[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-163-g5829c16
Tue Nov 17 20:53:56 PST 2020
the project "PostGIS".
       via  5829c165ccf2afcfd6d59cbe12c363f61a903c77 (commit)
      from  e65386f7062a3013c0753a7d5cd83fcf8e6592ae (commit)
revisions in full, below.
commit 5829c165ccf2afcfd6d59cbe12c363f61a903c77
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Nov 17 23:53:43 2020 -0500
    Change TopologyElementArray constraint to not exclude null and minor cleanup on news.  Closes #3372 for PostGIS 3.1
diff --git a/NEWS b/NEWS
index 70b4024..aaa227f 100644
--- a/NEWS
+++ b/NEWS
@@ -6,14 +6,14 @@ Only tickets not included in 3.1.0alpha2
   - #4737, Bump minimum protobuf-c requirement to 1.1.0 (Raúl Marín)
            The configure step will now fail if the requirement isn't
            met or explicitly disabled (--without-protobuf)
-  - #4258, Untangle postgis_sfcgal into its own .so (Regina Obe)
+  - #4258, Untangle postgis_sfcgal from postgis
+           into its own lib file (Regina Obe)
 * New features *
   - #4698, Add a precision parameter to ST_AsEWKT (Raúl Marín)
   - Add a gridSize optional parameter to ST_Union, ST_UnaryUnion,
     ST_Difference, ST_Intersection, ST_SymDifference, ST_Subdivide
-    (Sandro Santilli)
-  - GEOS 3.9
+    Requires GEOS 3.9 (Sandro Santilli)
 * Enhancements *
@@ -57,6 +57,7 @@ Only tickets not included in 3.1.0alpha2
   - #4769, Fix segfault in st_addband (Raúl Marín)
   - #4790, Fix ST_3dintersects calculations with identical vertices (Nicklas Avén)
   - #4742, tiger geocoder reverted to 2018 version on tiger upgrade (Regina Obe)
+  - #3372, TopoElementArray cannot be null - change domain constraint (Regina Obe)
 PostGIS 3.1.0alpha2
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 9e67725..c08f1be 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -375,10 +375,22 @@ ALTER DOMAIN topology.TopoElement ADD
 -- TopoElementArray domain
+-- Changed: 3.1.0 - get rid of IS NOT NULL check
 CREATE DOMAIN topology.TopoElementArray AS integer[][]
   CONSTRAINT DIMENSIONS CHECK (
-    array_upper(VALUE, 2) IS NOT NULL
-    AND array_upper(VALUE, 2) = 2
+    array_upper(VALUE, 2) = 2
+    AND array_upper(VALUE, 3) IS NULL
+-- Changed: 3.1.0
+ALTER DOMAIN topology.TopoElementArray DROP CONSTRAINT
+  IF EXISTS
+  DIMENSIONS;
+ALTER DOMAIN topology.TopoElementArray ADD
+        CONSTRAINT type_range CHECK (
Summary of changes:
 NEWS                     |  7 ++++---
 topology/topology.sql.in | 16 ++++++++++++++--
 2 files changed, 18 insertions(+), 5 deletions(-)
hooks/post-receive
