[postgis-tickets] [PostGIS] #4893: Topology Exception on st_intersection
PostGIS trac at osgeo.org
Sun Apr 4 19:34:54 PDT 2021
 Reporter:  mlt35                                |      Owner:  pramsey
     Type:  defect                               |     Status:  new
 Priority:  medium                               |  Milestone:  PostGIS
                                                 |  3.1.2
Component:  postgis                              |    Version:  3.1.x
 Keywords:  Geos Error, Topology Exception,      |
  lwgeom_intersection_prec                       |
 I was running an st_intersection operation on very complex, albeit valid
 geometries, and received the following message:
 {{{SQL Error [XX000]: ERROR: lwgeom_intersection_prec: GEOS Error:
 TopologyException: Directed Edge visited twice during ring-building at
 1007901.2646933049 165954.35405701387}}}
 I realize the multipolygon object is extremely complex and not ideal to
 work with (I didn't realize quite how bad it was until this problem
 arose). Ultimately, running st_subdivide on the multipolygon object
 allowed me to run an equivalent of this intersection with no issue.
 Further down is a reproducible example that throws the error, but first,
 here's my postgis info (Running on Windows 10 x64; Postgres 13.0,
 installed via StackBuilder):
 select postgis_full_version();
 --POSTGIS="3.1.1 3.1.1" [EXTENSION] PGSQL="130" GEOS="3.9.0-CAPI-1.14.1"
 SFCGAL="1.3.8" PROJ="7.1.1" GDAL="GDAL 3.2.1, released 2020/12/29"
 LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
 TOPOLOGY RASTER
 Reproducible Example:
 select st_intersection(st_geomfromtext('MULTIPOLYGON (((1007897.6751335859
 165975.99421341717, 1007898.4300533384 165975.52472616732,
 1007899.1482277513 165975.01029150188, 1007899.8312972635
 165974.44992516935, 1007900.475981012 165973.8459237516,
 1007900.6751275957 165973.64251208305, 1007900.722699672
 165973.59264342487, 1007900.7725683451 165973.54507133365,
 1007900.9759800136 165973.34592474997, 1007901.5799814165
 165972.7012410015, 1007902.1403477639 165972.01817150414,
 1007902.6547824293 165971.30032517016, 1007903.1213169247
 165970.5499985963, 1007903.5376546681 165969.77080066502,
 1007903.9024833441 165968.96634033322, 1007904.213506341
 165968.1395703405, 1007904.4700675011 165967.29409958422, 1007904.67052643
 165966.43386508524, 1007904.734830752 165966.08773717284,
 1007904.738767758 165966.0647713393, 1007904.7459855974 165966.0424616784,
 1007904.9700665027 165965.29410359263, 1007905.1705254167
 165964.43386909366, 1007905.2348297536 165964.08774116635,
 1007905.2387667596 165964.0647753328, 1007905.2459845841
 165964.0424656719, 1007905.4700655043 165963.29410758615,
 1007905.6705244184 165962.43387308717, 1007905.8145530075
 165961.56215567887, 1007905.9011670053 165960.68289233744,
 1007905.9300383329 165959.80002008379, 1007905.9300383329
 165959.62482358515, 1007906.1800378412 165959.49129366875,
 1007906.9300363362 165959.0247591734, 1007907.6482107639
 165958.51032450795, 1007908.3312802613 165957.94995817542,
 1007908.9759640098 165957.34595675766, 1007909.1751105934
 165957.14254508913, 1007909.2226826698 165957.09267641604,
 1007909.2725513428 165957.04510433972, 1007909.4759630114
 165956.84595775604, 1007909.6751095951 165956.6425460875,
 1007909.7226816714 165956.59267742932, 1007909.7725503445
 165956.5451053381, 1007909.975962013 165956.34595875442,
 1007910.1751085967 165956.14254708588, 1007910.222680673
 165956.0926784277, 1007910.2725493461 165956.04510633647,
 1007910.4759609997 165955.8459597528, 1007910.6751075834
