[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-65-gc97b84f
Fri Sep 11 01:54:54 PDT 2020
the project "PostGIS".
       via  c97b84fb39976897dc1ef621eab5cc6dc1187efe (commit)
      from  a15f8921b434454f9264eb4de0dbe12ff79a0711 (commit)
revisions in full, below.
commit c97b84fb39976897dc1ef621eab5cc6dc1187efe
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Aug 24 22:40:32 2020 +0200
    Expose fixed-precision overlay functions
    Adds an optional gridSize argument to:
      - ST_Intersection
      - ST_Difference
      - ST_SymDifference
      - ST_Union (including aggregate)
      - ST_UnaryUnion
      - ST_Subdivide
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 205a872..024ab31 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1255,6 +1255,7 @@ GEOMETRYCOLLECTION Z (POLYGON Z ((14 14 10,20 10 150,34 6 25,14 14 10))
             <funcdef>geometry <function>ST_Difference</function></funcdef>
             <paramdef><type>geometry </type> <parameter>geomA</parameter></paramdef>
             <paramdef><type>geometry </type> <parameter>geomB</parameter></paramdef>
+            <paramdef choice="opt"><type>float8 </type> <parameter>gridSize</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -1267,8 +1268,16 @@ GEOMETRYCOLLECTION Z (POLYGON Z ((14 14 10,20 10 150,34 6 25,14 14 10))
             then an empty geometry collection is returned.</para>
         <note><para>Order matters. B - A will always return a portion of B</para></note>
+            <para>
+If a gridSize argument is provided, the inputs are
+snapped to a grid of the given size and all intersections are computed
+on that same grid. This method requires GEOS-3.9.0 or higher.
+            </para>
         <para>Performed by the GEOS module</para>
+        <para>Enhanced: 3.1.0 accept a gridSize parameter.</para>
         <para>&sfs_compliant; s2.1.1.3</para>
         <para>&sqlmm_compliant; SQL-MM 3: 5.1.20</para>
         <para>&Z_support; However it seems to only consider x y when
@@ -1631,6 +1640,10 @@ Returns a geometry that represents the shared portion of geomA and geomB.
                         <type>geometry</type>
                     </paramdef>
+                        <type>float8</type>
+                        <parameter>gridSize</parameter>
+                    </paramdef>
                 </funcprototype>
                 <funcprototype>
                     <funcdef>geography <function>ST_Intersection</function></funcdef>
@@ -1658,6 +1671,12 @@ Returns a geometry that represents the shared portion of geomA and geomB.
             <para>ST_Intersection in conjunction with ST_Intersects is very useful for clipping geometries such as in bounding box, buffer, region
                 queries where you only want to return that portion of a geometry that sits in a country or region of interest.</para>
+            <para>
+            </para>
             <note><para>Geography: For geography this is really a thin wrapper around the geometry implementation. It first determines the best SRID that
                     fits the bounding box of the 2 geography objects (if geography objects are within one half zone UTM but not same UTM will pick one of those) (favoring UTM or Lambert Azimuthal Equal Area (LAEA) north/south pole, and falling back on mercator in worst case scenario)  and then intersection in that best fit planar spatial ref and retransforms back to WGS84 geography.</para></note>
@@ -1669,6 +1688,7 @@ Returns a geometry that represents the shared portion of geomA and geomB.
           <para>Availability: 1.5 support for geography data type was introduced.</para>
             <para>Changed: 3.0.0 does not depend on SFCGAL.</para>
+            <para>Changed: 3.1.0 added gridSize argument.</para>
           <para>&sqlmm_compliant; SQL-MM 3: 5.1.18</para>
@@ -3380,6 +3400,7 @@ GEOMETRYCOLLECTION(
             <funcdef>geometry <function>ST_SymDifference</function></funcdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -3392,7 +3413,16 @@ GEOMETRYCOLLECTION(
             ST_SymDifference(A,B) = ST_SymDifference(B,A). One can think of this as ST_Union(geomA,geomB) - ST_Intersection(A,B).
             </para>
+            <para>
+            </para>
         <para>&sqlmm_compliant; SQL-MM 3: 5.1.21</para>
@@ -3482,6 +3512,7 @@ MULTILINESTRING((1 3 2.75,1 4 2),(1 1 3,1 2 2.25))
                 <funcdef>setof geometry <function>ST_Subdivide</function></funcdef>
                 <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
                 <paramdef><type>integer</type> <parameter>max_vertices=256</parameter></paramdef>
+                <paramdef choice="opt"><type>float8</type> <parameter>gridSize</parameter></paramdef>
             </funcprototype>
         </funcsynopsis>
     </refsynopsisdiv>
@@ -3494,12 +3525,13 @@ MULTILINESTRING((1 3 2.75,1 4 2),(1 1 3,1 2 2.25))
             Point-in-polygon and other overlay operations are normally faster for indexed subdivided dataset:
             "miss" cases are faster to check as boxes for all parts typically cover smaller area than original geometry box,
             "hit" cases are faster because recheck operates on less points.
