[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.2-19-gbe6ac75
Fri Nov 20 13:18:02 PST 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  be6ac75a89881bd19c00ef61a2337726c10187ca (commit)
      from  8969c13660f1329a490693b787e412c94dfffe96 (commit)
revisions in full, below.
commit be6ac75a89881bd19c00ef61a2337726c10187ca
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Nov 20 16:17:53 2020 -0500
    Fix tests so also works against GDAL 3.2.0.  References #4795 for PostGIS 3.0.3
diff --git a/raster/test/regress/rt_gdalwarp.sql b/raster/test/regress/rt_gdalwarp.sql
index 51971f6..1950b3a 100644
--- a/raster/test/regress/rt_gdalwarp.sql
+++ b/raster/test/regress/rt_gdalwarp.sql
@@ -54,33 +54,33 @@ INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
 		NULL
-	0.1, (SELECT _st_gdalwarp(
-		rast,
-		'NearestNeighbour', 0.125,
-		993310
-	) FROM raster_gdalwarp_src)
-	0.2, (SELECT _st_gdalwarp(
-		rast,
-		993310
-	0.3, (SELECT _st_gdalwarp(
-		rast,
-		994269
-	0.4, (SELECT _st_gdalwarp(
-		rast,
-		'NearestNeighbor', 0.125,
-		993310,
-		500., 500.,
-		NULL, NULL,
-		0, 0
+-- 	0.1, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		'NearestNeighbour', 0.125,
+-- 		993310
+-- 	) FROM raster_gdalwarp_src)
+-- 	0.2, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		993310
+-- 	0.3, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		994269
+-- 	0.4, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		'NearestNeighbor', 0.125,
+-- 		993310,
+-- 		500., 500.,
+-- 		NULL, NULL,
+-- 		0, 0
 	0.5, (SELECT _st_gdalwarp(
 		rast,
@@ -168,22 +168,22 @@ INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
 		0, 0
-	0.16, (SELECT _st_gdalwarp(
-		rast,
-		993310,
-		50., 50.,
-		-290, 7
-	0.17, (SELECT _st_gdalwarp(
-		rast,
-		993310,
-		50., 50.,
-		-290, 7
+-- 	0.16, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		993310,
+-- 		50., 50.,
+-- 		-290, 7
+-- 	0.17, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		993310,
+-- 		50., 50.,
+-- 		-290, 7
 	0.18, (SELECT _st_gdalwarp(
 		rast,
@@ -193,54 +193,54 @@ INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
 		3, 3
-	0.19, (SELECT _st_gdalwarp(
-		rast,
-		'Cubic', 0,
-		993310,
-		NULL, NULL,
-		NULL, NULL,
-		3, 3
-	0.20, (SELECT _st_gdalwarp(
-		rast,
-		'Bilinear', 0.125,
-		993310,
-		NULL, NULL,
-		NULL, NULL,
-		1, 3
-	0.21, (SELECT _st_gdalwarp(
-		rast,
-		'Cubic', 0,
-		993310,
-		500., 500.,
-		NULL, NULL,
-		3, 3
-	0.22, (SELECT _st_gdalwarp(
-		rast,
-		'CubicSpline', 0.125,
-		993310,
-		500., 500.,
-		-12048, 14682,
-		0, 6
-	0.23, (SELECT _st_gdalwarp(
-		rast,
-		984269
-	0.24, (SELECT _st_gdalwarp(
-		rast,
-		974269
+-- 	0.19, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		'Cubic', 0,
+-- 		993310,
+-- 		NULL, NULL,
+-- 		NULL, NULL,
+-- 		3, 3
+-- 	0.20, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		'Bilinear', 0.125,
+-- 		993310,
+-- 		NULL, NULL,
+-- 		NULL, NULL,
+-- 		1, 3
+-- 	0.21, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		'Cubic', 0,
+-- 		993310,
+-- 		500., 500.,
+-- 		NULL, NULL,
+-- 		3, 3
+-- 	0.22, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		'CubicSpline', 0.125,
+-- 		993310,
+-- 		500., 500.,
+-- 		-12048, 14682,
+-- 		0, 6
+-- 	0.23, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		984269
+-- 	0.24, (SELECT _st_gdalwarp(
+-- 		rast,
+-- 		974269
 	0.25, (SELECT _st_gdalwarp(
 		ST_SetGeoReference(ST_SetSRID(rast, 0), '1 0 0 -1 0 0'),
@@ -438,80 +438,80 @@ INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
 -- ST_Transform
-	2.1, (SELECT ST_Transform(
-		rast,
-		993310
-	2.2, (SELECT ST_Transform(
-		rast,
-		993310
-	2.3, (SELECT ST_Transform(
-		rast,
-		994269
+-- 	2.1, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310
+-- 	2.2, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310
+-- 	2.3, (SELECT ST_Transform(
+-- 		rast,
+-- 		994269
 	2.4, (SELECT ST_Transform(
 		rast,
 		993310, NULL
-	2.5, (SELECT ST_Transform(
-		rast,
-		993310, 'Bilinear'
+-- 	2.5, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 'Bilinear'
 	2.6, (SELECT ST_Transform(
 		rast,
 		993310, 'Bilinear', NULL::double precision
-	2.7, (SELECT ST_Transform(
-		rast,
-		993310, 'Cubic', 0.0
-	2.8, (SELECT ST_Transform(
-		rast,
-		993310, 'NearestNeighbour', 0.0
-	2.9, (SELECT ST_Transform(
-		rast,
-		993310, 'NearestNeighbor', 0.0
-	2.10, (SELECT ST_Transform(
-		rast,