 165955.64254808426, 1007910.7226796746 165955.59267942607,
 1007910.7725483477 165955.54510733485, 1007910.9759600013
 165955.34596075118, 1007911.175106585 165955.14254908264,
 1007911.2226786762 165955.09268042445, 1007911.2725473344
 165955.04510833323, 1007911.475959003 165954.84596174955,
 1007912.0799604207 165954.20127800107, 1007912.6403267533
 165953.51820850372, 1007913.1547614187 165952.80036216974,
 1007913.3772019297 165952.44242325425, 1007913.4759550095
 165952.34596675634, 1007913.6751015931 165952.1425550878,
 1007913.7226736695 165952.09268642962, 1007913.7725423425
 165952.0451143384, 1007913.9759540111 165951.84596775472,
 1007914.1751005948 165951.64255608618, 1007914.2226726711
 165951.592687428, 1007914.2725413442 165951.54511533678,
 1007914.4759530127 165951.3459687531, 1007914.6750995964
 165951.14255708456, 1007914.7226716727 165951.09268842638,
 1007914.7725403458 165951.04511633515, 1007914.9759520143
 165950.84596975148, 1007915.1750985831 165950.64255808294,
 1007915.2226706743 165950.59268942475, 1007915.2725393474
 165950.54511733353, 1007915.475951001 165950.34597074986,
 1007915.6750975847 165950.14255909622, 1007915.722669676
 165950.09269042313, 1007915.7725383341 165950.0451183319,
 1007915.9759500027 165949.84597174823, 1007916.0743750036
 165949.74525016546, 1007916.6921559274 165949.6845547557,
 1007917.5638733357 165949.54052616656, 1007918.4241078347
 165949.34006725252, 1007919.269578591 165949.08350609243,
 1007920.0963485837 165948.77248309553, 1007920.9008089304
 165948.40765441954, 1007921.6800068468 165947.99131667614,
 1007922.4303334206 165947.52478216588, 1007923.1481797546
 165947.01034750044, 1007923.831249252 165946.4499811679,
 1007924.4759330004 165945.84597975016, 1007925.0799344182
 165945.20129600167, 1007925.6403007507 165944.51822650433,
 1007926.1547354311 165943.80005209148, 1007926.6212699264
 165943.0500535816, 1007927.0379357636 165942.2708556652,
 1007927.4024363458 165941.46606725454, 1007927.7134593427
 165940.63929726183, 1007927.7698896676 165940.47263091803,
 1007927.9007949233 165940.4076704234, 1007928.6799928397
 165939.9913326651, 1007929.4303194284 165939.52479816973,
 1007930.1481657624 165939.0103635043, 1007930.8312352598
 165938.44999717176, 1007931.4759190083 165937.845995754, 1007932.079920426
 165937.20131200552, 1007932.6402867585 165936.51824250817,
 1007933.154721424 165935.80006809533, 1007933.3774900138
 165935.4424572587, 1007933.4759149998 165935.3460007608,
 1007934.0799164176 165934.7013170123, 1007934.6353615075
 165934.02448108792, 1007934.6438916773 165934.01365433633,
 1007934.6543903351 165934.00545226038, 1007935.3312262595
 165933.44967909157, 1007935.975910008 165932.84600575268,
 1007936.5799114257 165932.2013220042, 1007937.1402777582
 165931.51825250685, 1007937.6547124237 165930.800078094, 1007938.121246919
 165930.05007958412, 1007938.5379127562 165929.27088166773,
 1007938.9024133384 165928.46609325707, 1007939.2134363353
 165927.63932324946, 1007939.4699975103 165926.79418058693,
 1007939.6704564244 165925.9336180091, 1007939.8144850135
 165925.06222867966, 1007939.9010990113 165924.18296533823,
 1007939.9299703389 165923.30009308457, 1007939.9299703389
 165922.47266691923, 1007940.0379097611 165922.27089567482,
 1007940.4024103433 165921.46610724926, 1007940.7134333402
 165920.63933725655, 1007940.9699945003 165919.79419459403,
 1007941.1704534292 165918.93363200128, 1007941.3144820035
 165918.06224267185, 1007941.4010960013 165917.18297934532,
 1007941.4299673438 165916.30010709167, 1007941.4299673438
