[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-153-g05eaa36
Fri Apr 23 11:44:35 PDT 2021
the project "PostGIS".
       via  05eaa361c5a7745d335166bd8e8d708b22103170 (commit)
      from  b10a4673f2168567065c0373ba9534ea2da56f73 (commit)
revisions in full, below.
commit 05eaa361c5a7745d335166bd8e8d708b22103170
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Apr 23 11:44:29 2021 -0700
    Expand POSTGIS_GEOS_VERSION from 39 to 30900 (zero padded minor/patch) so that GEOS 3.10 and future friends do not break things by accident. Closes #4899
diff --git a/configure.ac b/configure.ac
index df75fe6..48ebcd6 100644
--- a/configure.ac
+++ b/configure.ac
@@ -708,14 +708,13 @@ if test "x$GEOS_PATCH_VERSION" = "x"; then
 	GEOS_PATCH_VERSION="0";
 fi
 GEOS_FULL_VERSION=`$GEOSCONFIG --version`
-POSTGIS_GEOS_VERSION="$GEOS_MAJOR_VERSION$GEOS_MINOR_VERSION"
 GEOS_NUMERIC_PATCH_VERSION=`printf "%02d" $GEOS_PATCH_VERSION`
 GEOS_NUMERIC_MINOR_VERSION=`printf "%02d" $GEOS_MINOR_VERSION`
-GEOS_NUMERIC_VERSION="$GEOS_MAJOR_VERSION$GEOS_NUMERIC_MINOR_VERSION$GEOS_NUMERIC_PATCH_VERSION"
+POSTGIS_GEOS_VERSION="$GEOS_MAJOR_VERSION$GEOS_NUMERIC_MINOR_VERSION$GEOS_NUMERIC_PATCH_VERSION"
 dnl Ensure that we are using GEOS >= 3.6.0
 AC_MSG_RESULT([checking GEOS version... $GEOS_FULL_VERSION])
-if test ! "$GEOS_NUMERIC_VERSION" -ge 30600; then
+if test ! "$POSTGIS_GEOS_VERSION" -ge 30600; then
 	AC_MSG_ERROR([PostGIS requires GEOS >= 3.6.0])
 fi
@@ -742,7 +741,6 @@ LIBS="$LIBS_SAVE"
 AC_DEFINE_UNQUOTED([POSTGIS_GEOS_VERSION], [$POSTGIS_GEOS_VERSION], [GEOS library version])
 AC_SUBST([POSTGIS_GEOS_VERSION])
-AC_SUBST([GEOS_NUMERIC_VERSION])
 dnl ===========================================================================
@@ -1695,7 +1693,7 @@ AC_MSG_RESULT([  convert:              ${IMAGEMAGICK}])
 AC_MSG_RESULT([  mathml2.dtd:          ${MATHML2_DTD}])
 AC_MSG_RESULT()
-if test "$GEOS_NUMERIC_VERSION" -lt 30900; then
+if test "$POSTGIS_GEOS_VERSION" -lt 30900; then
 AC_MSG_WARN([ --------- GEOS VERSION WARNING ------------ ])
 AC_MSG_WARN([  You are building against GEOS ${GEOS_FULL_VERSION}.])
