[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-152-gb10a467
Thu Apr 22 13:27:03 PDT 2021
the project "PostGIS".
       via  b10a4673f2168567065c0373ba9534ea2da56f73 (commit)
      from  adc0c61c6b65c11c50f0b490385a7e2070531c78 (commit)
revisions in full, below.
commit b10a4673f2168567065c0373ba9534ea2da56f73
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Apr 22 13:26:56 2021 -0700
    Improve doc WKB/WKT information
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 527b7e3..793706b 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -12,7 +12,7 @@
      organizations all over the world that gain great benefit from its functionality and versatility.</para>
 	<para>The PostGIS project development group plans on supporting and
   enhancing PostGIS to better support a range of important GIS functionality
-	in the areas of OpenGIS and SQL/MM spatial standards, advanced topological constructs (coverages,
+	in the areas of OGC and SQL/MM spatial standards, advanced topological constructs (coverages,
   surfaces, networks), data source for desktop user interface tools for viewing and editing
   GIS data, and web-based access tools.</para>
diff --git a/doc/postgis.xml b/doc/postgis.xml
index e55b2f8..c9eba82 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -67,7 +67,7 @@
    <imageobject><imagedata fileref='images/check.png' /></imageobject>
  </inlinemediaobject>
  This method implements the <ulink
- url='http://www.opengeospatial.org/standards/sfs'>OpenGIS Simple Features
+ url='http://www.opengeospatial.org/standards/sfs'>OGC Simple Features
  Implementation Specification for SQL 1.1.</ulink>">
 <!ENTITY sqlmm_compliant
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index 842e601..cced670 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -131,7 +131,7 @@ CIRCULARSTRING(220268 150415 1,220227 150505 2,220227 150406 3)
 		  <refsection>
 			<title>Description</title>
-			<para>Returns the <link linkend="OpenGISWKBWKT">Well-Known Text</link> (WKT) representation of the geometry/geography.
+			<para>Returns the OGC <link linkend="OpenGISWKBWKT">Well-Known Text</link> (WKT) representation of the geometry/geography.
             The optional <parameter>maxdecimaldigits</parameter> argument may be used to limit the number
 			of digits after the decimal point in output ordinates (defaults to 15).</para>
@@ -202,7 +202,7 @@ F000000000000000000000000000000000000000000000000');
 		  <refentry id="ST_AsBinary">
 		  <refnamediv>
 			<refname>ST_AsBinary</refname>
-			<refpurpose>Return the Well-Known Binary (WKB) representation of the geometry/geography without SRID meta data.</refpurpose>
+			<refpurpose>Return the OGC/ISO Well-Known Binary (WKB) representation of the geometry/geography without SRID meta data.</refpurpose>
 		  </refnamediv>
 		  <refsynopsisdiv>
@@ -231,22 +231,21 @@ F000000000000000000000000000000000000000000000000');
 		  <refsection>
-			<para>Returns the Well-Known Binary representation of the geometry.  There are 2 variants of the function.  The first
+			<para>Returns the OGC/ISO <link linkend="OpenGISWKBWKT">Well-Known Binary</link> representation of the geometry.  There are 2 variants of the function.  The first
 			variant takes no endian encoding parameter and defaults to server machine endian.  The second variant takes a second argument
 			denoting the encoding - using little-endian ('NDR') or big-endian ('XDR') encoding.</para>
 			<para>This is useful in binary cursors to pull data out of the
 			database without converting it to a string representation.</para>
+			<para>To perform the inverse conversion of WKB to PostGIS geometry use <xref linkend="ST_GeomFromWKB" />.</para>
 			<note>
-			  <para>The WKB spec does not include the SRID.  To get the WKB with SRID format use ST_AsEWKB</para>
-			</note>
-			<note>
-			  <para>ST_AsBinary is the reverse of <xref linkend="ST_GeomFromWKB" /> for geometry.  Use <xref linkend="ST_GeomFromWKB" /> to convert to a postgis geometry from ST_AsBinary representation.</para>
+			  <para>The OGC/ISO WKB does not include the SRID.  To get the EWKB format including SRID use <xref linkend="ST_AsEWKB" /></para>
 			</note>
 			<note>
-			  <para>The default behavior in PostgreSQL 9.0 has been changed to output bytea in hex encoding.  ST_AsBinary is the reverse of <xref linkend="ST_GeomFromWKB" /> for geometry.  If your GUI tools
-				require the old behavior, then SET bytea_output='escape' in your database.</para>
+			  <para>The default behavior in PostgreSQL 9.0 has been changed to output bytea in hex encoding.