 165913.8463718444, 1007940.5029754043 165913.70642201602,
 1007939.5879342258 165913.50246206298, 1007938.6892583369
 165913.23547594246, 1007937.8112831711 165912.90675169227,
 1007936.9582444428 165912.51787518707, 1007936.1342574953
 165912.07072250542, 1007935.343297541 165911.56745087352,
 1007934.5891804098 165911.01048823443, 1007933.8755442499
 165910.40252158788, 1007933.205831915 165909.74648395923,
 1007932.583274275 165909.0455403104, 1007932.0108748077
 165908.30307223645, 1007931.4913949369 165907.5226616561,
 1007931.0273408293 165906.7080735415, 1007930.6209512352
 165905.86323775348, 1007930.2741867303 165904.9922300726,
 1007929.9887202083 165904.09925253686, 1007929.7659288942
 165903.18861318377, 1007929.6068875492 165902.2647052519,
 1007929.5123634934 165901.33198598772, 1007929.4828127623
 165900.39495517313, 1007928.8128665835 165900.329010427,
 1007927.9299943447 165900.30013908446, 1007927.4299953431
 165900.30013908446, 1007926.5471230894 165900.329010427,
 1007925.7951560915 165900.40282917023, 1007925.4007999301
 165900.19219967723, 1007924.5963395834 165899.827699095,
 1007923.7695695907 165899.51634800434, 1007922.9240988344
 165899.26011492312, 1007922.0638643354 165899.0593279153,
 1007921.1921469271 165898.91562741995, 1007920.3128835857
 165898.82901342213, 1007919.4300113469 165898.8001420945,
 1007917.9300143421 165898.8001420945, 1007917.0471420884
 165898.82901342213, 1007916.1678787619 165898.91562741995,
 1007915.2961613387 165899.0593279153, 1007914.4359268397
 165899.26011492312, 1007913.5904560834 165899.51634800434,
 1007912.7636860907 165899.827699095, 1007911.9592257589
 165900.19219967723, 1007911.1800278425 165900.60853742063,
 1007910.4297012538 165901.07507191598, 1007909.7118549198
 165901.5898346752, 1007909.0287854224 165902.15020100772,
 1007908.384101674 165902.75420242548, 1007907.7801002562
 165903.39888617396, 1007907.2197339237 165904.08162759244,
 1007906.7052992582 165904.7998020053, 1007906.2387647629
 165905.55012859404, 1007905.8220989257 165906.32899841666,
 1007905.7951960862 165906.38870958984, 1007905.2325331718
 165907.04979750514, 1007904.8024159223 165907.5816205889,
 1007904.2879812568 165908.29979500175, 1007903.8214467615
 165909.0501215905, 1007903.4051090032 165909.82899142802,
 1007903.040608421 165910.63377983868, 1007902.7292573452
 165911.4605498463, 1007902.4726961702 165912.30602058768,
 1007902.4379193336 165912.44020667672, 1007901.881490007
 165912.69217467308, 1007901.1022920907 165913.10851241648,
 1007900.3522935957 165913.57504692674, 1007899.6341191679
 165914.08980967104, 1007898.9510496706 165914.65017600358,
 1007898.3063659221 165915.25417742133, 1007897.7023645043
 165915.89886116982, 1007897.5393070877 165916.08849333227,
 1007897.1511845142 165916.54813808203, 1007896.7935736775
 165916.9648039192, 1007896.7574845105 165917.0067985952,
 1007896.6495450884 165917.13376684487, 1007896.5311070085
 165917.2748426795, 1007896.4743485898 165917.34341208637,
 1007896.4156216681 165917.41066917777, 1007896.2952150851
 165917.55010458827, 1007895.6495470852 165918.30863325298,
 1007895.2197579294 165918.84012825787, 1007894.705323264
 165919.55830267072, 1007894.2387887537 165920.30862925947,
 1007893.8221229166 165921.08782717586, 1007893.4576223344
 165921.89228750765, 1007893.1465993375 165922.71905750036,
 1007892.8900381774 165923.56452825665, 1007892.6892511696
 165924.42476275563, 1007892.5455506742 165925.29648017883,
 1007892.4589366764 165926.17574350536, 1007892.4349865913
