[postgis-tickets] [PostGIS] #4753: make installcheck against Pg13 fails
PostGIS trac at osgeo.org
Wed Sep 9 12:25:22 PDT 2020
 Reporter:  pramsey  |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.1.0
Component:  postgis  |    Version:  master
 Keywords:           |
 Upgrade path: unpackaged --> 3.1.0dev!
 PATH is /opt/pgsql/13/bin:/opt/pgsql/13/bin:/Users/pramsey/google-cloud-
 sdk/bin:/Users/pramsey/.cargo/bin:/Library/Frameworks/Python.framework/Versions/3.6/bin:/opt/pgsql/13/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/go/bin:/usr/local/go/bin:/Users/pramsey/Code/go/bin:/opt/local/bin:/opt/vagrant/bin
 Checking for shp2pgsql ... found
 Checking for pgsql2shp ... found
 TMPDIR is /tmp/pgis_reg
 Creating database 'postgis_reg'
 Loading unpackaged components from /Users/pramsey/Code/postgis-
 git/regress/00-regress-install/share/contrib/postgis
 Loading PostGIS into 'postgis_reg'
   Upgrading from postgis 3.1.0dev
 Upgrading PostGIS in 'postgis_reg' using: SELECT
 postgis_extensions_upgrade()
  failed (Error encountered altering EXTENSION POSTGIS:
 /tmp/pgis_reg/regress_log)
 Died at ../run_test.pl line 1646.
 make[3]: *** [check] Error 1
 Contents of /tmp/pgis_reg/regress_log
 NOTICE:  Packaging extension postgis
 ERROR:  CREATE EXTENSION ... FROM is no longer supported
 LINE 1: CREATE EXTENSION postgis FROM unpackaged;
 QUERY:  CREATE EXTENSION postgis FROM unpackaged;
 CONTEXT:  PL/pgSQL function postgis_extensions_upgrade() line 57 at
 EXECUTE
 If the upgrade path in Pg13 no longer involved unpackaged upgrade we
 should take this test out. If this is still a problem in general (upgrade
 on pg13) it seems like we have a big blocker.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4753>
