[postgis-tickets] [PostGIS] #4756: PostGIS 3.0.2 is bundled with GDAL 2.4.4 that has ogr2ogr incompatible with PG12
PostGIS trac at osgeo.org
Sat Sep 26 21:58:09 PDT 2020
PG12
  Reporter:  mlt         |      Owner:  strk
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 3.0.3
 Component:              |    Version:  3.0.x
  build/upgrade/install  |   Keywords:
Resolution:  wontfix     |  ogr2ogr,gdal,windows,win32,packaging
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 mlt I do plan to release the upcoming PostGIS 3.0.3 with GDAL 3.0.4 or
 GDAL 3.1.  However I'm not sure which problem you are having here. I
 suspect my upgrade won't fix your issue.
 The ogr2ogr that is distributed with windows PostGIS Bundle doesn't even
 have PostgreSQL driver packaged in with it.  I did that intentionally
 because then I'd have possible issues with libpq that is distributed with
 each PostgreSQL version and I use the same GDAL package across all the
 PostGIS bundle PostgreSQL versions.
 You can verify with below that PostgreSQL is not a supported driver
 ogr2ogr --formats
 The ogr2ogr is pretty barebones and was there just cause I needed to
 verify drivers before ogrfdw introduced option to list drivers.
 If you need an ogr2ogr that contains postgresql support -- I highly
 recommend using one of Tamas package https://www.gisinternals.com/.  His
 is what I use when I need PostgreSQL support or some other non-built in
 drivers.  He also has versions built whenever a change in GDAL.
 Alternative would be to use the Foreign Data Wrapper (ogr_fdw) which I
 find easier to use than fussing with ogr2ogr.
 The issue I pointed out in that GDAL ticket doesn't affect the ogr_fdw
 since ogr_fdw doesn't rely on the PostgreSQL plumbing in GDAL. It has it's
 own plumbing which is a bit different from postgresql to postgresql.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4756#comment:2>