-            Uses the same envelope clipping as <code>ST_ClipByBox2D</code>.
             <code>max_vertices</code> must be 5 or more, as 5 points are needed to represent a closed box.
+            <code>gridSize</code> can be specified to have clipping work in fixed-precision space (requires GEOS-3.9.0+).
         </para>
         <para>Performed by the GEOS module.</para>
         <para>Availability: 2.2.0</para>
         <para>Enhanced: 2.5.0 reuses existing points on polygon split, vertex count is lowered from 8 to 5.</para>
       </refsection>
       <refsection>
@@ -3601,6 +3633,12 @@ LINESTRING(44.7994523421035 82.5156766227011,85 85)</screen>
       </funcprototype>
       <funcprototype>
         <funcdef>geometry <function>ST_Union</function></funcdef>
+        <paramdef><type>geometry</type> <parameter>g1</parameter></paramdef>
+        <paramdef><type>geometry</type> <parameter>g2</parameter></paramdef>
+        <paramdef><type>float8</type> <parameter>gridSize</parameter></paramdef>
+      </funcprototype>
+      <funcprototype>
+        <funcdef>geometry <function>ST_Union</function></funcdef>
         <paramdef><type>geometry[]</type> <parameter>g1_array</parameter></paramdef>
       </funcprototype>
     </funcsynopsis>
@@ -3622,6 +3660,11 @@ LINESTRING(44.7994523421035 82.5156766227011,85 85)</screen>
         input geometries. Output type can be a MULTI*, NON-MULTI or
         GEOMETRYCOLLECTION. If any are NULL, then NULL is returned.</para>
+    <para>
+        For non-aggregate version, <code>gridSize</code> can be specified
+        to work in fixed-precision space (requires GEOS-3.9.0+).
+    </para>
     <note><para>ST_Collect and ST_Union are often interchangeable.
         ST_Union is in general orders of magnitude slower than ST_Collect
         because it tries to dissolve boundaries and reorder geometries to ensure that a constructed Multi* doesn't
@@ -3636,6 +3679,7 @@ LINESTRING(44.7994523421035 82.5156766227011,85 85)</screen>
         word.</para>
     <para>Availability: 1.4.0 - ST_Union was enhanced. ST_Union(geomarray) was introduced and also faster aggregate collection in PostgreSQL.</para>
     <note><para>Aggregate version is not explicitly defined in OGC SPEC.</para></note>
@@ -3732,6 +3776,7 @@ MULTILINESTRING((3 4,4 5),(1 2,3 4))
           <funcprototype>
             <funcdef>geometry <function>ST_UnaryUnion</function></funcdef>
             <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
@@ -3758,9 +3803,16 @@ MULTILINESTRING((3 4,4 5),(1 2,3 4))
         balance between ST_Union and ST_MemUnion.
         </para>
+        <para>
+        </para>
         <para>&Z_support;</para>
         <para>Availability: 2.0.0</para>
       </refsection>
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 59a94ce..f44588f 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2364,15 +2364,21 @@ LWGEOM* lwgeom_geos_noop(const LWGEOM *geom) ;
 LWGEOM *lwgeom_normalize(const LWGEOM *geom);
 LWGEOM *lwgeom_intersection(const LWGEOM *geom1, const LWGEOM *geom2);
+LWGEOM *lwgeom_intersection_prec(const LWGEOM *geom1, const LWGEOM *geom2, double gridSize);
 LWGEOM *lwgeom_difference(const LWGEOM *geom1, const LWGEOM *geom2);
+LWGEOM *lwgeom_difference_prec(const LWGEOM *geom1, const LWGEOM *geom2, double gridSize);
 LWGEOM *lwgeom_symdifference(const LWGEOM* geom1, const LWGEOM* geom2);
+LWGEOM *lwgeom_symdifference_prec(const LWGEOM* geom1, const LWGEOM* geom2, double gridSize);
 LWGEOM *lwgeom_pointonsurface(const LWGEOM* geom);
 LWGEOM *lwgeom_centroid(const LWGEOM* geom);
 LWGEOM *lwgeom_union(const LWGEOM *geom1, const LWGEOM *geom2);
+LWGEOM *lwgeom_union_prec(const LWGEOM *geom1, const LWGEOM *geom2, double gridSize);
 LWGEOM *lwgeom_linemerge(const LWGEOM *geom1);
 LWGEOM *lwgeom_unaryunion(const LWGEOM *geom1);
+LWGEOM *lwgeom_unaryunion_prec(const LWGEOM *geom1, double gridSize);
 LWGEOM *lwgeom_clip_by_rect(const LWGEOM *geom1, double x0, double y0, double x1, double y1);
 LWCOLLECTION *lwgeom_subdivide(const LWGEOM *geom, uint32_t maxvertices);
+LWCOLLECTION *lwgeom_subdivide_prec(const LWGEOM *geom, uint32_t maxvertices, double gridSize);
  * Snap vertices and segments of a geometry to another using a given tolerance.