+                If your GUI tools require the old behavior, then SET bytea_output='escape' in your database.</para>
 			</note>
 			<para>Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
@@ -307,7 +306,7 @@ F000000000000000000000000000000000000000000000000');
 	<refentry id="ST_AsEWKB">
 		  <refnamediv>
 			<refname>ST_AsEWKB</refname>
-			<refpurpose>Return the Well-Known Binary (WKB) representation of the geometry with SRID meta data.</refpurpose>
+			<refpurpose>Return the Extended Well-Known Binary (EWKB) representation of the geometry with SRID meta data.</refpurpose>
 		  </refnamediv>
 		  <refsynopsisdiv>
@@ -326,17 +325,18 @@ F000000000000000000000000000000000000000000000000');
 		  <refsection>
-			<para>Returns the Well-Known Binary representation of the geometry with SRID metadata.  There are 2 variants of the function.  The first
+			<para>Returns the <link linkend="EWKB_EWKT">Extended Well-Known Binary</link> (EWKB) representation of the geometry with SRID metadata.  There are 2 variants of the function.  The first
 			variant takes no endian encoding parameter and defaults to little endian.  The second variant takes a second argument
+			<para>To perform the inverse conversion of EWKB to PostGIS geometry use <xref linkend="ST_GeomFromEWKB" />.</para>
 			<note>
-			  <para>The WKB spec does not include the SRID.  To get the OGC WKB format use ST_AsBinary</para>
-			</note>
-			<note>
-			  <para>ST_AsEWKB is the reverse of ST_GeomFromEWKB.  Use ST_GeomFromEWKB to convert to a postgis geometry from ST_AsEWKB representation.</para>
+			  <para>The OGC/ISO WKB spec does not include the SRID.  To get the OGC WKB format use <xref linkend="ST_AsBinary" /></para>
 			</note>
 			<para>&Z_support;</para>
 			<para>&curve_support;</para>
@@ -352,32 +352,28 @@ F000000000000000000000000000000000000000000000000');
 		   st_asewkb
-\001\003\000\000 \346\020\000\000\001\000
-\000\000\005\000\000\000\000
-\000\000\000\000\000\000\000\000
-\000\000\000\000\000\000\000\000\000
-\000\000\000\000\000\000\000\000\000\000
-\000\000\360?\000\000\000\000\000\000\360?
-\000\000\000\000\000\000\360?\000\000\000\000\000
-\000\360?\000\000\000\000\000\000\000\000\000\000\000
-\000\000\000\000\000\000\000\000\000\000\000\000\000
-(1 row)</programlisting>
+\x0103000020e61000000100000005000000
+000000000000000000000000000000000000
+000000000000000000000000f03f00000000
+0000f03f000000000000f03f000000000000
+f03f000000000000000000000000000000000000000000000000
+</programlisting>
 		<programlisting>
 			SELECT ST_AsEWKB(ST_GeomFromText('POLYGON((0 0,0 1,1 1,1 0,0 0))',4326), 'XDR');
 		   st_asewkb
-\000 \000\000\003\000\000\020\346\000\000\000\001\000\000\000\005\000\000\000\000\
-000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000?
-\360\000\000\000\000\000\000?\360\000\000\000\000\000\000?\360\000\000\000\000
-\000\000?\360\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000
+\x0020000003000010e60000000100000005
+0000000000003ff00000000000003ff00000
+000000003ff00000000000003ff000000000
+0000000000000000000000000000000000000000000000000000
 		</programlisting>
 		  </refsection>
 		  <!-- Optionally add a "See Also" section -->
 		  <refsection>
 			<title>See Also</title>
-			<para><xref linkend="ST_AsBinary" />, <xref linkend="ST_AsEWKT" />, <xref linkend="ST_AsText" />, <xref linkend="ST_GeomFromEWKT" />, <xref linkend="ST_SRID" /></para>
+			<para><xref linkend="ST_AsBinary" />, <xref linkend="ST_GeomFromEWKB" />, <xref linkend="ST_SRID" /></para>
 		  </refsection>
 	</refentry>
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index ea35e6c..2bd6615 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -6,18 +6,18 @@
 	<title>GIS Objects</title>
 	<para>The GIS objects supported by PostGIS are a superset of the "Simple
-	Features" standard defined by the OpenGIS Consortium (OGC).
+	Features" standard defined by the Open Geospatial Consortium (OGC).
