas Avén)
 PostGIS 3.0.2
 2020/08/15
diff --git a/liblwgeom/cunit/cu_measures.c b/liblwgeom/cunit/cu_measures.c
index 7cfccd3..8867992 100644
--- a/liblwgeom/cunit/cu_measures.c
+++ b/liblwgeom/cunit/cu_measures.c
@@ -30,19 +30,20 @@ static LWGEOM* lwgeom_from_text(const char *str)
 	return r.geom;
-#define DIST2DTEST(str1, str2, res) \
-	do_test_mindistance_tolerance(str1, str2, res, __LINE__, lwgeom_mindistance2d_tolerance);\
-	do_test_mindistance_tolerance(str2, str1, res, __LINE__, lwgeom_mindistance2d_tolerance)
-#define DIST3DTEST(str1, str2, res) \
-	do_test_mindistance_tolerance(str1, str2, res, __LINE__, lwgeom_mindistance3d_tolerance);\
-	do_test_mindistance_tolerance(str2, str1, res, __LINE__, lwgeom_mindistance3d_tolerance)
+#define DIST2DTEST(str1, str2, res, accepted_error) \
+	do_test_mindistance_tolerance(str1, str2, res, __LINE__, lwgeom_mindistance2d_tolerance, accepted_error);\
+	do_test_mindistance_tolerance(str2, str1, res, __LINE__, lwgeom_mindistance2d_tolerance, accepted_error)
+#define DIST3DTEST(str1, str2, res, accepted_error) \
+	do_test_mindistance_tolerance(str1, str2, res, __LINE__, lwgeom_mindistance3d_tolerance, accepted_error);\
+	do_test_mindistance_tolerance(str2, str1, res, __LINE__, lwgeom_mindistance3d_tolerance, accepted_error)
 static void
 do_test_mindistance_tolerance(char *in1,
 			      char *in2,
 			      double expected_res,
 			      int line,
-			      double (*distancef)(const LWGEOM *, const LWGEOM *, double))
+			      double (*distancef)(const LWGEOM *, const LWGEOM *, double),
+				  double accepted_error)
 	LWGEOM *lw1;
 	LWGEOM *lw2;
@@ -71,7 +72,7 @@ do_test_mindistance_tolerance(char *in1,
 	lwgeom_free(lw1);
 	lwgeom_free(lw2);
-	if ( fabs(distance - expected_res) > 0.00001 )
+	if ( fabs(distance - expected_res) > accepted_error )
 		printf(msg1, distance, expected_res, line);
 		CU_FAIL();
@@ -85,222 +86,232 @@ do_test_mindistance_tolerance(char *in1,
 static void test_mindistance2d_tolerance(void)
+	double default_accepted_error = 0.00001;
+	double zero_accepted_error = 0.0;
 	** Simple case.
-	DIST2DTEST("POINT(0 0)", "MULTIPOINT(0 1.5,0 2,0 2.5)", 1.5);
+	DIST2DTEST("POINT(0 0)", "MULTIPOINT(0 1.5,0 2,0 2.5)", 1.5, default_accepted_error);
 	** Point vs Geometry Collection.
-	DIST2DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(POINT(3 4))", 5.0);
+	DIST2DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(POINT(3 4))", 5.0, default_accepted_error);
 	** Point vs Geometry Collection Collection.
-	DIST2DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4)))", 5.0);
+	DIST2DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4)))", 5.0, default_accepted_error);
 	** Point vs Geometry Collection Collection Collection.
-	DIST2DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4))))", 5.0);
+	DIST2DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4))))", 5.0, default_accepted_error);