 AC_MSG_WARN([])
diff --git a/liblwgeom/cunit/cu_geos.c b/liblwgeom/cunit/cu_geos.c
index 6518f3a..ed648dd 100644
--- a/liblwgeom/cunit/cu_geos.c
+++ b/liblwgeom/cunit/cu_geos.c
@@ -150,7 +150,7 @@ test_geos_makevalid(void)
 	geom3 = lwgeom_normalize(geom2); //so GEOS 3.9 and 3.10 agree
 	out_ewkt = lwgeom_to_ewkt((LWGEOM*)geom3);
-#if POSTGIS_GEOS_VERSION < 39
+#if POSTGIS_GEOS_VERSION < 30900
 	ASSERT_STRING_EQUAL(
 	    out_ewkt,
 	    "GEOMETRYCOLLECTION(POLYGON((92092.377 463437.77,92114.014 463463.469,92115.51207431706 463462.206937429,92115.512 463462.207,92127.546 463452.075,92117.173 463439.755,92133.675 463425.942,92122.136 463412.82600000006,92092.377 463437.77)),MULTIPOINT(92122.136 463412.826,92115.51207431706 463462.2069374289))");
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index 1ab3fc0..5c95561 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -146,7 +146,7 @@ ptarray_from_GEOSCoordSeq(const GEOSCoordSequence* cs, uint8_t want3d)
 	for (i = 0; i < size; i++)
-#if POSTGIS_GEOS_VERSION < 38
+#if POSTGIS_GEOS_VERSION < 30800
 		GEOSCoordSeq_getX(cs, i, &(point.x));
 		GEOSCoordSeq_getY(cs, i, &(point.y));
 		if (dims >= 3) GEOSCoordSeq_getZ(cs, i, &(point.z));
@@ -291,7 +291,7 @@ ptarray_to_GEOSCoordSeq(const POINTARRAY* pa, uint8_t fix_ring)
 			LWDEBUGF(4, "Point: %g,%g", p2d->x, p2d->y);
 		GEOSCoordSeq_setX(sq, i, p2d->x);
 		GEOSCoordSeq_setY(sq, i, p2d->y);
 		if (dims == 3) GEOSCoordSeq_setZ(sq, i, p3d->z);
@@ -315,7 +315,7 @@ ptarray_to_GEOSCoordSeq(const POINTARRAY* pa, uint8_t fix_ring)
 			p2d = getPoint2d_cp(pa, 0);
 		for (i = pa->npoints; i < pa->npoints + append_points; i++)
 #else
@@ -347,7 +347,7 @@ GBOX2GEOS(const GBOX* box)
 	GEOSCoordSequence* seq = GEOSCoordSeq_create(5, 2);
 	if (!seq) return NULL;
 	GEOSCoordSeq_setX(seq, 0, box->xmin);
 	GEOSCoordSeq_setY(seq, 0, box->ymin);
@@ -430,7 +430,7 @@ LWGEOM2GEOS(const LWGEOM* lwgeom, uint8_t autofix)
 			g = GEOSGeom_createEmptyPoint();
 		else
 			sq = ptarray_to_GEOSCoordSeq(lwp->point, 0);
 			g = GEOSGeom_createPoint(sq);
 #else
@@ -575,7 +575,7 @@ make_geos_point(double x, double y)
 	GEOSCoordSeq_setX(seq, 0, x);
 	GEOSCoordSeq_setY(seq, 0, y);
 #else
@@ -595,7 +595,7 @@ make_geos_segment(double x1, double y1, double x2, double y2)
 	GEOSCoordSeq_setX(seq, 0, x1);
 	GEOSCoordSeq_setY(seq, 0, y1);
 	GEOSCoordSeq_setX(seq, 1, x2);
@@ -706,7 +706,7 @@ lwgeom_intersection_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
 	if (!(g2 = LWGEOM2GEOS(geom2, AUTOFIX))) GEOS_FREE_AND_FAIL(g1);
 	if ( prec >= 0) {
 		lwerror("Fixed-precision intersection requires GEOS-3.9 or higher");
 		GEOS_FREE_AND_FAIL(g1, g2);