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index d8ee087..1ca1bd5 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -2262,14 +2262,16 @@ static void lwgeom_subdivide_recursive(const LWGEOM *geom,
 				       uint8_t dimension,
 				       uint32_t depth,
-				       LWCOLLECTION *col);
+				       LWCOLLECTION *col,
+				       double gridSize);
 static void
 			   uint8_t dimension,
 			   uint32_t depth,
+			   double gridSize)
 	const uint32_t maxdepth = 50;
@@ -2317,7 +2319,7 @@ lwgeom_subdivide_recursive(const LWGEOM *geom,
 		/* Don't increment depth yet, since we aren't actually
 		 * subdividing geometries yet */
 		for (uint32_t i = 0; i < incol->ngeoms; i++ )
-			lwgeom_subdivide_recursive(incol->geoms[i], dimension, maxvertices, depth, col);
+			lwgeom_subdivide_recursive(incol->geoms[i], dimension, maxvertices, depth, col, gridSize);
 		return;
@@ -2421,31 +2423,31 @@ lwgeom_subdivide_recursive(const LWGEOM *geom,
 		LWGEOM *subbox = (LWGEOM *)lwpoly_construct_envelope(
 		    geom->srid, subbox1.xmin, subbox1.ymin, subbox1.xmax, subbox1.ymax);
-		LWGEOM *clipped = lwgeom_intersection(geom, subbox);
+		LWGEOM *clipped = lwgeom_intersection_prec(geom, subbox, gridSize);
 		lwgeom_simplify_in_place(clipped, 0.0, LW_TRUE);
 		lwgeom_free(subbox);
 		if (clipped && !lwgeom_is_empty(clipped))
-			lwgeom_subdivide_recursive(clipped, dimension, maxvertices, depth, col);
+			lwgeom_subdivide_recursive(clipped, dimension, maxvertices, depth, col, gridSize);
 			lwgeom_free(clipped);
 		    geom->srid, subbox2.xmin, subbox2.ymin, subbox2.xmax, subbox2.ymax);
 LWCOLLECTION *
-lwgeom_subdivide(const LWGEOM *geom, uint32_t maxvertices)
+lwgeom_subdivide_prec(const LWGEOM *geom, uint32_t maxvertices, double gridSize)
 	static uint32_t startdepth = 0;
 	static uint32_t minmaxvertices = 5;
@@ -2462,11 +2464,19 @@ lwgeom_subdivide(const LWGEOM *geom, uint32_t maxvertices)
 		lwerror("%s: cannot subdivide to fewer than %d vertices per output", __func__, minmaxvertices);
-	lwgeom_subdivide_recursive(geom, lwgeom_dimension(geom), maxvertices, startdepth, col);
+	lwgeom_subdivide_recursive(geom, lwgeom_dimension(geom), maxvertices, startdepth, col, gridSize);
 	lwgeom_set_srid((LWGEOM*)col, geom->srid);
 	return col;
+LWCOLLECTION *
+lwgeom_subdivide(const LWGEOM *geom, uint32_t maxvertices)
+	return lwgeom_subdivide_prec(geom, maxvertices, -1);
 int
 lwgeom_is_trajectory(const LWGEOM *geom)
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index f735f70..1ca3f4f 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -18,7 +18,7 @@
- * Copyright 2011-2014 Sandro Santilli <strk at kbt.io>
+ * Copyright 2011-2020 Sandro Santilli <strk at kbt.io>
  * Copyright 2015-2018 Daniel Baston <dbaston at gmail.com>
  * Copyright 2017-2018 Darafei Praliaskouski <me at komzpa.net>
@@ -673,7 +673,13 @@ lwgeom_normalize(const LWGEOM* geom)
 LWGEOM*
-lwgeom_intersection(const LWGEOM* geom1, const LWGEOM* geom2)
+lwgeom_intersection(const LWGEOM* g1, const LWGEOM* g2)
+	return lwgeom_intersection_prec(g1, g2, -1.0);
+LWGEOM*
+lwgeom_intersection_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
 	LWGEOM* result;
 	int32_t srid = RESULT_SRID(geom1, geom2);
@@ -695,7 +701,19 @@ lwgeom_intersection(const LWGEOM* geom1, const LWGEOM* geom2)
