[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-69-gf50dcaa
Mon Sep 21 07:20:44 PDT 2020
the project "PostGIS".
       via  f50dcaaaa7a0c77e84076d0543c3c48b3a4d9ad4 (commit)
      from  1e8036c222bf316c7f28a4387f5c8833dff6bd94 (commit)
revisions in full, below.
commit f50dcaaaa7a0c77e84076d0543c3c48b3a4d9ad4
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 21 16:04:04 2020 +0200
    Make topology test less sensible to overlay results order
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 460229a..fc194de 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -10,7 +10,7 @@ SELECT 'max',* from city_data.limits;
 -- Check changes since last saving, save more
-CREATE OR REPLACE FUNCTION check_changes(lbl text, add_id boolean default true)
+CREATE OR REPLACE FUNCTION check_changes(lbl text)
 RETURNS TABLE (o text)
 AS $$
 DECLARE
@@ -18,12 +18,12 @@ DECLARE
   sql text;
 BEGIN
   -- Check effect on nodes
-  sql :=  'SELECT $1 || ''|N|'' ' || CASE WHEN add_id THEN ' || n.node_id || ''|'' ||
+  sql :=  'SELECT $1 || ''|N|'' ||
         COALESCE(n.containing_face::text,'''') || ''|'' ||
-        ST_AsText(ST_SnapToGrid(n.geom, 0.2))::text ' ELSE '' END || ' as xx
+        ST_AsText(n.geom, 2)::text as xx
   	FROM city_data.node n WHERE n.node_id > (
     		SELECT max FROM city_data.limits WHERE what = ''node''::text )
-  		ORDER BY n.node_id';
+  		ORDER BY n.geom';
   FOR rec IN EXECUTE sql USING ( lbl )
   LOOP
@@ -31,15 +31,15 @@ BEGIN
     RETURN NEXT;
   END LOOP;
-  -- Check effect on edges (there should be one split)
+  -- Check effect on edges
   sql := 'WITH node_limits AS ( SELECT max FROM city_data.limits WHERE what = ''node''::text ),
        edge_limits AS ( SELECT max FROM city_data.limits WHERE what = ''edge''::text )
-  SELECT $1 || ''|E|'' ' || CASE WHEN add_id THEN ' || e.edge_id || ''|sn'' || e.start_node || ''|en'' || e.end_node::text ' ELSE '' END || ' AS xx ' ||
+  SELECT $1 || ''|E|'' || ST_AsText(e.geom, 2)::text AS xx ' ||
    ' FROM city_data.edge e, node_limits nl, edge_limits el
    WHERE e.start_node > nl.max
       OR e.end_node > nl.max
       OR e.edge_id > el.max
-  ORDER BY e.edge_id;';
+  ORDER BY e.geom;';
   LOOP
@@ -108,18 +108,18 @@ SELECT check_changes('snap_again');
 --       strk fix as you please leter
 --SELECT 'crossover', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(9 18, 9 20, 21 10, 21 7)') ORDER BY 2;
 SELECT 'crossover', COUNT(*) FROM TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(9 18, 9 20, 21 10, 21 7)') AS t;
-SELECT check_changes('crossover', false);
+SELECT check_changes('crossover');
 -- TODO: Geos 3.8+ gives different results, so just returning the count of edges instead
 --SELECT 'crossover_again', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(9 18, 9 20, 21 10, 21 7)') ORDER BY 2;
