[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-123-g91f887f
Thu Apr 1 16:49:17 PDT 2021
the project "PostGIS".
       via  91f887f5cc5a675beaa9c54870115346fa754c48 (commit)
      from  d5f7a2adc923869ebe17b5fd0a6fa299d5b9c20c (commit)
revisions in full, below.
commit 91f887f5cc5a675beaa9c54870115346fa754c48
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Apr 1 19:49:11 2021 -0400
    Change GDAL require > 2 on configure to agree with docs.  Change SFCGAL on docs to agree with configure and change SFCGAL links to gitlab
diff --git a/configure.ac b/configure.ac
index 20eadc0..48ba070 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1339,7 +1339,7 @@ if test "x$with_raster" != "xno"; then
 	LIBGDAL_DEPLIBS_LDFLAGS=""
 	dnl GDAL version constants, update here
-	GDAL_MIN_VERSION=1.8.0
+	GDAL_MIN_VERSION=2.0.0
 	GDAL_MIN_VERSION_NUMBER=180 dnl TODO: Use GDAL version calculation MAJOR*1000+MINOR*100+REV*10+BUILD
 	AC_ARG_WITH(
diff --git a/doc/installation.xml b/doc/installation.xml
index 0c3a60b..af4b7f5 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -241,9 +241,9 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
 	  <listitem>
 		<para>
-			SFCGAL, version 1.1 (or higher) could be used to provide additional 2D and 3D advanced analysis functions to PostGIS cf <xref linkend="reference_sfcgal" />. And also allow to use SFCGAL rather than GEOS for some 2D functions provided by both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis.backend</code> allow end user to control which backend he want to use if SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <ulink url="http://oslandia.github.io/SFCGAL/installation.html">http://oslandia.github.io/SFCGAL/installation.html</ulink>)
+			SFCGAL, version 1.3.1 (or higher) could be used to provide additional 2D and 3D advanced analysis functions to PostGIS cf <xref linkend="reference_sfcgal" />. And also allow to use SFCGAL rather than GEOS for some 2D functions provided by both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis.backend</code> allow end user to control which backend he want to use if SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <ulink url="https://oslandia.gitlab.io/SFCGAL/dev.html">https://oslandia.gitlab.io/SFCGAL/dev.html</ulink>)
-		  <ulink url="https://github.com/Oslandia/SFCGAL">https://github.com/Oslandia/SFCGAL</ulink>.
+		  <ulink url="https://gitlab.com/Oslandia/SFCGAL/">https://gitlab.com/Oslandia/SFCGAL/</ulink>.
 		</para>
 	  </listitem>
Summary of changes:
 configure.ac         | 2 +-
 doc/installation.xml | 4 ++--
 2 files changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