 	** Point vs Geometry Collection Collection Collection Multipoint.
-	DIST2DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(3 4))))", 5.0);
+	DIST2DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(3 4))))", 5.0, default_accepted_error);
 	** Geometry Collection vs Geometry Collection
-	DIST2DTEST("GEOMETRYCOLLECTION(POINT(0 0))", "GEOMETRYCOLLECTION(POINT(3 4))", 5.0);
+	DIST2DTEST("GEOMETRYCOLLECTION(POINT(0 0))", "GEOMETRYCOLLECTION(POINT(3 4))", 5.0, default_accepted_error);
 	** Geometry Collection Collection vs Geometry Collection Collection
-	DIST2DTEST("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(0 0)))", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4)))", 5.0);
+	DIST2DTEST("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(0 0)))", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4)))", 5.0, default_accepted_error);
 	** Geometry Collection Collection Multipoint vs Geometry Collection Collection Multipoint
-	DIST2DTEST("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(0 0)))", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(3 4)))", 5.0);
+	DIST2DTEST("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(0 0)))", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(3 4)))", 5.0, default_accepted_error);
 	** Linestring vs its start point
-	DIST2DTEST("LINESTRING(-2 0, -0.2 0)", "POINT(-2 0)", 0);
+	DIST2DTEST("LINESTRING(-2 0, -0.2 0)", "POINT(-2 0)", 0, zero_accepted_error);
 	** Linestring vs its end point
-	DIST2DTEST("LINESTRING(-0.2 0, -2 0)", "POINT(-2 0)", 0);
+	DIST2DTEST("LINESTRING(-0.2 0, -2 0)", "POINT(-2 0)", 0, zero_accepted_error);
 	** Linestring vs its start point (tricky number, see #1459)
-	DIST2DTEST("LINESTRING(-1e-8 0, -0.2 0)", "POINT(-1e-8 0)", 0);
+	DIST2DTEST("LINESTRING(-1e-8 0, -0.2 0)", "POINT(-1e-8 0)", 0, zero_accepted_error);
 	** Linestring vs its end point (tricky number, see #1459)
-	DIST2DTEST("LINESTRING(-0.2 0, -1e-8 0)", "POINT(-1e-8 0)", 0);
+	DIST2DTEST("LINESTRING(-0.2 0, -1e-8 0)", "POINT(-1e-8 0)", 0, zero_accepted_error);
 	* Circular string and point
-	DIST2DTEST("CIRCULARSTRING(-1 0, 0 1, 1 0)", "POINT(0 0)", 1);
-	DIST2DTEST("CIRCULARSTRING(-3 0, -2 0, -1 0, 0 1, 1 0)", "POINT(0 0)", 1);
+	DIST2DTEST("CIRCULARSTRING(-1 0, 0 1, 1 0)", "POINT(0 0)", 1, default_accepted_error);
+	DIST2DTEST("CIRCULARSTRING(-3 0, -2 0, -1 0, 0 1, 1 0)", "POINT(0 0)", 1, default_accepted_error);
 	* Circular string and Circular string
-	DIST2DTEST("CIRCULARSTRING(-1 0, 0 1, 1 0)", "CIRCULARSTRING(0 0, 1 -1, 2 0)", 1);
+	DIST2DTEST("CIRCULARSTRING(-1 0, 0 1, 1 0)", "CIRCULARSTRING(0 0, 1 -1, 2 0)", 1, default_accepted_error);