 SELECT 'crossover_again', COUNT(*) FROM TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(9 18, 9 20, 21 10, 21 7)') AS t;
-SELECT check_changes('crossover_again', false);
+SELECT check_changes('crossover_again');
 -- Fully containing
 SELECT 'contains', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(14 34, 13 35, 10 35, 9 35, 7 36)') ORDER BY 2;
 -- answers different between 3.8 and older geos so disabling output of ids and geometry
-SELECT check_changes('contains', false);
+SELECT check_changes('contains');
 -- Crossing a node
 SELECT 'nodecross', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(18 37, 22 37)') ORDER BY 2;
@@ -134,7 +134,7 @@ SELECT check_changes('iso_ex_2segs');
 SELECT '#1613.1', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(556267.562954 144887.066638, 556267 144887.4)') ORDER BY 2;
 SELECT check_changes('#1613.1');
 SELECT '#1613.2', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(556250 144887, 556267 144887.07, 556310.04 144887)') ORDER BY 2;
-SELECT check_changes('#1613.2', false);
+SELECT check_changes('#1613.2');
 -- Consistency check
 SELECT * FROM ValidateTopology('city_data');
@@ -240,9 +240,8 @@ SELECT '#1706.1', 'E', TopoGeo_AddLineString('city_data',
  'SRID=4326;LINESTRING(20 10, 10 10, 9 12, 10 20)');
 SELECT check_changes('#1706.1');
-SELECT '#1706.2', 'E*', TopoGeo_addLineString('city_data',
- 'SRID=4326;LINESTRING(10 0, 10 10, 15 10, 20 10)'
-, 4) ORDER BY 3;
+SELECT '#1706.2', count(*) FROM TopoGeo_addLineString('city_data',
+ 'SRID=4326;LINESTRING(10 0, 10 10, 15 10, 20 10)' , 4);
 SELECT check_changes('#1706.2');
@@ -266,7 +265,7 @@ SELECT check_changes('#1714.2');
 -- Cleanups
-DROP FUNCTION check_changes(text,boolean);
+DROP FUNCTION check_changes(text);
 SELECT DropTopology('city_data');
 -- See http://trac.osgeo.org/postgis/ticket/3280
@@ -341,7 +340,7 @@ SELECT 't3371.start', topology.CreateTopology('bug3711', 0, 0, true) > 1;
 SELECT 't3371.L1', topology.TopoGeo_AddLineString('bug3711',
 'LINESTRING (618369 4833784 0.88, 618370 4833784 1.93, 618370 4833780 1.90)'
 ::geometry, 0);
-SELECT 't3371.L2', topology.TopoGeo_AddLineString( 'bug3711',
+SELECT 't3371.L2', count(*) FROM topology.TopoGeo_AddLineString( 'bug3711',
 'LINESTRING (618370 4833780 1.92, 618370 4833784 1.90, 618371 4833780 1.93)'
 ::geometry, 0);
 SELECT 't3371.end', topology.DropTopology('bug3711');
@@ -378,7 +377,7 @@ SELECT 't1855_1.end', topology.DropTopology('bug1855');
 SELECT 't1855_2.start', topology.CreateTopology('bug1855') > 0;
 SELECT 't1855_2.0', topology.topogeo_AddLinestring('bug1855',
   'LINESTRING(0 0, 0 100)');
-SELECT 't1855_2.1', topology.topogeo_AddLinestring('bug1855',
+SELECT 't1855_2.1', count(*) FROM topology.topogeo_AddLinestring('bug1855',
   'LINESTRING(10 51, -100 50, 10 49)', 2);
