[postgis-tickets] [PostGIS] #4755: ST_Transform of valid polygon can produce invalid polygon
PostGIS trac at osgeo.org
Sun Sep 20 08:33:57 PDT 2020
  Reporter:  rouen    |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.1.0
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:  ST_Transform
Comment (by mdavis):
 This is because there is a very narrow "gore" in the polygon, and due to
 rounding effects the transformation perturbs the coordinates forming the
 gore just enough to introduce a self-intersection.
 One way to remove the self-intersection is to round the geometry to a
 lower precision. `ST_SnapToGrid(transform_geom, 0.0000001)` makes the
 geometry valid in this case.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4755#comment:1>