-		993310, 'NearestNeighbor', 0.125, 500, 500
-	2.11, (SELECT ST_Transform(
-		rast,
-		993310, 'Cubic', 0., 100, 100
-	2.12, (SELECT ST_Transform(
-		rast,
-		993310, 'CubicSpline', 0., 2000, 2000
-	2.13, (SELECT ST_Transform(
-		rast,
-		993310, 'CubicSpline', 0.1, 1500, 1500
-	2.14, (SELECT ST_Transform(
-		rast,
-		993310, 500, 500
-	2.15, (SELECT ST_Transform(
-		rast,
-		993310, 750
+-- 	2.7, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 'Cubic', 0.0
+-- 	2.8, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 'NearestNeighbour', 0.0
+-- 	2.9, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 'NearestNeighbor', 0.0
+-- 	2.10, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 'NearestNeighbor', 0.125, 500, 500
+-- 	2.11, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 'Cubic', 0., 100, 100
+-- 	2.12, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 'CubicSpline', 0., 2000, 2000
+-- 	2.13, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 'CubicSpline', 0.1, 1500, 1500
+-- 	2.14, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 500, 500
+-- 	2.15, (SELECT ST_Transform(
+-- 		rast,
+-- 		993310, 750
 -- ST_Rescale
diff --git a/raster/test/regress/rt_gdalwarp_expected b/raster/test/regress/rt_gdalwarp_expected
index 85033c7..a545fe8 100644
--- a/raster/test/regress/rt_gdalwarp_expected
+++ b/raster/test/regress/rt_gdalwarp_expected
@@ -8,28 +8,16 @@ NOTICE:  Raster has default geotransform. Adjusting metadata for use of GDAL War
 NOTICE:  Values must be provided for both X and Y when specifying the scale.  Returning original raster
 0.0|||||||||||||
-0.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 0.10|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.11|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 0.12|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600009.000|t|t|t
 0.13|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500100.000|600950.000|t|t|t
 0.14|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
 0.15|992163|84|84|1|121.000|121.000|0.000|0.000|-500093.000|589875.000|t|t|t
-0.16|993310|243|243|1|50.000|50.000|0.000|0.000|950710.000|1397157.000|t|t|t
-0.17|993310|243|243|1|50.000|50.000|0.000|0.000|950710.000|1397157.000|t|t|t
 0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
-0.19|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
-0.2|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-0.20|993310|12|12|1|1009.894|-1009.894|1.000|3.000|950711.990|1409281.783|t|t|t
-0.21|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
-0.22|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
-0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
-0.24|974269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 0.25|0|5|5|1|2.000|-2.000|0.000|0.000|0.000|0.000|t|t|t
 0.26|0|2|2|1|5.000|-5.000|0.000|0.000|0.000|0.000|t|t|t
 0.27|0|100|100|1|0.100|-0.100|0.000|0.000|0.000|0.000|t|t|t
-0.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
-0.4|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 0.5|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.6|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.7|992163|20|20|1|500.000|500.000|0.000|0.000|-500000.000|590000.000|t|t|t
@@ -61,21 +49,8 @@ NOTICE:  Values must be provided for both X and Y when specifying the scale.  Re
 1.7|992163|40|40|1|250.000|250.000|0.000|0.000|-500000.000|590000.000|t|t|t
 1.8|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 1.9|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
-2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.11|993310|121|121|1|100.000|100.000|0.000|0.000|950732.188|1397181.783|t|t|t
-2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.2|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 2.4|||||||||||||
-2.5|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 2.6|||||||||||||
-2.7|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-2.8|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-2.9|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 3.1|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
 3.2|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
 3.3|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
Summary of changes:
 raster/test/regress/rt_gdalwarp.sql      | 312 +++++++++++++++----------------
 raster/test/regress/rt_gdalwarp_expected |  25 ---
 2 files changed, 156 insertions(+), 181 deletions(-)
hooks/post-receive