 SELECT 't1855_2.end', topology.DropTopology('bug1855');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 8f75e7c..c760d95 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -8,171 +8,168 @@ ERROR:  Invalid geometry type (MULTILINESTRING) passed to TopoGeo_AddLinestring,
 ERROR:  Invalid geometry type (POINT) passed to TopoGeo_AddLinestring, expected LINESTRING
 ERROR:  No topology with name "invalid" in topology.topology
 iso_uni|27
-iso_uni|N|23||POINT(36 26)
-iso_uni|N|24||POINT(38 30)
-iso_uni|E|27|sn23|en24
+iso_uni|N||POINT(36 26)
+iso_uni|N||POINT(38 30)
+iso_uni|E|LINESTRING(36 26,38 30)
 iso_f5|28
-iso_f5|N|25||POINT(37 20)
-iso_f5|N|26||POINT(41 16)
-iso_f5|E|28|sn25|en26
+iso_f5|N||POINT(37 20)
+iso_f5|N||POINT(41 16)
+iso_f5|E|LINESTRING(37 20,43 19,41 16)
 iso_ex|27
 iso_ex_tol|27
 noniso_ex|18
 noniso_ex_tol|18
 contained|29
-contained|N|27||POINT(35 8)
-contained|N|28||POINT(35 12)
-contained|E|18|sn10|en27
-contained|E|29|sn27|en28
-contained|E|30|sn28|en13
+contained|N||POINT(35 8)
+contained|N||POINT(35 12)
+contained|E|LINESTRING(35 6,35 8)
+contained|E|LINESTRING(35 8,35 12)
+contained|E|LINESTRING(35 12,35 14)
 overlap|31
 overlap|32
-overlap|N|29||POINT(49 22)
-overlap|N|30||POINT(45 22)
-overlap|E|8|sn18|en30
-overlap|E|31|sn19|en29
-overlap|E|32|sn30|en19
+overlap|N||POINT(45 22)
+overlap|N||POINT(49 22)
+overlap|E|LINESTRING(35 22,45 22)
+overlap|E|LINESTRING(45 22,47 22)
+overlap|E|LINESTRING(47 22,49 22)
 cross|34
 cross|35
-cross|N|31||POINT(49 18)
-cross|N|32||POINT(47 17.6)
-cross|N|33||POINT(44 17)
-cross|E|15|sn12|en32
-cross|E|33|sn32|en19
-cross|E|34|sn31|en32
-cross|E|35|sn32|en33
+cross|N||POINT(44 17)
+cross|N||POINT(47 17.6)
+cross|N||POINT(49 18)
+cross|E|LINESTRING(47 14,47 17.6)
+cross|E|LINESTRING(47 17.6,47 22)
+cross|E|LINESTRING(47 17.6,44 17)
+cross|E|LINESTRING(49 18,47 17.6)
 snap|7
 snap|36
 snap|38
-snap|N|34||POINT(18 22.200000000000003)
-snap|N|35||POINT(22.400000000000002 22)
-snap|N|36||POINT(21.200000000000003 20.400000000000002)
-snap|E|7|sn17|en35
-snap|E|36|sn34|en17
-snap|E|37|sn35|en18
-snap|E|38|sn35|en36
+snap|N||POINT(21.2 20.5)
+snap|N||POINT(22.35 22)
+snap|N||POINT(18 22.2)
+snap|E|LINESTRING(22.35 22,35 22)
+snap|E|LINESTRING(22.35 22,21.2 20.5)
+snap|E|LINESTRING(21 22,22.35 22)
+snap|E|LINESTRING(18 22.2,21 22)
 snap_again|7
 snap_again|36
 snap_again|38
 crossover|4
-crossover|N|
-crossover|N|
-crossover|N|
-crossover|N|
-crossover|N|
-crossover|E|
-crossover|E|
-crossover|E|
-crossover|E|
-crossover|E|
-crossover|E|
-crossover|E|
-crossover|E|
-crossover|E|
-crossover|E|
+crossover|N||POINT(21 10)
+crossover|N||POINT(16.2 14)
+crossover|N||POINT(21 7)
+crossover|N||POINT(9 20)
+crossover|N||POINT(9 18)
+crossover|E|LINESTRING(9 14,16.2 14)
+crossover|E|LINESTRING(21 7,21 10)
+crossover|E|LINESTRING(16.2 14,21 10)