 165926.70428575575, 1007892.3841336668 165926.75415442884,
 1007891.7801322639 165927.39883817732, 1007891.2197659165
 165928.0815795958, 1007890.7050031722 165928.79975400865,
 1007890.4825626761 165929.15769292414, 1007890.3841376752
 165929.25414942205, 1007889.7801362574 165929.89883317053,
 1007889.7128791809 165929.9742923379, 1007889.590504095 165930.016286999,
 1007888.7637340873 165930.32763808966, 1007887.9589456767
 165930.69213867188, 1007887.1800758392 165931.10880450904,
 1007886.4297492504 165931.57501092553, 1007885.7115748376
 165932.08977366984, 1007885.0288334191 165932.65014000237,
 1007884.3841496706 165933.25414142013, 1007883.7801482528
 165933.8988251686, 1007883.2197819203 165934.5815665871, 1007882.705019176
 165935.29974099994, 1007882.2388127595 165936.0500675887,
 1007881.8221469223 165936.82926550508, 1007881.4576463401
 165937.63372583687, 1007881.1462952644 165938.46049584448,
 1007880.8900621682 165939.30596658587, 1007880.6892751753
 165940.16620108485, 1007880.54557468 165941.03791850805,
 1007880.4589606673 165941.91718183458, 1007880.4330420941
 165942.70622225106, 1007879.6800908446 165943.10878050327,
 1007878.9297642559 165943.57531499863, 1007878.211589843
 165944.08974967897, 1007877.5288484246 165944.6501160115,
 1007876.8841646761 165945.25411742926, 1007876.4202548414
 165945.74164925516, 1007876.3972890079 165945.76723974943,
 1007876.3716985136 165945.79020558298, 1007875.8841666728
 165946.2541154176, 1007875.6850200891 165946.45752708614,
 1007875.6371199191 165946.50706766546, 1007875.5875793397
 165946.55496783555, 1007875.3841676712 165946.75411441922,
 1007875.1850210875 165946.95752608776, 1007875.1371209174
 165947.00706666708, 1007875.0875803381 165947.05496683717,
 1007874.8841686696 165947.25411342084, 1007874.6850220859
 165947.45752508938, 1007874.6371219307 165947.5070656687,
 1007874.5875813365 165947.5549658388, 1007874.384169668
 165947.75411242247, 1007873.7801682502 165948.39879617095,
 1007873.2198019177 165949.0818656683, 1007872.7050391734
 165949.79971200228, 1007872.238504678 165950.55003859103,
 1007871.8221669197 165951.32923650742, 1007871.6335190088
 165951.7281858325, 1007871.6154744178 165951.76788392663,
 1007871.5944770873 165951.80594158173, 1007871.3221679181
 165952.32923451066, 1007870.9576673359 165953.13369484246,
 1007870.6463162601 165953.96046483517, 1007870.3900831789
 165954.80593559146, 1007870.1892961711 165955.66617009044,
 1007870.0455956757 165956.53788749874, 1007869.9589816779
 165957.41715084016, 1007869.9301103354 165958.30002309382,
 1007869.9301103354 165960.80001808703, 1007869.9589816779
 165961.6828903407, 1007870.0455956757 165962.5621536672,
 1007870.1892961711 165963.4338710904, 1007870.3900831789
 165964.2941055894, 1007870.6463162601 165965.13957634568,
 1007870.9576673359 165965.9663463384, 1007871.3221679181
 165966.7708066702, 1007871.7385056764 165967.55000458658,
 1007872.2050401717 165968.30033117533, 1007872.6712465882
 165968.9519046694, 1007872.822164923 165969.2708016783, 1007873.0944740921
 165969.79409459233, 1007873.1154714227 165969.83215226233,
 1007873.1335160136 165969.87185034156, 1007873.3221639246
 165970.27079966664, 1007873.738501668 165971.04999758303,
 1007874.2050361782 165971.80032417178, 1007874.7197989225
 165972.51817050576, 1007875.2801652551 165973.2012400031,
 1007875.8841666728 165973.8459237516, 1007876.0875783414
 165974.04507033527, 1007876.1371189207 165974.0926424265,
 1007876.1850190908 165974.14251108468, 1007876.3841656744
 165974.34592275321, 1007877.0288494229 165974.94992417097,