 	* CurvePolygon and Point
 	static char *cs1 = "CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(1 6, 6 1, 9 7),(9 7, 3 13, 1 6)),COMPOUNDCURVE((3 6, 5 4, 7 4, 7 6),CIRCULARSTRING(7 6,5 8,3 6)))";
-	DIST2DTEST(cs1, "POINT(3 14)", 1);
-	DIST2DTEST(cs1, "POINT(3 8)", 0);
-	DIST2DTEST(cs1, "POINT(6 5)", 1);
-	DIST2DTEST(cs1, "POINT(6 4)", 0);
+	DIST2DTEST(cs1, "POINT(3 14)", 1, default_accepted_error);
+	DIST2DTEST(cs1, "POINT(3 8)", 0, default_accepted_error);
+	DIST2DTEST(cs1, "POINT(6 5)", 1, default_accepted_error);
+	DIST2DTEST(cs1, "POINT(6 4)", 0, default_accepted_error);
 	* CurvePolygon and Linestring
-	DIST2DTEST(cs1, "LINESTRING(0 0, 50 0)", 0.917484);
-	DIST2DTEST(cs1, "LINESTRING(6 0, 10 7)", 0);
-	DIST2DTEST(cs1, "LINESTRING(4 4, 4 8)", 0);
-	DIST2DTEST(cs1, "LINESTRING(4 7, 5 6, 6 7)", 0.585786);
-	DIST2DTEST(cs1, "LINESTRING(10 0, 10 2, 10 0)", 1.52913);
+	DIST2DTEST(cs1, "LINESTRING(0 0, 50 0)", 0.917484, default_accepted_error);
+	DIST2DTEST(cs1, "LINESTRING(6 0, 10 7)", 0, default_accepted_error);
+	DIST2DTEST(cs1, "LINESTRING(4 4, 4 8)", 0, default_accepted_error);
+	DIST2DTEST(cs1, "LINESTRING(4 7, 5 6, 6 7)", 0.585786, default_accepted_error);
+	DIST2DTEST(cs1, "LINESTRING(10 0, 10 2, 10 0)", 1.52913, default_accepted_error);
 	* CurvePolygon and Polygon
-	DIST2DTEST(cs1, "POLYGON((10 4, 10 8, 13 8, 13 4, 10 4))", 0.58415);
-	DIST2DTEST(cs1, "POLYGON((9 4, 9 8, 12 8, 12 4, 9 4))", 0);
-	DIST2DTEST(cs1, "POLYGON((1 4, 1 8, 4 8, 4 4, 1 4))", 0);
+	DIST2DTEST(cs1, "POLYGON((10 4, 10 8, 13 8, 13 4, 10 4))", 0.58415, default_accepted_error);
+	DIST2DTEST(cs1, "POLYGON((9 4, 9 8, 12 8, 12 4, 9 4))", 0, default_accepted_error);
+	DIST2DTEST(cs1, "POLYGON((1 4, 1 8, 4 8, 4 4, 1 4))", 0, default_accepted_error);
 	* CurvePolygon and CurvePolygon
-	DIST2DTEST(cs1, "CURVEPOLYGON(CIRCULARSTRING(-1 4, 0 5, 1 4, 0 3, -1 4))", 0.0475666);
-	DIST2DTEST(cs1, "CURVEPOLYGON(CIRCULARSTRING(1 4, 2 5, 3 4, 2 3, 1 4))", 0.0);
+	DIST2DTEST(cs1, "CURVEPOLYGON(CIRCULARSTRING(-1 4, 0 5, 1 4, 0 3, -1 4))", 0.0475666, default_accepted_error);
+	DIST2DTEST(cs1, "CURVEPOLYGON(CIRCULARSTRING(1 4, 2 5, 3 4, 2 3, 1 4))", 0.0, default_accepted_error);
 	* MultiSurface and CurvePolygon
 	static char *cs2 = "MULTISURFACE(POLYGON((0 0,0 4,4 4,4 0,0 0)),CURVEPOLYGON(CIRCULARSTRING(8 2,10 4,12 2,10 0,8 2)))";
-	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(5 2,6 3,7 2,6 1,5 2))", 1);
-	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(4 2,5 3,6 2,5 1,4 2))", 0);
-	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(5 3,6 2,5 1,4 2,5 3))", 0);