 	if (!(g1 = LWGEOM2GEOS(geom1, AUTOFIX))) GEOS_FAIL();
 	if (!(g2 = LWGEOM2GEOS(geom2, AUTOFIX))) GEOS_FREE_AND_FAIL(g1);
-	g3 = GEOSIntersection(g1, g2);
+	if ( prec >= 0) {
+#if POSTGIS_GEOS_VERSION < 39
+		lwerror("Fixed-precision intersection requires GEOS-3.9 or higher");
+		GEOS_FREE_AND_FAIL(g1, g2);
+		return NULL;
+#else
+		g3 = GEOSIntersectionPrec(g1, g2, prec);
+#endif
+	else
+		g3 = GEOSIntersection(g1, g2);
 	if (!g3) GEOS_FREE_AND_FAIL(g1);
 	GEOSSetSRID(g3, srid);
@@ -740,6 +758,12 @@ lwgeom_linemerge(const LWGEOM* geom)
 LWGEOM*
 lwgeom_unaryunion(const LWGEOM* geom)
+	return lwgeom_unaryunion_prec(geom, -1.0);
+LWGEOM*
+lwgeom_unaryunion_prec(const LWGEOM* geom, double prec)
 	LWGEOM* result;
 	int32_t srid = RESULT_SRID(geom);
 	uint8_t is3d = FLAGS_GET_Z(geom->flags);
@@ -755,7 +779,19 @@ lwgeom_unaryunion(const LWGEOM* geom)
 	if (!(g1 = LWGEOM2GEOS(geom, AUTOFIX))) GEOS_FAIL();
-	g3 = GEOSUnaryUnion(g1);
+	if ( prec >= 0) {
+		lwerror("Fixed-precision union requires GEOS-3.9 or higher");
+		GEOS_FREE_AND_FAIL(g1);
+		return NULL;
+#else
+		g3 = GEOSUnaryUnionPrec(g1, prec);
+#endif
+	else
+		g3 = GEOSUnaryUnion(g1);
@@ -771,6 +807,12 @@ lwgeom_unaryunion(const LWGEOM* geom)
 LWGEOM*
 lwgeom_difference(const LWGEOM* geom1, const LWGEOM* geom2)
+	return lwgeom_difference_prec(geom1, geom2, -1.0);
+LWGEOM*
+lwgeom_difference_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
 	LWGEOM* result;
 	uint8_t is3d = (FLAGS_GET_Z(geom1->flags) || FLAGS_GET_Z(geom2->flags));
@@ -789,7 +831,19 @@ lwgeom_difference(const LWGEOM* geom1, const LWGEOM* geom2)
-	g3 = GEOSDifference(g1, g2);
+	if ( prec >= 0) {
+		lwerror("Fixed-precision difference requires GEOS-3.9 or higher");
+		return NULL;
+#else
+		g3 = GEOSDifferencePrec(g1, g2, prec);
+#endif
+	else
+		g3 = GEOSDifference(g1, g2);
 	if (!g3) GEOS_FREE_AND_FAIL(g1, g2);
@@ -804,6 +858,12 @@ lwgeom_difference(const LWGEOM* geom1, const LWGEOM* geom2)
 LWGEOM*
+	return lwgeom_symdifference_prec(geom1, geom2, -1.0);
+LWGEOM*
+lwgeom_symdifference_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
 	LWGEOM* result;
@@ -822,7 +882,19 @@ lwgeom_symdifference(const LWGEOM* geom1, const LWGEOM* geom2)
-	g3 = GEOSSymDifference(g1, g2);
+	if ( prec >= 0) {
+		return NULL;
+#else
+		g3 = GEOSSymDifferencePrec(g1, g2, prec);
+#endif
+	else
+		g3 = GEOSSymDifference(g1, g2);
@@ -901,7 +973,13 @@ lwgeom_pointonsurface(const LWGEOM *geom)
 LWGEOM*
-lwgeom_union(const LWGEOM* geom1, const LWGEOM* geom2)
+lwgeom_union(const LWGEOM* g1, const LWGEOM* g2)
+	return lwgeom_union_prec(g1, g2, -1.0);
+LWGEOM*
+lwgeom_union_prec(const LWGEOM* geom1, const LWGEOM* geom2, double gridSize)
 	LWGEOM* result;
@@ -921,7 +999,19 @@ lwgeom_union(const LWGEOM* geom1, const LWGEOM* geom2)
-	g3 = GEOSUnion(g1, g2);
+	if ( gridSize >= 0) {
+		return NULL;
+#else
+		g3 = GEOSUnionPrec(g1, g2, gridSize);
+#endif
+	else
+		g3 = GEOSUnion(g1, g2);
diff --git a/postgis/legacy.sql.in b/postgis/legacy.sql.in
index d750541..c90452a 100644
--- a/postgis/legacy.sql.in
+++ b/postgis/legacy.sql.in
@@ -1806,13 +1806,13 @@ CREATE OR REPLACE FUNCTION StartPoint(geometry)
 -- Deprecation in 1.2.3
 CREATE OR REPLACE FUNCTION symdifference(geometry,geometry)
 	RETURNS geometry