 1007877.7115908414 165975.5102905035, 1007878.4297652543
 165976.02472516894, 1007879.180091843 165976.4912596792,
 1007879.9589616805 165976.90792550147, 1007880.7637500912
 165977.27242608368, 1007881.5905200839 165977.5834490955,
 1007882.4359908402 165977.84001025558, 1007883.2962253392
 165978.04046916962, 1007883.6420251727 165978.10477350652,
 1007883.6653190851 165978.10871051252, 1007883.6876287609
 165978.11625641584, 1007884.4359868467 165978.3400092572,
 1007885.2962213457 165978.54046817124, 1007886.167938754
 165978.68449676037, 1007887.0472020954 165978.77111075819,
 1007887.9300743341 165978.79998208582, 1007889.430071339
 165978.79998208582, 1007890.3129435927 165978.77111075819,
 1007891.1922069192 165978.68449676037, 1007892.0635962635
 165978.54046817124, 1007892.9241588414 165978.3400092572,
 1007893.7693015039 165978.0834480822, 1007894.5960715115
 165977.7724250853, 1007895.4008599222 165977.4079245031,
 1007896.1800578386 165976.99125866592, 1007896.9300563335
 165976.52472417057, 1007897.6305142641 165976.0240690112,
 1007897.6518396735 165976.0076648444, 1007897.6751335859
 165975.99421341717), (1007899.4300513417 165947.80004408956,
 1007898.93005234 165947.80004408956, 1007898.93005234 165945.80004808307,
 1007898.4300533384 165945.80004808307, 1007898.4300533384
 165945.30004909635, 1007897.9300543368 165945.30004909635,
 1007897.9300543368 165944.80005009472, 1007897.4300553352
 165944.80005009472, 1007897.4300553352 165945.30004909635,
 1007896.9300563335 165945.30004909635, 1007896.9300563335
 165945.80004808307, 1007896.4300573468 165945.80004808307,
 1007896.4300573468 165946.3000470847, 1007895.9300583452
 165946.3000470847, 1007895.9300583452 165946.8000460863,
 1007895.4300593436 165946.8000460863, 1007895.4300593436
 165946.3000470847, 1007893.9300623387 165946.3000470847,
 1007893.9300623387 165942.80005408823, 1007896.9300563335
 165942.80005408823, 1007896.9300563335 165942.3000550866,
 1007897.9300543368 165942.3000550866, 1007897.9300543368
 165941.30005708337, 1007898.4300533384 165941.30005708337,
 1007898.4300533384 165940.80005808175, 1007898.93005234
 165940.80005808175, 1007898.93005234 165940.30005909503,
 1007899.4300513417 165940.30005909503, 1007899.4300513417
 165939.8000600934, 1007899.9300503433 165939.8000600934,
 1007899.9300503433 165938.80006209016, 1007900.4300493449
 165938.80006209016, 1007900.4300493449 165938.30006308854,
 1007900.9300483465 165938.30006308854, 1007900.9300483465
 165937.8000640869, 1007901.4300473332 165937.8000640869,
 1007901.4300473332 165937.3000650853, 1007901.9300463349
 165937.3000650853, 1007901.9300463349 165936.30006708205,
 1007902.4300453365 165936.30006708205, 1007902.4300453365
 165935.80006809533, 1007903.4300433397 165935.80006809533,
 1007903.4300433397 165935.3000690937, 1007903.9300423414
 165935.3000690937, 1007903.9300423414 165934.80007009208,
 1007904.430041343 165934.80007009208, 1007904.430041343
 165934.30007109046, 1007904.9300403446 165934.30007109046,
 1007904.9300403446 165933.80007208884, 1007905.4300393462
 165933.80007208884, 1007905.4300393462 165933.30007308722,
 1007905.9300383329 165933.30007308722, 1007905.9300383329
 165932.8000740856, 1007906.4300373346 165932.8000740856,
 1007906.4300373346 165931.80007608235, 1007906.9300363362
 165931.80007608235, 1007906.9300363362 165929.30008108914,
 1007906.4300373346 165929.30008108914, 1007906.4300373346
 165928.3000830859, 1007905.9300383329 165928.3000830859,
 1007905.9300383329 165927.05861575902, 1007906.5757063478