+crossover|E|LINESTRING(16.2 14,21 14)
+crossover|E|LINESTRING(21 10,21 14)
+crossover|E|LINESTRING(21 6,21 7)
+crossover|E|LINESTRING(9 20,9 22)
+crossover|E|LINESTRING(9 20,16.2 14)
+crossover|E|LINESTRING(9 14,9 18)
+crossover|E|LINESTRING(9 18,9 20)
 crossover_again|4
 contains|25
 contains|46
 contains|47
-contains|N|
-contains|N|
-contains|E|
-contains|E|
+contains|N||POINT(7 36)
+contains|N||POINT(14 34)
+contains|E|LINESTRING(14 34,13 35)
+contains|E|LINESTRING(9 35,7 36)
 nodecross|48
 nodecross|49
-nodecross|N|44||POINT(18 37)
-nodecross|N|45||POINT(22 37)
-nodecross|E|48|sn44|en4
-nodecross|E|49|sn4|en45
+nodecross|N||POINT(22 37)
+nodecross|N||POINT(18 37)
+nodecross|E|LINESTRING(20 37,22 37)
+nodecross|E|LINESTRING(18 37,20 37)
 iso_ex_2segs|28
 #1613.1|50
-#1613.1|N|46||POINT(556267.6 144887)
-#1613.1|N|47||POINT(556267 144887.4)
-#1613.1|E|50|sn46|en47
+#1613.1|N||POINT(556267 144887.4)
+#1613.1|N||POINT(556267.56 144887.07)
+#1613.1|E|LINESTRING(556267.56 144887.07,556267 144887.4)
 #1613.2|52
 #1613.2|53
-#1613.2|N|
-#1613.2|N|
-#1613.2|N|
-#1613.2|E|
-#1613.2|E|
-#1613.2|E|
-#1613.2|E|
+#1613.2|N||POINT(556250 144887)
+#1613.2|N||POINT(556267.56 144887.07)
+#1613.2|N||POINT(556310.04 144887)
+#1613.2|E|LINESTRING(556250 144887,556267 144887.07,556267.56 144887.07)
+#1613.2|E|LINESTRING(556267.56 144887.07,556267 144887.4)
+#1613.2|E|LINESTRING(556267.56 144887.07,556267.56 144887.07)
+#1613.2|E|LINESTRING(556267.56 144887.07,556310.04 144887)
 #1631.1|54
-#1631.1|N|51||POINT(556267.6 144887)
-#1631.1|N|52||POINT(556267.6 144888)
-#1631.1|E|54|sn51|en52
+#1631.1|N||POINT(556267.57 144888)
+#1631.1|N||POINT(556267.56 144887.07)
+#1631.1|E|LINESTRING(556267.56 144887.07,556267.57 144888)
 #1631.2|55
 #1631.2|56
-#1631.2|N|53||POINT(556254.6 144886.6)
-#1631.2|N|54||POINT(556267.6 144887)
-#1631.2|E|55|sn53|en51
-#1631.2|E|56|sn51|en54
+#1631.2|N||POINT(556254.67 144886.62)
+#1631.2|N||POINT(556267.66 144887.07)
+#1631.2|E|LINESTRING(556254.67 144886.62,556267.56 144887.07)
+#1631.2|E|LINESTRING(556267.56 144887.07,556267.66 144887.07)
 #1641.1|57
-#1641.1|N|55||POINT(-0.2 0.4)
-#1641.1|N|56||POINT(0.2 0.4)
-#1641.1|E|57|sn55|en56
+#1641.1|N||POINT(0.14 0.41)
+#1641.1|N||POINT(-0.22 0.47)
+#1641.1|E|LINESTRING(-0.22 0.47,0.14 0.41)
 #1641.2|59
 #1641.2|60
-#1641.2|N|57||POINT(0 0.2)
-#1641.2|N|58||POINT(0 0.4)
-#1641.2|N|59||POINT(0 0.4)
-#1641.2|E|57|sn55|en58
-#1641.2|E|58|sn58|en56
-#1641.2|E|59|sn57|en58
-#1641.2|E|60|sn58|en59
+#1641.2|N||POINT(0.1 0.11)
+#1641.2|N||POINT(-0.06 0.47)
+#1641.2|N||POINT(-0.05 0.44)
+#1641.2|E|LINESTRING(0.1 0.11,-0.05 0.44)
+#1641.2|E|LINESTRING(-0.05 0.44,0.14 0.41)
+#1641.2|E|LINESTRING(-0.05 0.44,-0.06 0.47)
+#1641.2|E|LINESTRING(-0.22 0.47,-0.05 0.44)
 #1641.3|61
-#1641.3|N|60||POINT(-0.2 0.4)
-#1641.3|N|61||POINT(0.2 0.4)