-	AS 'MODULE_PATHNAME','symdifference'
+	AS 'MODULE_PATHNAME','ST_SymDifference'
 	LANGUAGE 'c' IMMUTABLE STRICT;
 CREATE OR REPLACE FUNCTION symmetricdifference(geometry,geometry)
 	RETURNS geometry
diff --git a/postgis/lwgeom_accum.c b/postgis/lwgeom_accum.c
index eb96fe4..4b4a688 100644
--- a/postgis/lwgeom_accum.c
+++ b/postgis/lwgeom_accum.c
@@ -72,6 +72,7 @@ pgis_geometry_accum_transfn(PG_FUNCTION_ARGS)
 	LWGEOM *geom = NULL;
 	GSERIALIZED *gser = NULL;
 	Datum argType = get_fn_expr_argtype(fcinfo->flinfo, 1);
+	double gridSize = -1.0;
 	if (argType == InvalidOid)
 		ereport(ERROR,
@@ -92,6 +93,7 @@ pgis_geometry_accum_transfn(PG_FUNCTION_ARGS)
 		state = MemoryContextAlloc(aggcontext, sizeof(CollectionBuildState));
 		state->geoms = NULL;
 		state->geomOid = argType;
+		state->gridSize = gridSize;
 		for (int i = 0; i < n; i++)
@@ -110,6 +112,13 @@ pgis_geometry_accum_transfn(PG_FUNCTION_ARGS)
 	if (!PG_ARGISNULL(1))
 		gser = PG_GETARG_GSERIALIZED_P(1);
+	if (PG_NARGS()>2 && !PG_ARGISNULL(2))
+		gridSize = PG_GETARG_FLOAT8(2);
+		/*lwnotice("Passed gridSize %g", gridSize);*/
+		if ( gridSize > state->gridSize ) state->gridSize = gridSize;
 	/* Take a copy of the geometry into the aggregate context */
 	old = MemoryContextSwitchTo(aggcontext);
 	if (gser)
diff --git a/postgis/lwgeom_accum.h b/postgis/lwgeom_accum.h
index c500d67..e1da21b 100644
--- a/postgis/lwgeom_accum.h
+++ b/postgis/lwgeom_accum.h
@@ -38,6 +38,7 @@ typedef struct CollectionBuildState
 	List *geoms;  /* collected geometries */
 	Datum data[CollectionBuildStateDataSize];
 	Oid geomOid;
+	float8 gridSize;
 } CollectionBuildState;
diff --git a/postgis/lwgeom_dump.c b/postgis/lwgeom_dump.c
index 7d6ae64..e096bf3 100644
--- a/postgis/lwgeom_dump.c
+++ b/postgis/lwgeom_dump.c
@@ -347,6 +347,7 @@ Datum ST_Subdivide(PG_FUNCTION_ARGS)
 		LWCOLLECTION *col;
 		/* default to maxvertices < page size */
 		int maxvertices = 128;
+		double gridSize = -1;
 		/* create a function context for cross-call persistence */
 		funcctx = SRF_FIRSTCALL_INIT();
@@ -369,9 +370,15 @@ Datum ST_Subdivide(PG_FUNCTION_ARGS)
 			maxvertices = PG_GETARG_INT32(1);
+		* Get the gridSize value
+		if ( PG_NARGS() > 2 && ! PG_ARGISNULL(2) )
 		* Compute the subdivision of the geometry
-		col = lwgeom_subdivide(geom, maxvertices);
+		col = lwgeom_subdivide_prec(geom, maxvertices, gridSize);
 		if ( ! col )
 			SRF_RETURN_DONE(funcctx);
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index e7fd51a..ed5d27e 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -83,7 +83,7 @@ Datum convexhull(PG_FUNCTION_ARGS);
 Datum topologypreservesimplify(PG_FUNCTION_ARGS);
 Datum ST_Difference(PG_FUNCTION_ARGS);
 Datum boundary(PG_FUNCTION_ARGS);
-Datum symdifference(PG_FUNCTION_ARGS);
+Datum ST_SymDifference(PG_FUNCTION_ARGS);
 Datum ST_Union(PG_FUNCTION_ARGS);
 Datum issimple(PG_FUNCTION_ARGS);
 Datum isring(PG_FUNCTION_ARGS);
@@ -683,23 +683,13 @@ Datum pgis_geometry_union_finalfn(PG_FUNCTION_ARGS)
 	if (ngeoms > 0)
-		GEOSGeometry *g = NULL;
-		GEOSGeometry *g_union = NULL;
 		LWCOLLECTION* col = lwcollection_construct(COLLECTIONTYPE, srid, NULL, ngeoms, geoms);
-		initGEOS(lwpgnotice, lwgeom_geos_error);
-		g = LWGEOM2GEOS((LWGEOM*)col, LW_FALSE);
-		if (!g)