 		return NULL;
@@ -784,7 +784,7 @@ lwgeom_unaryunion_prec(const LWGEOM* geom, double prec)
 	if (!(g1 = LWGEOM2GEOS(geom, AUTOFIX))) GEOS_FAIL();
 	if ( prec >= 0) {
 		lwerror("Fixed-precision union requires GEOS-3.9 or higher");
 		return NULL;
@@ -836,7 +836,7 @@ lwgeom_difference_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
 	if ( prec >= 0) {
 		lwerror("Fixed-precision difference requires GEOS-3.9 or higher");
 		return NULL;
@@ -887,7 +887,7 @@ lwgeom_symdifference_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
 	if ( prec >= 0) {
 		return NULL;
@@ -946,7 +946,7 @@ lwgeom_centroid(const LWGEOM* geom)
 LWGEOM*
 lwgeom_reduceprecision(const LWGEOM* geom, double gridSize)
 	lwerror("Precision reduction requires GEOS-3.9 or higher");
 	return NULL;
 #else
@@ -1040,7 +1040,7 @@ lwgeom_union_prec(const LWGEOM* geom1, const LWGEOM* geom2, double gridSize)
 	if ( gridSize >= 0) {
 		return NULL;
@@ -1097,7 +1097,7 @@ lwgeom_clip_by_rect(const LWGEOM *geom1, double x1, double y1, double x2, double
 /* ------------ BuildArea stuff ---------------------------------------------------------------------{ */
 typedef struct Face_t
 	const GEOSGeometry* geom;
@@ -1362,7 +1362,7 @@ lwgeom_buildarea(const LWGEOM* geom)
 	g3 = LWGEOM_GEOS_buildArea(g1);
 #else
 	g3 = GEOSBuildArea(g1);
@@ -1760,7 +1760,7 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 			if (x >= bbox.xmax || y >= bbox.ymax) continue;
 			gseq = GEOSCoordSeq_create(1, 2);
 			GEOSCoordSeq_setX(gseq, 0, x);
 			GEOSCoordSeq_setY(gseq, 0, y);
 #else
@@ -2000,7 +2000,7 @@ lwgeom_get_geos_coordseq_2d(const LWGEOM* g, uint32_t num_points)
 			return NULL;
 		if (!GEOSCoordSeq_setX(coords, i, tmp.x) || !GEOSCoordSeq_setY(coords, i, tmp.y))
 #else
 		if (!GEOSCoordSeq_setXY(coords, i, tmp.x, tmp.y))
diff --git a/liblwgeom/lwgeom_geos.h b/liblwgeom/lwgeom_geos.h
index ae21aef..71ec5fe 100644
--- a/liblwgeom/lwgeom_geos.h
+++ b/liblwgeom/lwgeom_geos.h
@@ -34,7 +34,7 @@
 LWGEOM* GEOS2LWGEOM(const GEOSGeometry* geom, uint8_t want3d);
 GEOSGeometry* LWGEOM2GEOS(const LWGEOM* g, uint8_t autofix);
 GEOSGeometry* GBOX2GEOS(const GBOX* g);
 GEOSGeometry* LWGEOM_GEOS_buildArea(const GEOSGeometry* geom_in);
 GEOSGeometry* LWGEOM_GEOS_makeValid(const GEOSGeometry*);
 #endif
diff --git a/liblwgeom/lwgeom_geos_clean.c b/liblwgeom/lwgeom_geos_clean.c
index 3c12e25..7b720a0 100644
--- a/liblwgeom/lwgeom_geos_clean.c
+++ b/liblwgeom/lwgeom_geos_clean.c
@@ -37,7 +37,7 @@
 /* #define PARANOIA_LEVEL 2 */
 #undef LWGEOM_PROFILE_MAKEVALID
  * Return Nth vertex in GEOSGeometry as a POINT.
  * May return NULL if the geometry has NO vertex.