-#1641.3|E|61|sn60|en61
+#1641.3|N||POINT(0.14 0.41)
+#1641.3|N||POINT(-0.22 0.47)
+#1641.3|E|LINESTRING(-0.22 0.47,0.14 0.41)
 #1641.4|63
 #1641.4|64
-#1641.4|N|62||POINT(0 0.2)
-#1641.4|N|63||POINT(0 0.4)
-#1641.4|N|64||POINT(0 0.4)
-#1641.4|E|61|sn60|en63
-#1641.4|E|62|sn63|en61
-#1641.4|E|63|sn62|en63
-#1641.4|E|64|sn63|en64
+#1641.4|N||POINT(0.1 0.11)
+#1641.4|N||POINT(-0.06 0.47)
+#1641.4|N||POINT(-0.05 0.44)
+#1641.4|E|LINESTRING(0.1 0.11,-0.05 0.44)
+#1641.4|E|LINESTRING(-0.05 0.44,0.14 0.41)
+#1641.4|E|LINESTRING(-0.05 0.44,-0.06 0.47)
+#1641.4|E|LINESTRING(-0.22 0.47,-0.05 0.44)
 #1650.1
 #1650.265
-#1650.2|N|65||POINT(0 0)
-#1650.2|N|66||POINT(0 1)
-#1650.2|E|65|sn65|en66
+#1650.2|N||POINT(0 0)
+#1650.2|N||POINT(0 1)
+#1650.2|E|LINESTRING(0 0,0 1)
 #1650.3|65
 #1650.3|66
-#1650.3|N|67||POINT(10 0)
-#1650.3|E|66|sn65|en67
+#1650.3|N||POINT(10 0)
+#1650.3|E|LINESTRING(0 0,10 0)
 #1654.1|N|68
-#1654.1|N|68|0|POINT(0 0)
+#1654.1|N|0|POINT(0 0)
 #1654.2|67
 #1654.2|68
-#1654.2|N|69||POINT(-10 1)
-#1654.2|N|70||POINT(10 1)
-#1654.2|E|67|sn69|en68
-#1654.2|E|68|sn68|en70
+#1654.2|N||POINT(10 1)
+#1654.2|N||POINT(-10 1)
+#1654.2|E|LINESTRING(0 0,10 1)
+#1654.2|E|LINESTRING(-10 1,0 0)
 #1706.1|E|69
-#1706.1|N|71||POINT(20 10)
-#1706.1|N|72||POINT(10 20)
-#1706.1|E|69|sn71|en72
-#1706.2|E*|69
-#1706.2|E*|70
-#1706.2|E*|71
-#1706.2|E*|73
-#1706.2|N|73||POINT(10 0)
-#1706.2|N|74||POINT(10 10)
-#1706.2|N|75||POINT(9 12)
-#1706.2|N|76||POINT(15 10)
-#1706.2|E|69|sn71|en76
-#1706.2|E|70|sn74|en75
-#1706.2|E|71|sn73|en74
-#1706.2|E|72|sn75|en72
-#1706.2|E|73|sn76|en74
+#1706.1|N||POINT(20 10)
+#1706.1|N||POINT(10 20)
+#1706.1|E|LINESTRING(20 10,10 10,9 12,10 20)
+#1706.2|4
+#1706.2|N||POINT(10 0)
+#1706.2|N||POINT(9 12)
+#1706.2|N||POINT(15 10)
+#1706.2|N||POINT(10 10)
+#1706.2|E|LINESTRING(10 0,10 10)
+#1706.2|E|LINESTRING(15 10,10 10)
+#1706.2|E|LINESTRING(10 10,9 12)
+#1706.2|E|LINESTRING(20 10,15 10)
+#1706.2|E|LINESTRING(9 12,10 20)
 #1714.1|N|77
-#1714.1|N|77|0|POINT(10 0)
+#1714.1|N|0|POINT(10 0)
 #1714.2|E*|74
-#1714.2|N|78||POINT(0 20)
-#1714.2|E|74|sn77|en78
+#1714.2|N||POINT(0 20)
+#1714.2|E|LINESTRING(10 0,0 20)
 Topology 'city_data' dropped
 t3280.start|t
 t3280|L11
@@ -196,7 +193,6 @@ t3412.L2|4
 t3412.end|Topology 'bug3412' dropped
 t3371.start|t
 t3371.L1|1
-t3371.L2|3
 t3371.L2|2
 t3371.end|Topology 'bug3711' dropped
 t3838.start|t
@@ -209,8 +205,6 @@ t1855_1.end|Topology 'bug1855' dropped
 t1855_2.start|t
 t1855_2.0|1
 t1855_2.1|3
-t1855_2.1|5
-t1855_2.1|6
 t1855_2.end|Topology 'bug1855' dropped
 t4757.start|t
 t4757.0|1
Summary of changes:
 topology/test/regress/topogeo_addlinestring.sql    |  33 ++-
 .../test/regress/topogeo_addlinestring_expected    | 238 ++++++++++-----------
 2 files changed, 132 insertions(+), 139 deletions(-)
hooks/post-receive