-	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(4.5 3,5.5 2,4.5 1,3.5 2,4.5 3))", 0);
-	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(5.5 3,6.5 2,5.5 1,4.5 2,5.5 3))", 0.5);
-	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(10 3,11 2,10 1,9 2,10 3))", 0);
-	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(2 3,3 2,2 1,1 2,2 3))", 0);
-	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(5 7,6 8,7 7,6 6,5 7))", 2.60555);
+	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(5 2,6 3,7 2,6 1,5 2))", 1, default_accepted_error);
+	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(4 2,5 3,6 2,5 1,4 2))", 0, default_accepted_error);
+	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(5 3,6 2,5 1,4 2,5 3))", 0, default_accepted_error);
+	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(4.5 3,5.5 2,4.5 1,3.5 2,4.5 3))", 0, default_accepted_error);
+	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(5.5 3,6.5 2,5.5 1,4.5 2,5.5 3))", 0.5, default_accepted_error);
+	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(10 3,11 2,10 1,9 2,10 3))", 0, default_accepted_error);
+	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(2 3,3 2,2 1,1 2,2 3))", 0, default_accepted_error);
+	DIST2DTEST(cs2, "CURVEPOLYGON(CIRCULARSTRING(5 7,6 8,7 7,6 6,5 7))", 2.60555, default_accepted_error);
 	* MultiCurve and Linestring
-	DIST2DTEST("LINESTRING(0.5 1,0.5 3)", "MULTICURVE(CIRCULARSTRING(2 3,3 2,2 1,1 2,2 3),(0 0, 0 5))", 0.5);
+	DIST2DTEST("LINESTRING(0.5 1,0.5 3)", "MULTICURVE(CIRCULARSTRING(2 3,3 2,2 1,1 2,2 3),(0 0, 0 5))", 0.5, default_accepted_error);
 static void
 test_mindistance3d_tolerance(void)
 	/* 2D [Z=0] should work just the same */
-	DIST3DTEST("POINT(0 0 0)", "MULTIPOINT(0 1.5 0, 0 2 0, 0 2.5 0)", 1.5);
-	DIST3DTEST("POINT(0 0 0)", "GEOMETRYCOLLECTION(POINT(3 4 0))", 5.0);
-	DIST3DTEST("POINT(0 0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4 0)))", 5.0);
-	DIST3DTEST("POINT(0 0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4 0))))", 5.0);
-	DIST3DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(3 4))))", 5.0);
-	DIST3DTEST("GEOMETRYCOLLECTION(POINT(0 0 0))", "GEOMETRYCOLLECTION(POINT(3 4 0))", 5.0);
+	DIST3DTEST("POINT(0 0 0)", "MULTIPOINT(0 1.5 0, 0 2 0, 0 2.5 0)", 1.5, default_accepted_error);
+	DIST3DTEST("POINT(0 0 0)", "GEOMETRYCOLLECTION(POINT(3 4 0))", 5.0, default_accepted_error);
+	DIST3DTEST("POINT(0 0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4 0)))", 5.0, default_accepted_error);
+	DIST3DTEST("POINT(0 0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(3 4 0))))", 5.0, default_accepted_error);
