[postgis-tickets] [PostGIS] #4758: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 2, LOCATION: pg_error, lwgeom_pg.c:250
PostGIS trac at osgeo.org
Thu Sep 24 08:06:51 PDT 2020
  Reporter:  laopsahl  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.1.0
 Component:  postgis   |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by strk):
 Simplified test:
 select topology.DropTopology('t4758');
 select topology.CreateTopology ('t4758', 0, 1e-06);
 select topology.TopoGeo_addLinestring('t4758',
 'LINESTRING(
 11.38327215  60.4081942,
 11.3826176   60.4089484)
 '); -- length: 0.0009986257269390762 (=~ 1e-3)
 'LINESTRING(
 11.3832721  60.408194249999994,
 11.38327215 60.4081942)
 '); -- length: 7.071067643283874e-08
     -- distance of start point from first edge: 4.9893601355070966e-09
 'LINESTRING(
 11.38330505 60.408239599999995,
 11.3832721  60.408194249999994)
 '); -- length:  5.6056444769047025e-05
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4758#comment:2>