-			HANDLE_GEOS_ERROR("Could not create GEOS COLLECTION from geometry array");
-		g_union = GEOSUnaryUnion(g);
-		GEOSGeom_destroy(g);
-		if (!g_union)
-			HANDLE_GEOS_ERROR("GEOSUnaryUnion");
-		GEOSSetSRID(g_union, srid);
-		gser_out = GEOS2POSTGIS(g_union, has_z);
-		GEOSGeom_destroy(g_union);
+		LWGEOM *out = lwgeom_unaryunion_prec(lwcollection_as_lwgeom(col), state->gridSize);
+		if ( ! out )
+			lwcollection_free(col);
+		gser_out = geometry_serialize(out);
 	/* No real geometries in our array, any empties? */
 	else
@@ -737,12 +727,15 @@ Datum ST_UnaryUnion(PG_FUNCTION_ARGS)
 	GSERIALIZED *geom1;
 	GSERIALIZED *result;
 	LWGEOM *lwgeom1, *lwresult ;
+	double prec = -1;
 	geom1 = PG_GETARG_GSERIALIZED_P(0);
+	if (PG_NARGS() > 1 && ! PG_ARGISNULL(1))
+		prec = PG_GETARG_FLOAT8(1);
 	lwgeom1 = lwgeom_from_gserialized(geom1) ;
-	lwresult = lwgeom_unaryunion(lwgeom1);
+	lwresult = lwgeom_unaryunion_prec(lwgeom1, prec);
 	result = geometry_serialize(lwresult) ;
 	lwgeom_free(lwgeom1) ;
@@ -760,14 +753,17 @@ Datum ST_Union(PG_FUNCTION_ARGS)
 	GSERIALIZED *geom2;
 	LWGEOM *lwgeom1, *lwgeom2, *lwresult;
 	geom2 = PG_GETARG_GSERIALIZED_P(1);
+	if (PG_NARGS() > 2 && ! PG_ARGISNULL(2))
 	lwgeom1 = lwgeom_from_gserialized(geom1);
 	lwgeom2 = lwgeom_from_gserialized(geom2);
-	lwresult = lwgeom_union(lwgeom1, lwgeom2);
+	lwresult = lwgeom_union_prec(lwgeom1, lwgeom2, gridSize);
 	result = geometry_serialize(lwresult);
 	lwgeom_free(lwgeom1);
@@ -780,26 +776,40 @@ Datum ST_Union(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(result);
+/* This is retained for backward ABI compatibility
+ * with PostGIS < 3.1.0 */
+PG_FUNCTION_INFO_V1(symdifference);
+Datum symdifference(PG_FUNCTION_ARGS)
+  PG_RETURN_DATUM(DirectFunctionCall2(
+     ST_SymDifference,
+     PG_GETARG_DATUM(0), PG_GETARG_DATUM(1)
  *  @example symdifference {@link #symdifference} - SELECT ST_SymDifference(
  *      'POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))',
  *      'POLYGON((5 5, 15 5, 15 7, 5 7, 5 5))');
-PG_FUNCTION_INFO_V1(symdifference);
+PG_FUNCTION_INFO_V1(ST_SymDifference);
 	GSERIALIZED *geom1;
 	GSERIALIZED *geom2;
 	LWGEOM *lwgeom1, *lwgeom2, *lwresult ;
+	double prec = -1;
+		prec = PG_GETARG_FLOAT8(2);
 	lwgeom2 = lwgeom_from_gserialized(geom2) ;
-	lwresult = lwgeom_symdifference(lwgeom1, lwgeom2) ;
+	lwresult = lwgeom_symdifference_prec(lwgeom1, lwgeom2, prec);
@@ -1406,14 +1416,17 @@ Datum ST_Intersection(PG_FUNCTION_ARGS)
 	GSERIALIZED *geom2;
+	double prec = -1;
-	lwresult = lwgeom_intersection(lwgeom1, lwgeom2);
+	lwresult = lwgeom_intersection_prec(lwgeom1, lwgeom2, prec);
@@ -1433,14 +1446,17 @@ Datum ST_Difference(PG_FUNCTION_ARGS)
 	GSERIALIZED *geom2;
+	double prec = -1;
-	lwresult = lwgeom_difference(lwgeom1, lwgeom2);
+	lwresult = lwgeom_difference_prec(lwgeom1, lwgeom2, prec);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 8fcd15f..9b19f05 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3422,7 +3422,8 @@ CREATE OR REPLACE FUNCTION ST_IsValidTrajectory(geometry)
 -- GEOS
-CREATE OR REPLACE FUNCTION ST_Intersection(geom1 geometry, geom2 geometry)
+-- Changed: 3.1.0 to add gridSize default argument
+CREATE OR REPLACE FUNCTION ST_Intersection(geom1 geometry, geom2 geometry, gridSize float8 DEFAULT -1)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_Intersection'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
