[postgis-tickets] [PostGIS] #4794: ST_3DIntersection does not behave correctly with line strings when no vertex is seen within the intersecion
PostGIS trac at osgeo.org
Tue Nov 17 03:22:54 PST 2020
 Reporter:  basilrabi  |      Owner:  pramsey
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS SFCGAL
Component:  postgis    |    Version:  3.0.x
 Keywords:             |
 -- POSTGIS="3.0.2 2fb2a18" [EXTENSION] PGSQL="130" GEOS="3.7.1-CAPI-1.11.1
 27a5e771" SFCGAL="1.3.6" PROJ="Rel. 5.2.0, September 15th, 2018"
 GDAL="GDAL 2.4.0, released 2018/12/14" LIBXML="2.9.4" LIBJSON="0.12.1"
 LIBPROTOBUF="1.3.1" WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
 WITH solid AS (
     SELECT ST_MakeSolid(
         ST_Extrude(
             ST_Translate(
                 ST_Force3D(
                     ST_GeomFromText('POLYGON ((-1 1,1 1,1 -1,-1 -1,-1
 1))')
                 0, 0, -1
             0, 0, 2
     ) geom
 SELECT
     ST_AsText(ST_3DIntersection(
         'LINESTRING (-2 0 0,2 0 2)'::geometry,
         solid.geom
         'LINESTRING (-2 0 0,0 0 1,2 0 2)'::geometry,
         solid.geom
 FROM solid
 The code above returns
 POINT Z (-1 0 0.5), LINESTRING Z (-1 0 0.5,0 0 1)
 But I think it should be both `LINESTRING Z (-1 0 0.5,0 0 1)`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4794>