+	DIST3DTEST("POINT(0 0)", "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(3 4))))", 5.0, default_accepted_error);
+	DIST3DTEST("GEOMETRYCOLLECTION(POINT(0 0 0))", "GEOMETRYCOLLECTION(POINT(3 4 0))", 5.0, default_accepted_error);
 	DIST3DTEST("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(0 0 0)))",
-		   5.0);
+		   5.0, default_accepted_error);
 	DIST3DTEST("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(0 0 0)))",
 		   "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(MULTIPOINT(3 4 0)))",
-		   5.0);
-	DIST3DTEST("LINESTRING(-2 0 0, -0.2 0 0)", "POINT(-2 0 0)", 0);
-	DIST3DTEST("LINESTRING(-0.2 0 0, -2 0 0)", "POINT(-2 0 0)", 0);
-	DIST3DTEST("LINESTRING(-1e-8 0 0, -0.2 0 0)", "POINT(-1e-8 0 0)", 0);
-	DIST3DTEST("LINESTRING(-0.2 0 0, -1e-8 0 0)", "POINT(-1e-8 0 0)", 0);
+	DIST3DTEST("LINESTRING(-2 0 0, -0.2 0 0)", "POINT(-2 0 0)", 0, zero_accepted_error);
+	DIST3DTEST("LINESTRING(-0.2 0 0, -2 0 0)", "POINT(-2 0 0)", 0, zero_accepted_error);
+	DIST3DTEST("LINESTRING(-1e-8 0 0, -0.2 0 0)", "POINT(-1e-8 0 0)", 0, zero_accepted_error);
+	DIST3DTEST("LINESTRING(-0.2 0 0, -1e-8 0 0)", "POINT(-1e-8 0 0)", 0, zero_accepted_error);
 	/* Tests around intersections */
-	DIST3DTEST("LINESTRING(1 0 0 , 2 0 0)", "POLYGON((1 1 0, 2 1 0, 2 2 0, 1 2 0, 1 1 0))", 1.0);
-	DIST3DTEST("LINESTRING(1 1 1 , 2 1 0)", "POLYGON((1 1 0, 2 1 0, 2 2 0, 1 2 0, 1 1 0))", 0.0);
-	DIST3DTEST("LINESTRING(1 1 1 , 2 1 1)", "POLYGON((1 1 0, 2 1 0, 2 2 0, 1 2 0, 1 1 0))", 1.0);
+	DIST3DTEST("LINESTRING(1 0 0 , 2 0 0)", "POLYGON((1 1 0, 2 1 0, 2 2 0, 1 2 0, 1 1 0))", 1.0, default_accepted_error);
+	DIST3DTEST("LINESTRING(1 1 1 , 2 1 0)", "POLYGON((1 1 0, 2 1 0, 2 2 0, 1 2 0, 1 1 0))", 0.0, zero_accepted_error);
+	DIST3DTEST("LINESTRING(1 1 1 , 2 1 1)", "POLYGON((1 1 0, 2 1 0, 2 2 0, 1 2 0, 1 1 0))", 1.0, default_accepted_error);
 	/* Same but triangles */
-	DIST3DTEST("LINESTRING(1 0 0 , 2 0 0)", "TRIANGLE((1 1 0, 2 1 0, 1 2 0, 1 1 0))", 1.0);
-	DIST3DTEST("LINESTRING(1 1 1 , 2 1 0)", "TRIANGLE((1 1 0, 2 1 0, 1 2 0, 1 1 0))", 0.0);
-	DIST3DTEST("LINESTRING(1 1 1 , 2 1 1)", "TRIANGLE((1 1 0, 2 1 0, 1 2 0, 1 1 0))", 1.0);
+	DIST3DTEST("LINESTRING(1 0 0 , 2 0 0)", "TRIANGLE((1 1 0, 2 1 0, 1 2 0, 1 1 0))", 1.0, default_accepted_error);
+	DIST3DTEST("LINESTRING(1 1 1 , 2 1 0)", "TRIANGLE((1 1 0, 2 1 0, 1 2 0, 1 1 0))", 0.0, zero_accepted_error);
+	DIST3DTEST("LINESTRING(1 1 1 , 2 1 1)", "TRIANGLE((1 1 0, 2 1 0, 1 2 0, 1 1 0))", 1.0, default_accepted_error);
 	/* Triangle to triangle*/
-	DIST3DTEST("TRIANGLE((-1 1 0, -2 1 0, -1 2 0, -1 1 0))", "TRIANGLE((1 1 0, 2 1 0, 1 2 0, 1 1 0))", 2.0);