@@ -3563,8 +3564,9 @@ CREATE OR REPLACE FUNCTION ST_MaximumInscribedCircle(geometry, OUT center geomet
 	_COST_HIGH;
--- PostGIS equivalent function: difference(geom1 geometry, geom2 geometry)
-CREATE OR REPLACE FUNCTION ST_Difference(geom1 geometry, geom2 geometry)
+-- PostGIS equivalent function: ST_difference(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION ST_Difference(geom1 geometry, geom2 geometry, gridSize float8 DEFAULT -1.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_Difference'
@@ -3585,28 +3587,35 @@ CREATE OR REPLACE FUNCTION ST_Points(geometry)
 	_COST_MEDIUM;
 -- PostGIS equivalent function: symdifference(geom1 geometry, geom2 geometry)
-CREATE OR REPLACE FUNCTION ST_SymDifference(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION ST_SymDifference(geom1 geometry, geom2 geometry, gridSize float8 DEFAULT -1.0)
 	RETURNS geometry
 	_COST_HIGH;
 -- Availability: 1.2.2
 CREATE OR REPLACE FUNCTION ST_SymmetricDifference(geom1 geometry, geom2 geometry)
 	RETURNS geometry
+	AS 'SELECT ST_SymDifference(geom1, geom2, -1.0);'
+	LANGUAGE 'sql';
+CREATE OR REPLACE FUNCTION ST_Union(geom1 geometry, geom2 geometry)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME','ST_Union'
 	_COST_HIGH;
--- PostGIS equivalent function: GeomUnion(geom1 geometry, geom2 geometry)
-CREATE OR REPLACE FUNCTION ST_Union(geom1 geometry, geom2 geometry)
+-- Availability: 3.1.0
+CREATE OR REPLACE FUNCTION ST_Union(geom1 geometry, geom2 geometry, gridSize float8)
 	RETURNS geometry
 	_COST_HIGH;
 -- Availability: 2.0.0
-CREATE OR REPLACE FUNCTION ST_UnaryUnion(geometry)
+CREATE OR REPLACE FUNCTION ST_UnaryUnion(geometry, gridSize float8 DEFAULT -1.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_UnaryUnion'
@@ -3633,7 +3642,8 @@ CREATE OR REPLACE FUNCTION ST_ClipByBox2d(geom geometry, box box2d)
 	_COST_MEDIUM;
 -- Availability: 2.2.0
-CREATE OR REPLACE FUNCTION ST_Subdivide(geom geometry, maxvertices integer DEFAULT 256)
+CREATE OR REPLACE FUNCTION ST_Subdivide(geom geometry, maxvertices integer DEFAULT 256, gridSize float8 DEFAULT -1.0)
 	RETURNS setof geometry
 	AS 'MODULE_PATHNAME', 'ST_Subdivide'
@@ -4006,6 +4016,15 @@ CREATE AGGREGATE ST_Union (geometry) (
 	finalfunc = pgis_geometry_union_finalfn
+CREATE AGGREGATE ST_Union (geometry, gridSize float8) (
+	sfunc = pgis_geometry_accum_transfn,
+	stype = internal,
+	parallel = safe,
+	finalfunc = pgis_geometry_union_finalfn
 -- Changed: 2.4.0: marked parallel safe
 -- Changed: 2.5.0 use 'internal' stype
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index 02f8692..a7b929f 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -4,7 +4,7 @@
 -- PostGIS - Spatial Types for PostgreSQL
 -- http://postgis.net
--- Copyright (C) 2011-2012 Sandro Santilli <strk at kbt.io>
+-- Copyright (C) 2011-2020 Sandro Santilli <strk at kbt.io>
 -- Copyright (C) 2010-2012 Regina Obe <lr at pcorp.us>
 -- Copyright (C) 2009      Paul Ramsey <pramsey at cleverelephant.ca>
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index fd104bc..dcd69aa 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -217,6 +217,12 @@ DROP FUNCTION IF EXISTS st_buffer(geometry, double precision); -- Does not confl