@@ -360,7 +360,7 @@ lwcollection_make_geos_friendly(LWCOLLECTION* g)
 	return (LWGEOM*)ret;
  * Fully node given linework
@@ -932,7 +932,7 @@ lwgeom_make_valid(LWGEOM* lwgeom_in)
 		LWDEBUG(4, "geom converted to GEOS");
 	geosout = LWGEOM_GEOS_makeValid(geosgeom);
 #else
 	geosout = GEOSMakeValid(geosgeom);
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 117ddf0..519797f 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -274,7 +274,7 @@ Datum hausdorffdistancedensify(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(ST_FrechetDistance);
 Datum ST_FrechetDistance(PG_FUNCTION_ARGS)
-#if POSTGIS_GEOS_VERSION < 37
+#if POSTGIS_GEOS_VERSION < 30700
 	lwpgerror("The GEOS version this PostGIS binary "
 					"was compiled against (%d) doesn't support "
@@ -282,7 +282,7 @@ Datum ST_FrechetDistance(PG_FUNCTION_ARGS)
 					POSTGIS_GEOS_VERSION);
 	PG_RETURN_NULL();
-#else /* POSTGIS_GEOS_VERSION >= 37 */
+#else /* POSTGIS_GEOS_VERSION >= 30700 */
 	GSERIALIZED *geom1;
 	GSERIALIZED *geom2;
 	GEOSGeometry *g1;
@@ -330,7 +330,7 @@ Datum ST_FrechetDistance(PG_FUNCTION_ARGS)
 	PG_RETURN_FLOAT8(result);
-#endif /* POSTGIS_GEOS_VERSION >= 37 */
+#endif /* POSTGIS_GEOS_VERSION >= 30700 */
@@ -344,7 +344,7 @@ Datum ST_FrechetDistance(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(ST_MaximumInscribedCircle);
 Datum ST_MaximumInscribedCircle(PG_FUNCTION_ARGS)
@@ -352,7 +352,7 @@ Datum ST_MaximumInscribedCircle(PG_FUNCTION_ARGS)
 	          PG_RETURN_NULL();
-#else /* POSTGIS_GEOS_VERSION >= 39 */
+#else /* POSTGIS_GEOS_VERSION >= 30900 */
 	GSERIALIZED* geom;
 	GSERIALIZED* center;
 	GSERIALIZED* nearest;
@@ -453,7 +453,7 @@ Datum ST_MaximumInscribedCircle(PG_FUNCTION_ARGS)
 	PG_RETURN_DATUM(result);
-#endif /* POSTGIS_GEOS_VERSION >= 39 */
+#endif /* POSTGIS_GEOS_VERSION >= 30900 */
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index a0f50df..21b95dc 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -131,20 +131,20 @@ ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" ">=" 120),1)
 		$(topsrcdir)/regress/core/computed_columns
 endif
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 37),1)
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30700),1)
 	# GEOS-3.7 adds:
 	# ST_FrechetDistance
 	TESTS += \
 		$(topsrcdir)/regress/core/frechet
 endif
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 38),1)
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30800),1)
 	# GEOS-3.8 adds stable pointonsurface implementation
 	TESTS += \
 		$(topsrcdir)/regress/core/geos38
 endif
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 39),1)
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30900),1)
 	# GEOS-3.0 adds stable maximuminscribedcircle implementation
 	TESTS += \
 		$(topsrcdir)/regress/core/geos39 \
diff --git a/topology/test/Makefile.in b/topology/test/Makefile.in
index cef9108..732d01b 100644
--- a/topology/test/Makefile.in
+++ b/topology/test/Makefile.in
@@ -2,7 +2,6 @@ DATABASE=postgis_topo_regress
 PSQL=psql
 PERL=@PERL@
-GEOS_NUMERIC_VERSION=@GEOS_NUMERIC_VERSION@
 # MingW hack: rather than use PGSQL_BINDIR directly, we change to the directory and
 # then use "pwd" to return the path. This ensures that the returned path is in MSYS
Summary of changes:
 configure.ac                  |  8 +++-----
 liblwgeom/cunit/cu_geos.c     |  2 +-
 liblwgeom/lwgeom_geos.c       | 34 +++++++++++++++++-----------------
 liblwgeom/lwgeom_geos.h       |  2 +-
 liblwgeom/lwgeom_geos_clean.c |  6 +++---
 postgis/lwgeom_geos.c         | 12 ++++++------
 regress/core/tests.mk.in      |  6 +++---
 topology/test/Makefile.in     |  1 -
 8 files changed, 34 insertions(+), 37 deletions(-)
hooks/post-receive
