[postgis-tickets] [PostGIS] #4790: 3D measuring functions doesn't recognize identical vertex points correctly
PostGIS trac at osgeo.org
Fri Nov 13 05:47:55 PST 2020
  Reporter:  nicklas  |      Owner:  nicklas
      Type:  defect   |     Status:  assigned
  Priority:  medium   |  Milestone:  PostGIS 3.1.0
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:
Comment (by Raúl Marín <git@…>):
 In [changeset:"5566fb734626f1ef93b9990ec6212e17b69669da/git" 5566fb7/git]:
 #!CommitTicketReference repository="git"
 revision="5566fb734626f1ef93b9990ec6212e17b69669da"
 Fix ST_3dintersects calculations with identical vertices
 Short circuit when geometries share points to avoid unnecessary
 calculations that can lead to floating point errors
 References #4790 (3.0)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4790#comment:4>