 DROP FUNCTION IF EXISTS ST_CurveToLine(geometry, integer); -- Does not conflict
 DROP FUNCTION IF EXISTS ST_CurveToLine(geometry); -- Does not conflict
+DROP FUNCTION IF EXISTS st_intersection(geometry, geometry); -- replaced in 3.1.0 by 3 args version
+DROP FUNCTION IF EXISTS st_subdivide(geometry, integer); -- replaced in 3.1.0 by 3 args version
+DROP FUNCTION IF EXISTS st_difference(geometry, geometry); -- replaced in 3.1.0 by 3 args version
+DROP FUNCTION IF EXISTS st_symdifference(geometry, geometry); -- replaced in 3.1.0 by 3 args version
+DROP FUNCTION IF EXISTS st_unaryunion(geometry); -- replaced in 3.1.0 by 3 args version
 -- geometry_columns changed parameter types so we verify if it needs to be dropped
 -- We check the catalog to see if the view (geometry_columns) has a column
 -- with name `f_table_schema` and type `character varying(256)` as it was
diff --git a/regress/core/subdivide_expected b/regress/core/subdivide_expected
index bf58e60..10fc0e5 100644
--- a/regress/core/subdivide_expected
+++ b/regress/core/subdivide_expected
@@ -1,7 +1,7 @@
 1|t|5|10
 2|t|4|8
 3|t|10|10
-ERROR:  lwgeom_subdivide: cannot subdivide to fewer than 5 vertices per output
+ERROR:  lwgeom_subdivide_prec: cannot subdivide to fewer than 5 vertices per output
 #3522|POINT(1 1)
 #3744|1600000000000000
 4|29321996468.6|29321996468.6|1857|256
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index a329953..9bbed01 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -327,10 +327,10 @@ NOTICE:  Too few points in geometry component at or near point 0 0
 #4011|ST_MultiLineString|MULTILINESTRING EMPTY|t|t
 #4011|ST_GeometryCollection|MULTILINESTRING((0 0,0 0))|f|f
 #4025|
-ERROR:  lwgeom_intersection: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
-ERROR:  lwgeom_difference: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
-ERROR:  lwgeom_symdifference: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
-ERROR:  lwgeom_union: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
+ERROR:  lwgeom_intersection_prec: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
+ERROR:  lwgeom_difference_prec: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
+ERROR:  lwgeom_symdifference_prec: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
+ERROR:  lwgeom_union_prec: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
 #4055a|4326
 #4055b|4326
 #4089|LINESTRING Z (1 1 1,3 3 1)
Summary of changes:
 doc/reference_processing.xml       |  54 ++++++++++++++++++-
 liblwgeom/liblwgeom.h.in           |   6 +++
 liblwgeom/lwgeom.c                 |  28 ++++++----
 liblwgeom/lwgeom_geos.c            | 106 ++++++++++++++++++++++++++++++++++---
 postgis/legacy.sql.in              |   4 +-
 postgis/lwgeom_accum.c             |   9 ++++
 postgis/lwgeom_accum.h             |   1 +
 postgis/lwgeom_dump.c              |   9 +++-
 postgis/lwgeom_geos.c              |  64 +++++++++++++---------
 postgis/postgis.sql.in             |  39 ++++++++++----
 postgis/postgis_after_upgrade.sql  |   2 +-
 postgis/postgis_before_upgrade.sql |   6 +++
 regress/core/subdivide_expected    |   2 +-
 regress/core/tickets_expected      |   8 +--
 14 files changed, 277 insertions(+), 61 deletions(-)
hooks/post-receive