 165926.3000870943, 1007906.9300363362 165926.3000870943,
 1007906.9300363362 165925.883749336, 1007907.0379757583
 165925.75678108633, 1007907.4300353378 165925.30008909106,
 1007907.8522785902 165924.80009008944, 1007907.9300343394
 165924.80009008944, 1007907.9300343394 165925.30008909106,
 1007908.9300323427 165925.30008909106, 1007908.9300323427
 165925.80008809268, 1007910.9300283343 165925.80008809268,
 1007910.9300283343 165925.30008909106, 1007911.9300263375
 165925.30008909106, 1007911.9300263375 165924.80009008944,
 1007912.4300253391 165924.80009008944, 1007912.4300253391
 165924.30009108782, 1007912.9300243407 165924.30009108782,
 1007912.9300243407 165923.8000920862, 1007913.4300233424
 165923.8000920862, 1007913.4300233424 165923.30009308457,
 1007913.930022344 165923.30009308457, 1007913.930022344
 165922.80009408295, 1007914.4300213456 165922.80009408295,
 1007914.4300213456 165922.30009509623, 1007914.9300203472
 165922.30009509623, 1007914.9300203472 165921.300097093, 1007915.430019334
 165921.300097093, 1007915.430019334 165920.30009908974, 1007915.9300183356
 165920.30009908974, 1007915.9300183356 165918.30010308325,
 1007916.4300173372 165918.30010308325, 1007916.4300173372
 165916.30010709167, 1007915.9300183356 165916.30010709167,
 1007915.9300183356 165915.80010809004, 1007915.5126963407
 165915.80010809004, 1007918.156719923 165912.6938150823,
 1007917.9300143421 165912.5009020865, 1007917.9300143421
 165912.3001150936, 1007919.4300113469 165912.3001150936,
 1007919.4300113469 165912.8001140952, 1007919.9300103337
 165912.8001140952, 1007919.9300103337 165913.80011208355,
 1007920.4300093353 165913.80011208355, 1007920.4300093353
 165914.30011108518, 1007920.9300083369 165914.30011108518,
 1007920.9300083369 165914.8001100868, 1007921.4300073385
 165914.8001100868, 1007921.4300073385 165915.30010908842,
 1007921.9300063401 165915.30010908842, 1007921.9300063401
 165915.80010809004, 1007922.9300043434 165915.80010809004,
 1007922.9300043434 165916.30010709167, 1007924.930000335
 165916.30010709167, 1007924.930000335 165915.80010809004,
 1007925.4299993366 165915.80010809004, 1007925.4299993366
 165915.30010908842, 1007925.9299983382 165915.30010908842,
 1007925.9299983382 165914.30011108518, 1007927.4299953431
 165914.30011108518, 1007927.4299953431 165913.80011208355,
 1007927.9299943447 165913.80011208355, 1007927.9299943447
 165916.30010709167, 1007927.4299953431 165916.30010709167,
 1007927.4299953431 165916.8001060933, 1007926.9299963415
 165916.8001060933, 1007926.9299963415 165917.3001050949,
 1007926.4299973398 165917.3001050949, 1007926.4299973398
 165923.30009308457, 1007925.4299993366 165923.30009308457,
 1007925.4299993366 165923.8000920862, 1007924.930000335 165923.8000920862,
 1007924.930000335 165924.30009108782, 1007924.4300013334
 165924.30009108782, 1007924.4300013334 165924.80009008944,
 1007923.9300023466 165924.80009008944, 1007923.9300023466
 165925.80008809268, 1007923.430003345 165925.80008809268,
 1007923.430003345 165926.3000870943, 1007922.9300043434 165926.3000870943,
 1007922.9300043434 165926.80008609593, 1007922.4300053418
 165926.80008609593, 1007922.4300053418 165927.30008508265,
 1007921.9300063401 165927.30008508265, 1007921.9300063401
 165928.3000830859, 1007918.4300133437 165928.3000830859,
 1007918.4300133437 165928.80008208752, 1007917.4300153404
 165928.80008208752, 1007917.4300153404 165929.30008108914,
 1007916.9300163388 165929.30008108914, 1007916.9300163388
 165929.80008009076, 1007916.4300173372 165929.80008009076,