 	PostGIS supports all the objects and functions specified in the OGC
 	"Simple Features for SQL" specification (SFS).</para>
 	<para>PostGIS extends the standard with support for embedded SRID information.</para>
 	<sect2 id="OpenGISWKBWKT">
-	  <title>OpenGIS WKB and WKT</title>
+	  <title>OGC WKB and WKT</title>
-	  <para>The OpenGIS specification defines two standard ways of expressing
-	  spatial objects: the Well-Known Text (WKT) form and the Well-Known
-	  Binary (WKB) form. Both WKT and WKB include information about the type
+	  <para>The OGC SFS specification defines two standard ways of expressing
+	  spatial objects: Well-Known Text (WKT) format and Well-Known
+	  Binary (WKB) format. Both WKT and WKB include information about the type
 	  of the object and the coordinates which form the object.</para>
 	  <para>Examples of the text representations (WKT) of the spatial objects
@@ -66,7 +66,7 @@
 		</listitem>
 	  </itemizedlist>
-	  <para>The OpenGIS specification also requires that the internal storage
+	  <para>The OGC specification requires that the internal storage
 	  format of spatial objects include a spatial referencing system
 	  identifier (SRID). The SRID is required when creating spatial objects
 	  for insertion into the database.</para>
@@ -89,31 +89,36 @@ geometry = ST_GeometryFromText(text WKT, SRID);</programlisting>
 	<sect2 id="EWKB_EWKT">
 	  <title>PostGIS EWKB, EWKT and Canonical Forms</title>
-		<para>First OpenGIS specifications (prior to 1.2.0) only support 2D geometries,
-		and the associated SRID is *never* embedded in the input/output representations.</para>
+		<para>OGC specifications prior to 1.2.0 only support 2D geometries,
+		and the associated SRID is *never* included in the input/output representations.</para>
-		<para>Even though the last OpenGIS specification 1.2.1 supports 3DM and 3DZ coordinates
-		specifing ZM qualifiers, it does not include yet the associated SRID in the
+		<para>The OGC specification 1.2.1 (which is aligned with the ISO 19125 standard)
+        supports 3D (ZYZ and XYM) and 4D (XYZM) coordinates
+		via specifing ZM qualifiers.  But it still does not include the SRID in the
-		<para>PostGIS extended formats add 3DM, 3DZ, 4D coordinates support and embedded
-		SRID information. However, PostGIS EWKB/EWKT outputs have several peculiarities:</para>
+		<para>Because of these limitations PostGIS has implemented extended EWKB and EWKT formats.
+        They provide XYZ, XYM, and 4D (XYZM) coordinate support
+        and includes SRID information.
+        Including *all* geometry fields allows PostGIS to use EWKB as the format of record
+        (e.g. in DUMP files).
+        PostGIS EWKT outputs have a few differences to OGC WKT:</para>
 		<itemizedlist>
 			<listitem>
 				<para>For 3DZ geometries they will drop the Z qualifier:</para>
-				<para>OpenGIS: POINT Z (1 2 3)</para>
-				<para>EWKB/EWKT: POINT(1 2 3)</para>
+				<para>OGC: POINT Z (1 2 3)</para>
+				<para>EWKT: POINT(1 2 3)</para>
 			</listitem>
 			<listitem>
 				<para>For 3DM geometries they will keep the M qualifier:</para>
-				<para>OpenGIS: POINT M (1 2 3)</para>
-				<para>EWKB/EWKT: POINTM(1 2 3)</para>
+				<para>OGC: POINT M (1 2 3)</para>
+				<para>EWKT: POINTM(1 2 3)</para>
 			</listitem>
 			<listitem>
 				<para>For 4D geometries they will drop the ZM qualifiers:</para>
-				<para>OpenGIS: POINT ZM (1 2 3 4)</para>
-				<para>EWKB/EWKT: POINT(1 2 3 4)</para>
+				<para>OGC: POINT ZM (1 2 3 4)</para>
+				<para>EWKT: POINT(1 2 3 4)</para>
 			</listitem>
 		</itemizedlist>
@@ -133,9 +138,9 @@ geometry = ST_GeometryFromText(text WKT, SRID);</programlisting>
 		</itemizedlist>
 		<caution>
-			<para>PostGIS extended formats are currently superset of the OGC one (every valid WKB/WKT is a valid EWKB/EWKT)
-			but this might vary in the future, specifically if OGC comes out with a new format conflicting with our
-			extensions. Thus you SHOULD NOT rely on this feature!</para>
+			<para>PostGIS extended formats are currently a superset of the OGC one, so that every valid OGC WKB/WKT is also valid EWKB/EWKT.
+			However, this might vary in the future, specifically if OGC comes out with a new format conflicting with the
+			extensions. Thus you SHOULD NOT rely on this compatibility!</para>
 		</caution>
 	  <para>Examples of the text representations (EWKT) of the extended
Summary of changes:
 doc/introduction.xml          |  2 +-
 doc/postgis.xml               |  2 +-
 doc/reference_output.xml      | 58 ++++++++++++++++++++-----------------------
 doc/using_postgis_dataman.xml | 47 +++++++++++++++++++----------------
 4 files changed, 55 insertions(+), 54 deletions(-)
hooks/post-receive