+	DIST3DTEST("TRIANGLE((-1 1 0, -2 1 0, -1 2 0, -1 1 0))", "TRIANGLE((1 1 0, 2 1 0, 1 2 0, 1 1 0))", 2.0, default_accepted_error);
 	/* Line in polygon */
-	DIST3DTEST("LINESTRING(1 1 1 , 2 2 2)", "POLYGON((0 0 0, 2 2 2, 3 3 1, 0 0 0))", 0.0);
+	DIST3DTEST("LINESTRING(1 1 1 , 2 2 2)", "POLYGON((0 0 0, 2 2 2, 3 3 1, 0 0 0))", 0.0, zero_accepted_error);
 	/* Line has a point in the same plane as the polygon but isn't the closest*/
-	DIST3DTEST("LINESTRING(-10000 -10000 0, 0 0 1)", "POLYGON((0 0 0, 1 0 0, 1 1 0, 0 1 0, 0 0 0))", 1);
+	DIST3DTEST("LINESTRING(-10000 -10000 0, 0 0 1)", "POLYGON((0 0 0, 1 0 0, 1 1 0, 0 1 0, 0 0 0))", 1, default_accepted_error);
 	/* This is an invalid polygon since it defines just a line */
-	DIST3DTEST("LINESTRING(1 1 1, 2 2 2)", "POLYGON((0 0 0, 2 2 2, 3 3 3, 0 0 0))", 0);
-	DIST3DTEST("TRIANGLE((1 1 1, 2 2 2, 3 3 3, 1 1 1))", "POLYGON((0 0 0, 2 2 2, 3 3 3, 0 0 0))", 0);
-	DIST3DTEST("POLYGON((0 0 0, 2 2 2, 3 3 3, 0 0 0))", "TRIANGLE((1 1 1, 2 2 2, 3 3 3, 1 1 1))", 0);
-	DIST3DTEST("TRIANGLE((0 0 0, 2 2 2, 3 3 3, 0 0 0))", "LINESTRING(1 1 1, 2 2 2)", 0);
+	DIST3DTEST("LINESTRING(1 1 1, 2 2 2)", "POLYGON((0 0 0, 2 2 2, 3 3 3, 0 0 0))", 0, zero_accepted_error);
+	DIST3DTEST("TRIANGLE((1 1 1, 2 2 2, 3 3 3, 1 1 1))", "POLYGON((0 0 0, 2 2 2, 3 3 3, 0 0 0))", 0, zero_accepted_error);
+	DIST3DTEST("POLYGON((0 0 0, 2 2 2, 3 3 3, 0 0 0))", "TRIANGLE((1 1 1, 2 2 2, 3 3 3, 1 1 1))", 0, zero_accepted_error);
+	DIST3DTEST("TRIANGLE((0 0 0, 2 2 2, 3 3 3, 0 0 0))", "LINESTRING(1 1 1, 2 2 2)", 0, zero_accepted_error);
 	/* A box in a box: two solids, one inside another */
 	DIST3DTEST(
 	    "POLYHEDRALSURFACE Z (((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),((0 0 1,1 0 1,1 1 1,0 1 1,0 0 1)),((0 0 0,0 0 1,0 1 1,0 1 0,0 0 0)),((1 0 0,1 1 0,1 1 1,1 0 1,1 0 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)),((0 1 0,0 1 1,1 1 1,1 1 0,0 1 0)))",
 	    "POLYHEDRALSURFACE Z (((-1 -1 -1,-1 2 -1,2 2 -1,2 -1 -1,-1 -1 -1)),((-1 -1 2,2 -1 2,2 2 2,-1 2 2,-1 -1 2)),((-1 -1 -1,-1 -1 2,-1 2 2,-1 2 -1,-1 -1 -1)),((2 -1 -1,2 2 -1,2 2 2,2 -1 2,2 -1 -1)),((-1 -1 -1,2 -1 -1,2 -1 2,-1 -1 2,-1 -1 -1)),((-1 2 -1,-1 2 2,2 2 2,2 2 -1,-1 2 -1)))",
-	    0);
+	    0, zero_accepted_error);
 	/* A box in a box with a hat: two solids, one inside another, Z ray up is hitting hat */
 	DIST3DTEST(