 1007916.4300173372 165930.30007909238, 1007915.430019334
 165930.30007909238, 1007915.430019334 165929.80008009076,
 1007914.4300213456 165929.80008009076, 1007914.4300213456
 165930.30007909238, 1007913.4300233424 165930.30007909238,
 1007913.4300233424 165931.30007709563, 1007912.9300243407
 165931.30007709563, 1007912.9300243407 165932.8000740856,
 1007913.4300233424 165932.8000740856, 1007913.4300233424
 165933.30007308722, 1007913.930022344 165933.30007308722,
 1007913.930022344 165933.80007208884, 1007914.9300203472
 165933.80007208884, 1007914.9300203472 165936.30006708205,
 1007914.4300213456 165936.30006708205, 1007914.4300213456
 165935.80006809533, 1007913.930022344 165935.80006809533,
 1007913.930022344 165935.3000690937, 1007910.9300283343 165935.3000690937,
 1007910.9300283343 165935.80006809533, 1007910.4300293475
 165935.80006809533, 1007910.4300293475 165936.30006708205,
 1007909.9300303459 165936.30006708205, 1007909.9300303459
 165936.80006608367, 1007908.9300323427 165936.80006608367,
 1007908.9300323427 165937.3000650853, 1007908.430033341 165937.3000650853,
 1007908.430033341 165937.8000640869, 1007907.9300343394 165937.8000640869,
 1007907.9300343394 165938.30006308854, 1007907.4300353378
 165938.30006308854, 1007907.4300353378 165939.30006109178,
 1007906.9300363362 165939.30006109178, 1007906.9300363362
 165939.8000600934, 1007906.4300373346 165939.8000600934,
 1007906.4300373346 165940.30005909503, 1007905.9300383329
 165940.30005909503, 1007905.9300383329 165940.80005808175,
 1007905.4300393462 165940.80005808175, 1007905.4300393462
 165941.30005708337, 1007904.9300403446 165941.30005708337,
 1007904.9300403446 165941.800056085, 1007904.430041343 165941.800056085,
 1007904.430041343 165942.3000550866, 1007903.9300423414 165942.3000550866,
 1007903.9300423414 165942.80005408823, 1007903.4300433397
 165942.80005408823, 1007903.4300433397 165943.30005308986,
 1007902.9300443381 165943.30005308986, 1007902.9300443381
 165943.80005209148, 1007902.4300453365 165943.80005209148,
 1007902.4300453365 165944.3000510931, 1007901.9300463349
 165944.3000510931, 1007901.9300463349 165945.30004909635,
 1007901.4300473332 165945.30004909635, 1007901.4300473332
 165945.80004808307, 1007900.9300483465 165945.80004808307,
 1007900.9300483465 165946.3000470847, 1007900.4300493449
 165946.3000470847, 1007900.4300493449 165946.8000460863,
 1007899.9300503433 165946.8000460863, 1007899.9300503433
 165947.30004508793, 1007899.4300513417 165947.30004508793,
 1007899.4300513417 165947.80004408956)), ((1007890.3657650054
 165975.80654975772, 1007891.3074774145 165975.7736644372,
 1007892.2446018754 165975.6751686893, 1007893.1725728511
 165975.51154237238, 1007894.0868693291 165975.28358265755,
 1007894.983036965 165974.99240013954, 1007895.8567096888
 165974.6394134387, 1007896.7036311327 165974.22634226826,
 1007897.5196750759 165973.75519905981, 1007898.3008659183
 165973.22827918825, 1007899.0433977543 165972.64814974365,
 1007899.7436530291 165972.0176370665, 1007900.3982201515
 165971.33981294927, 1007901.0039101838 165970.6179796755,
 1007901.5577722489 165969.8556539565, 1007902.0571079849
 165969.0565497577, 1007902.4994846581 165968.22456024584,
 1007902.882747054 165967.36373877522, 1007903.2050279974
 165966.47827918825, 1007903.4647573231 165965.57249534872,
 1007903.6606696843 165964.65080016103, 1007903.7918106018
 165963.7176840156, 1007903.8575411736 165962.77769296613,
 1007903.8575411736 165961.8354065567, 1007903.7918106018
 165960.89541550723, 1007903.6606696843 165959.9622993618,
