[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-135-g022f6ea
Sun Apr 11 11:34:06 PDT 2021
the project "PostGIS".
       via  022f6eaac6d05b5d70578075086b0998684f78ac (commit)
       via  9773307ee16c9a0f2d970e87ba444b18bae02290 (commit)
       via  9bb03f8a2a86517db06fd695fd9a1891645fdeba (commit)
       via  4f653e76d48e93a81b6aa2a9d399154503e3e340 (commit)
       via  6650f487b0c30fc1ae1ab816574b650b4882971e (commit)
      from  b3659c0b0c9cfe935a249e3b89d3047d45d169c9 (commit)
revisions in full, below.
commit 022f6eaac6d05b5d70578075086b0998684f78ac
Merge: b3659c0 9773307
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Sun Apr 11 11:34:01 2021 -0700
    Merge branch 'rouault-liblwgeom_cppcheck'
commit 9773307ee16c9a0f2d970e87ba444b18bae02290
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Sun Apr 11 15:45:42 2021 +0200
    _lwt_EdgeRingIterator_begin(): avoid nullptr dereference when er->size == 0
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index b86ff07..2c7d3fd 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -6197,7 +6197,7 @@ _lwt_EdgeRingIterator_begin(LWT_EDGERING *er)
   if ( er->size ) ret->curelem = er->elems[0];
   else ret->curelem = NULL;
   ret->curelemidx = 0;
-  ret->curidx = ret->curelem->left ? 0 : ret->curelem->edge->geom->points->npoints - 1;
+  ret->curidx = (ret->curelem == NULL || ret->curelem->left) ? 0 : ret->curelem->edge->geom->points->npoints - 1;
   return ret;
commit 9bb03f8a2a86517db06fd695fd9a1891645fdeba
Date:   Sun Apr 11 15:45:11 2021 +0200
    lwgeom_topo.c: add missing return in error code path, that could otherwise call a nullptr dereference due to pa being NULL
index 7ec18bb..b86ff07 100644
@@ -4499,6 +4499,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
       e2sign = 0;
       _lwt_release_edges(edges, nedges);
       lwerror("Coding error: caseno=%d should never happen", caseno);
+      return -1;
       break;
   newedge.geom = lwline_construct(topo->srid, NULL, pa);
commit 4f653e76d48e93a81b6aa2a9d399154503e3e340
Date:   Sun Apr 11 15:44:17 2021 +0200
    Use va_copy() / va_end() since we already used va_end(ap2) before
diff --git a/liblwgeom/stringbuffer.c b/liblwgeom/stringbuffer.c
index 9babf0a..d71d5f1 100644
--- a/liblwgeom/stringbuffer.c
+++ b/liblwgeom/stringbuffer.c
@@ -191,7 +191,9 @@ stringbuffer_avprintf(stringbuffer_t *s, const char *fmt, va_list ap)
 	/* Propogate errors up */
 	if ( len < 0 )
 		#if defined(__MINGW64_VERSION_MAJOR)
+		va_copy(ap2, ap);
 		len = _vscprintf(fmt, ap2);/**Assume windows flaky vsnprintf that returns -1 if initial buffer to small and add more space **/
+		va_end(ap2);
 		#else
 		return len;
 		#endif
commit 6650f487b0c30fc1ae1ab816574b650b4882971e
Date:   Sun Apr 11 15:43:45 2021 +0200
    Add missing va_end() calls
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index 647de60..1ab3fc0 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -104,6 +104,7 @@ static void geos_destroy(size_t count, ...) {
 			GEOSGeom_destroy(g);
+	va_end(ap);
@@ -631,6 +632,7 @@ get_result_srid(size_t count, const char* funcname, ...)
 		if (!g)
 			lwerror("%s: Geometry is null", funcname);
+			va_end(ap);
 			return SRID_INVALID;
 		if (i == 0)
@@ -642,10 +644,12 @@ get_result_srid(size_t count, const char* funcname, ...)
 			if (g->srid != srid)
 				lwerror("%s: Operation on mixed SRID geometries (%d != %d)", funcname, srid, g->srid);
+				va_end(ap);
+	va_end(ap);
 	return srid;
Summary of changes:
 liblwgeom/lwgeom_geos.c  | 4 ++++
 liblwgeom/lwgeom_topo.c  | 3 ++-
 liblwgeom/stringbuffer.c | 2 ++
 3 files changed, 8 insertions(+), 1 deletion(-)
hooks/post-receive