 	    "POLYHEDRALSURFACE Z (((0 0 2,0 1 2,-1 2 2,0 0 2)),((0 1 2,0 0 2,0 1 4,0 1 2)),((-1 2 2,0 1 2,1 1 2,-1 2 2)),((0 0 2,-1 2 2,-1 -1 2,0 0 2)),((0 1 4,0 0 2,0 0 4,0 1 4)),((0 1 2,0 1 4,1 1 4,0 1 2)),((1 1 2,0 1 2,1 1 4,1 1 2)),((-1 2 2,1 1 2,2 2 2,-1 2 2)),((-1 -1 2,-1 2 2,-1 -1 -1,-1 -1 2)),((0 0 2,-1 -1 2,1 0 2,0 0 2)),((0 0 4,0 0 2,1 0 2,0 0 4)),((0 1 4,0 0 4,1 0 4,0 1 4)),((1 1 4,0 1 4,1 0 4,1 1 4)),((1 1 2,1 1 4,1 0 4,1 1 2)),((2 2 2,1 1 2,2 -1 2,2 2 2)),((-1 2 2,2 2 2,-1 2 -1,-1 2 2)),((-1 -1 -1,-1 2 2,-1 2 -1,-1 -1 -1)),((-1 -1 2,-1 -1 -1,2 -1 -1,-1 -1 2)),((1 0 2,-1 -1 2,2 -1 2,1 0 2)),((0 0 4,1 0 2,1 0 4,0 0 4)),((1 1 2,1 0 4,1 0 2,1 1 2)),((2 -1 2,1 1 2,1 0 2,2 -1 2)),((2 2 2,2 -1 2,2 2 -1,2 2 2)),((-1 2 -1,2 2 2,2 2 -1,-1 2 -1)),((-1 -1 -1,-1 2 -1,2 2 -1,-1 -1 -1)),((2 -1 -1,-1 -1 -1,2 2 -1,2 -1 -1)),((-1 -1 2,2 -1 -1,2 -1 2,-1 -1 2)),((2 2 -1,2 -1 2,2 -1 -1,2 2 -1)))",
-	    0);
 	/* Same but as TIN */
 	DIST3DTEST(
 	    "TIN Z (((0 0 2,0 1 2,-1 2 2,0 0 2)),((0 1 2,0 0 2,0 1 4,0 1 2)),((-1 2 2,0 1 2,1 1 2,-1 2 2)),((0 0 2,-1 2 2,-1 -1 2,0 0 2)),((0 1 4,0 0 2,0 0 4,0 1 4)),((0 1 2,0 1 4,1 1 4,0 1 2)),((1 1 2,0 1 2,1 1 4,1 1 2)),((-1 2 2,1 1 2,2 2 2,-1 2 2)),((-1 -1 2,-1 2 2,-1 -1 -1,-1 -1 2)),((0 0 2,-1 -1 2,1 0 2,0 0 2)),((0 0 4,0 0 2,1 0 2,0 0 4)),((0 1 4,0 0 4,1 0 4,0 1 4)),((1 1 4,0 1 4,1 0 4,1 1 4)),((1 1 2,1 1 4,1 0 4,1 1 2)),((2 2 2,1 1 2,2 -1 2,2 2 2)),((-1 2 2,2 2 2,-1 2 -1,-1 2 2)),((-1 -1 -1,-1 2 2,-1 2 -1,-1 -1 -1)),((-1 -1 2,-1 -1 -1,2 -1 -1,-1 -1 2)),((1 0 2,-1 -1 2,2 -1 2,1 0 2)),((0 0 4,1 0 2,1 0 4,0 0 4)),((1 1 2,1 0 4,1 0 2,1 1 2)),((2 -1 2,1 1 2,1 0 2,2 -1 2)),((2 2 2,2 -1 2,2 2 -1,2 2 2)),((-1 2 -1,2 2 2,2 2 -1,-1 2 -1)),((-1 -1 -1,-1 2 -1,2 2 -1,-1 -1 -1)),((2 -1 -1,-1 -1 -1,2 2 -1,2 -1 -1)),((-1 -1 2,2 -1 -1,2 -1 2,-1 -1 2)),((2 2 -1,2 -1 2,2 -1 -1,2 2 -1)))",
-	    0);
 	/* Same but both are TIN */
 	DIST3DTEST(
 	    "TIN Z (((0 0 0,0 1 0,1 1 0,0 0 0)),((1 0 0,0 0 0,1 1 0,1 0 0)),((0 1 1,1 0 1,1 1 1,0 1 1)),((0 1 1,0 0 1,1 0 1,0 1 1)),((0 0 0,0 0 1,0 1 1,0 0 0)),((0 1 0,0 0 0,0 1 1,0 1 0)),((1 0 1,1 1 0,1 1 1,1 0 1)),((1 0 1,1 0 0,1 1 0,1 0 1)),((0 0 1,1 0 0,1 0 1,0 0 1)),((0 0 1,0 0 0,1 0 0,0 0 1)),((0 1 0,0 1 1,1 1 1,0 1 0)),((1 1 0,0 1 0,1 1 1,1 1 0)))",
-	    0);
 	/* Point inside TIN */
 	DIST3DTEST(
 	    "POINT(0 0 0)",
-	    0);
 	/* A point hits vertical Z edge */
 	DIST3DTEST(
 	    "POLYHEDRALSURFACE Z (((0 -1 1,-1 -1 1,-1 -1 -1,0 -1 -1,1 -1 -1,0 -1 2,0 -1 1)),((0 1 1,0 1 2,1 1 -1,0 1 -1,-1 1 -1,-1 1 1,0 1 1)),((0 -1 1,0 1 1,-1 1 1,-1 -1 1,0 -1 1)),((-1 -1 1,-1 1 1,-1 1 -1,-1 -1 -1,-1 -1 1)),((-1 -1 -1,-1 1 -1,0 1 -1,0 -1 -1,-1 -1 -1)),((0 -1 -1,0 1 -1,1 1 -1,1 -1 -1,0 -1 -1)),((1 -1 -1,1 1 -1,0 1 2,0 -1 2,1 -1 -1)),((0 -1 2,0 1 2,0 1 1,0 -1 1,0 -1 2)))",
 	    "POINT(0 0 0)",
-	    0);
 	/* A point in the middle of a hole of extruded polygon */
 	DIST3DTEST(