 1007903.4647573231 165959.04060416666, 1007903.2050279974
 165958.13482033458, 1007902.882747054 165957.2493607476,
 1007902.4994846581 165956.388539277, 1007902.0571079849 165955.5565497577,
 1007901.5577722489 165954.75744556633, 1007901.0039101838
 165953.99511984733, 1007900.3982201515 165953.27328657356,
 1007899.7436530291 165952.59546245632, 1007899.0433977543
 165951.96494977918, 1007898.3008659183 165951.38482033458,
 1007897.5196750759 165950.85790046302, 1007896.7036311327
 165950.38675725457, 1007895.8567096888 165949.97368608412,
 1007894.983036965 165949.6206993833, 1007894.0868693291
 165949.32951686528, 1007893.1725728511 165949.10155715045,
 1007892.2446018754 165948.93793082607, 1007891.3074774145
 165948.83943508563, 1007890.3657650054 165948.80654975696,
 1007889.4240526258 165948.83943508563, 1007888.4869281648
 165948.93793082607, 1007887.5589571892 165949.10155715045,
 1007886.6446607112 165949.32951686528, 1007885.7484930753
 165949.6206993833, 1007884.8748203515 165949.97368608412,
 1007884.0278989075 165950.38675725457, 1007883.2118549644
 165950.85790046302, 1007882.430664122 165951.38482033458,
 1007881.688132286 165951.96494977918, 1007880.9878770112
 165952.59546245632, 1007880.3333098887 165953.27328657356,
 1007879.7276198565 165953.99511984733, 1007879.1737577914
 165954.75744556633, 1007878.6744220554 165955.5565497577,
 1007878.2320453821 165956.388539277, 1007877.8487829863 165957.2493607476,
 1007877.5265020429 165958.13482033458, 1007877.2667727171
 165959.04060416666, 1007877.070860356 165959.9622993618,
 1007876.9397194384 165960.89541550723, 1007876.8739888667
 165961.8354065567, 1007876.8739888667 165962.77769296613,
 1007876.9397194384 165963.7176840156, 1007877.070860356
 165964.65080016103, 1007877.2667727171 165965.57249534872,
 1007877.5265020429 165966.47827918825, 1007877.8487829863
 165967.36373877522, 1007878.2320453821 165968.22456024584,
 1007878.6744220554 165969.0565497577, 1007879.1737577914
 165969.8556539565, 1007879.7276198565 165970.6179796755,
 1007880.3333098887 165971.33981294927, 1007880.9878770112
 165972.0176370665, 1007881.688132286 165972.64814974365, 1007882.430664122
 165973.22827918825, 1007883.2118549644 165973.75519905981,
 1007884.0278989075 165974.22634226826, 1007884.8748203515
 165974.6394134387, 1007885.7484930753 165974.99240013954,
 1007886.6446607112 165975.28358265755, 1007887.5589571892
 165975.51154237238, 1007888.4869281648 165975.6751686893,
 1007889.4240526258 165975.7736644372, 1007890.3657650054
 165975.80654975772)))
 '), st_geomfromtext('POLYGON ((1007898.2646993101 165955.73802031577,
 1007898.2646993101 165958.7380143106, 1007895.2647053003
 165958.7380143106, 1007895.2647053003 165961.1422873552,
 1007903.0009145737 165967.71595335007, 1007916.4510178566
 165951.53980731964, 1007917.8975553513 165949.8003230095,
 1007910.2646753043 165943.3143946815, 1007910.2646753043
 165943.73771622777, 1007907.2646813095 165943.73771622777,
 1007907.2646813095 165949.7380323112, 1007904.2646872997
 165949.7380323112, 1007904.2646872997 165952.73802630603,
 1007901.2646933049 165952.73802630603, 1007901.2646933049
 165955.73802031577, 1007898.2646993101 165955.73802031577))
 --SQL Error [XX000]: ERROR: lwgeom_intersection_prec: GEOS Error:
 Again - I checked validity of both of the objects and they come back valid
 using
 {{{select st_isvalid([insert st_geomfromtext]);}}}
 Thanks to the devs who work on this and who have made PostGIS such a
 powerful and robust product!
 Best,
 Mike Treglia
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4893>
