[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-71-gbf932db
Sat Sep 26 22:49:49 PDT 2020
the project "PostGIS".
       via  bf932db36f78a25b7a0869baa03cb000d2cbf4c6 (commit)
      from  3bcbbee1324e0efe574481a59a603b4be85f962a (commit)
revisions in full, below.
commit bf932db36f78a25b7a0869baa03cb000d2cbf4c6
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Sep 27 01:49:42 2020 -0400
    Fail fast when srids of geometry/raster are different. References #4719 for PostGIS 3.1 master
diff --git a/NEWS b/NEWS
index fb8ff3f..9a352a3 100644
--- a/NEWS
+++ b/NEWS
@@ -31,6 +31,8 @@ Only tickets not included in 3.1.0alpha2
   - #4737, Improve performance and reduce memory usage in ST_AsMVT, especially in
            queries involving parallelism (Raúl Marín)
   - #4746, Micro optimizations to the serialization process (Raúl Marín)
+  - #4719, Fail fast when srids don't match ST_Intersection(geometry,raster)
+            Also schema qualify calls in function. (Regina Obe)
 * Bug fixes *
   - #4691, Fix segfault during gist index creation with empty geometries (Raúl Marín)
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index bfb91b5..ab1669b 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -6671,9 +6671,15 @@ CREATE OR REPLACE FUNCTION ST_Disjoint(rast1 raster, rast2 raster)
 CREATE OR REPLACE FUNCTION ST_Intersection(geomin geometry, rast raster, band integer DEFAULT 1)
 	RETURNS SETOF geomval AS $$
 	DECLARE
-		intersects boolean := FALSE;
+		intersects boolean := FALSE; same_srid boolean := FALSE;
 	BEGIN
-		intersects := ST_Intersects(geomin, rast, band);
+		same_srid :=  (@extschema at .ST_SRID(geomin) = @extschema at .ST_SRID(rast));
+		IF NOT same_srid THEN
+			RAISE EXCEPTION 'SRIDS of geometry: % and raster: % are not the same',
+				@extschema at .ST_SRID(geomin), @extschema at .ST_SRID(rast)
+				USING HINT = 'Verify using ST_SRID function';
+		END IF;
+		intersects :=  @extschema at .ST_Intersects(geomin, rast, band);
 		IF intersects THEN
 			-- Return the intersections of the geometry with the vectorized parts of
 			-- the raster and the values associated with those parts, if really their
@@ -6684,12 +6690,12 @@ CREATE OR REPLACE FUNCTION ST_Intersection(geomin geometry, rast raster, band in
 					val
 				FROM (
 					SELECT
-						ST_Intersection((gv).geom, geomin) AS intgeom,
+						@extschema at .ST_Intersection((gv).geom, geomin) AS intgeom,
 						(gv).val
-					FROM ST_DumpAsPolygons(rast, band) gv
-					WHERE ST_Intersects((gv).geom, geomin)
+					FROM @extschema at .ST_DumpAsPolygons(rast, band) gv
+					WHERE @extschema at .ST_Intersects((gv).geom, geomin)
 				) foo
-				WHERE NOT ST_IsEmpty(intgeom);
+				WHERE NOT @extschema at .ST_IsEmpty(intgeom);
 		ELSE
 			-- If the geometry does not intersect with the raster, return an empty
 			-- geometry and a null value
diff --git a/raster/test/regress/rt_intersection.sql b/raster/test/regress/rt_intersection.sql
index 46344e0..1dd9a48 100644
--- a/raster/test/regress/rt_intersection.sql
+++ b/raster/test/regress/rt_intersection.sql
@@ -161,5 +161,12 @@ FROM (
 ) foo
 ORDER BY 1, 2, 3, 4, 5, 6, 7;
+-- test for mismatched srid geom/raster https://trac.osgeo.org/postgis/ticket/4719
+SELECT '#4719' AS ticker,  r1.rid, ST_Intersection(
+		r1.rast, ST_Buffer(ST_SetSRID(ST_Point(1,2), 4326),0.5)
+	FROM raster_intersection AS r1
+	WHERE r1.rid = 10;
 DROP TABLE IF EXISTS raster_intersection;
 DROP TABLE IF EXISTS raster_intersection_out;
diff --git a/raster/test/regress/rt_intersection_expected b/raster/test/regress/rt_intersection_expected
index 67161ba..0f819fa 100644
--- a/raster/test/regress/rt_intersection_expected
+++ b/raster/test/regress/rt_intersection_expected
@@ -118,3 +118,4 @@
 10|13|2|1|2|4|POLYGON((0.1 -0.8,1.1 -0.7,1.2 0.3,0.2 0.2,0.1 -0.8))
 10|13|2|2|1|4|POLYGON((1 -1.7,2 -1.6,2.1 -0.6,1.1 -0.7,1 -1.7))
 10|13|2|2|2|4|POLYGON((1.1 -0.7,2.1 -0.6,2.2 0.4,1.2 0.3,1.1 -0.7))
+ERROR:  SRIDS of geometry: 4326 and raster: 0 are not the same
Summary of changes:
 NEWS                                         |  2 ++
 raster/rt_pg/rtpostgis.sql.in                | 18 ++++++++++++------
 raster/test/regress/rt_intersection.sql      |  7 +++++++
 raster/test/regress/rt_intersection_expected |  1 +
 4 files changed, 22 insertions(+), 6 deletions(-)
hooks/post-receive