 	    "POLYHEDRALSURFACE Z (((-3 -3 0,-3 3 0,3 3 0,3 -3 0,-3 -3 0),(-1 -1 0,1 -1 0,1 1 0,-1 1 0,-1 -1 0)),((-3 -3 3,3 -3 3,3 3 3,-3 3 3,-3 -3 3),(-1 -1 3,-1 1 3,1 1 3,1 -1 3,-1 -1 3)),((-3 -3 0,-3 -3 3,-3 3 3,-3 3 0,-3 -3 0)),((-3 3 0,-3 3 3,3 3 3,3 3 0,-3 3 0)),((3 3 0,3 3 3,3 -3 3,3 -3 0,3 3 0)),((3 -3 0,3 -3 3,-3 -3 3,-3 -3 0,3 -3 0)),((-1 -1 0,-1 -1 3,1 -1 3,1 -1 0,-1 -1 0)),((1 -1 0,1 -1 3,1 1 3,1 1 0,1 -1 0)),((1 1 0,1 1 3,-1 1 3,-1 1 0,1 1 0)),((-1 1 0,-1 1 3,-1 -1 3,-1 -1 0,-1 1 0)))",
 	    "POINT(0 0 1)",
-	    1);
+	    1, zero_accepted_error);
 	/* A point at the face of a hole of extruded polygon */
 	DIST3DTEST(
 	    "POINT(1 1 2)",
-	    0);
+	/* A point at the face of a hole of extruded polygon */
+	DIST3DTEST(
+	    "LINESTRING Z (-27974.1264 -110211.5032 148.9768,-27975.4229 -110210.9441 149.0093)",
+	    "LINESTRING Z (-27995.4183 -110201.8041 149.3354,-27975.4229 -110210.9441 149.0093)",
 static int tree_pt(RECT_NODE *tree, double x, double y)
diff --git a/liblwgeom/measures3d.c b/liblwgeom/measures3d.c
index 4cb98d2..30b71f0 100644
--- a/liblwgeom/measures3d.c
+++ b/liblwgeom/measures3d.c
@@ -1011,9 +1011,9 @@ lw_dist3d_pt_seg(POINT3DZ *p, POINT3DZ *A, POINT3DZ *B, DISTPTS3D *dl)
 			return lw_dist3d_pt_pt(p, B, dl);
-	if (r < 0) /*If the first vertex A is closest to the point p*/
+	if (r <= 0) /*If the first vertex A is closest to the point p*/
 		return lw_dist3d_pt_pt(p, A, dl);
-	if (r > 1) /*If the second vertex B is closest to the point p*/
+	if (r >= 1) /*If the second vertex B is closest to the point p*/
 	/*else if the point p is closer to some point between a and b
@@ -1193,25 +1193,26 @@ lw_dist3d_seg_seg(POINT3DZ *s1p1, POINT3DZ *s1p2, POINT3DZ *s2p1, POINT3DZ *s2p2
 	/* Now we check if the projected closest point on the infinite lines is outside our segments. If so the
 	 * combinations with start and end points will be tested*/
-	if (s1k < 0.0 || s1k > 1.0 || s2k < 0.0 || s2k > 1.0)
+	if (s1k <= 0.0 || s1k >= 1.0 || s2k <= 0.0 || s2k >= 1.0)
-		if (s1k < 0.0)
+		if (s1k <= 0.0)
 			if (!lw_dist3d_pt_seg(s1p1, s2p1, s2p2, dl))
 				return LW_FALSE;
-		if (s1k > 1.0)
+		if (s1k >= 1.0)
 			if (!lw_dist3d_pt_seg(s1p2, s2p1, s2p2, dl))
 				return LW_FALSE;
-		if (s2k < 0.0)
+		if (s2k <= 0.0)
 			dl->twisted = ((dl->twisted) * (-1));
 			if (!lw_dist3d_pt_seg(s2p1, s1p1, s1p2, dl))
 				return LW_FALSE;
-		if (s2k > 1.0)
+		if (s2k >= 1.0)
 			if (!lw_dist3d_pt_seg(s2p2, s1p1, s1p2, dl))
Summary of changes:
 NEWS                          |   1 +
 liblwgeom/cunit/cu_measures.c | 171 ++++++++++++++++++++++--------------------
 liblwgeom/measures3d.c        |  15 ++--
 3 files changed, 100 insertions(+), 87 deletions(-)
hooks/post-receive
