[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-156-g3c622d0
Mon Apr 26 02:32:43 PDT 2021
the project "PostGIS".
       via  3c622d02437567d718b56bf336fdbe77b2e8ec0b (commit)
       via  fb9fa7e9ddb3eb59c7dec63a44a040b4c0e88332 (commit)
       via  fea3aac3989348b85c20a7e59f4d90bd83198035 (commit)
      from  05eaa361c5a7745d335166bd8e8d708b22103170 (commit)
revisions in full, below.
commit 3c622d02437567d718b56bf336fdbe77b2e8ec0b
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Apr 26 11:30:34 2021 +0200
    Add NEWS item
diff --git a/NEWS b/NEWS
index bfc48bc..89ff3c8 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,8 @@ PostGIS 3.2.0
   - #4870, Allow open options to be passed to GDAL drivers (Paul Ramsey)
   - ST_Value() accepts resample parameter to add bilinear option (Paul Ramsey)
   - #3778, #4401, ST_Boundary now works for TIN and does not linearize curves (Aliaksandr Kalenik)
+  - #4881, #4884, Store sign of edge_id for lineal TopoGeometry in relation table
+           to retain direction (Sandro Santilli)
  * New features*
   - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
@@ -20,7 +22,7 @@ PostGIS 3.2.0
     using one of a number of algorithms (inverse weighted distance, average, etc)
     using algorithms from GDAL
     (Paul Ramsey)
-  - ST_Contour() generates contour lines from raster values
+  - ST_Contour() generates contour lines from raster values
     using algorithms from GDAL (Paul Ramsey)
   - ST_SetZ()/ST_SetM() fills in z/m coordinates of a geometry using data read
     from a raster (Paul Ramsey)
commit fb9fa7e9ddb3eb59c7dec63a44a040b4c0e88332
Date:   Mon Apr 26 10:44:06 2021 +0200
    Have TopoGeo_addLinestring return signed edge ids for lineals
    Closes #4884 in main branch (3.2.0dev)
    Update expected results accordingly
    Add specific tests for totopogeom.
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 2c7d3fd..e48bdd4 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -5253,9 +5253,13 @@ lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol)
 /* Return identifier of an equal edge, 0 if none or -1 on error
  * (and lwerror gets called on error)
+ * If an equal edge is found, specify, in "forward" variable whether
+ * the edge is also equal direction-wise
 static LWT_ELEMID
-_lwt_GetEqualEdge( LWT_TOPOLOGY *topo, LWLINE *edge )
+_lwt_GetEqualEdge( LWT_TOPOLOGY *topo, LWLINE *edge, int *forward )
   LWT_ELEMID id;
   LWT_ISO_EDGE *edges;
@@ -5307,6 +5311,40 @@ _lwt_GetEqualEdge( LWT_TOPOLOGY *topo, LWLINE *edge )
       if ( equals )
         id = e->edge_id;
+        /* Check if direction also matches */
+        if ( forward )
+          /* If input line is closed, we use winding order */
+          if ( lwline_is_closed(edge) )
+            if ( ptarray_isccw(edge->points) == ptarray_isccw(e->geom->points) )
+              *forward = 1;
+            else
+              *forward = 0;
+          else
+            /* Input line is not closed, checking fist point is enough */
+            if (
+              memcmp(
+                  getPoint_internal(edge->points, 0),
+                  getPoint_internal(e->geom->points, 0),
+                  sizeof(POINT2D)
+              ) == 0
+              *forward = 1;
+            else
+              *forward = 0;
         GEOSGeom_destroy(edgeg);
         _lwt_release_edges(edges, num);
         return id;
@@ -5327,10 +5365,16 @@ _lwt_GetEqualEdge( LWT_TOPOLOGY *topo, LWLINE *edge )
  *        if the newly added edge would split a face and if so
  *        would create new faces accordingly. Otherwise it will
  *        set left_face and right_face to null (-1)
+ * @param forward output parameter, will be populated if
+ *        a pre-existing edge was found in the topology,
+ *        in which case a value of 1 means the incoming
+ *        line will have the same direction of the edge,
+ *        and 0 that the incomine line has opposite direction
 static LWT_ELEMID
 _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
-                  int handleFaceSplit )
+                  int handleFaceSplit, int *forward )
   LWCOLLECTION *col;
   LWPOINT *start_point, *end_point;
@@ -5456,7 +5500,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   /* check if the so-snapped edge _now_ exists */
-  id = _lwt_GetEqualEdge ( topo, edge );
+  id = _lwt_GetEqualEdge ( topo, edge, forward );
   LWDEBUGF(1, "_lwt_GetEqualEdge returned %" LWTFMT_ELEMID, id);
   if ( id == -1 )
@@ -5490,7 +5534,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
     /* check if the so-decimated edge _now_ exists */
     if ( id == -1 )
@@ -5515,6 +5559,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   lwgeom_free(tmp); /* possibly takes "edge" down with it */
+  *forward = 1;
   return id;
@@ -5557,6 +5602,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
   uint64_t num, numedges = 0, numnodes = 0;
   uint64_t i;
   GBOX qbox;
+  int forward;
   *nedges = -1; /* error condition, by default */
@@ -5842,7 +5888,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
 #endif
-    id = _lwt_AddLineEdge( topo, lwgeom_as_lwline(g), tol, handleFaceSplit );
+    id = _lwt_AddLineEdge( topo, lwgeom_as_lwline(g), tol, handleFaceSplit, &forward );
     LWDEBUGF(1, "_lwt_AddLineEdge returned %" LWTFMT_ELEMID, id);
     if ( id < 0 )
@@ -5856,9 +5902,9 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
       continue;
-    LWDEBUGF(1, "Component %d of split line is edge %" LWTFMT_ELEMID,
-                  i, id);
-    ids[num++] = id; /* TODO: skip duplicates */
+    LWDEBUGF(1, "Component %d of split line is %s edge %" LWTFMT_ELEMID,
+                  i, forward ? "forward" : "backward", id);
+    ids[num++] = forward ? id : -id; /* TODO: skip duplicates */
   LWDEBUGG(1, noded, "Noded before free");
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index d786940..9c09021 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -71,7 +71,7 @@ crossover|E|LINESTRING(9 20,16.2 14)
 crossover|E|LINESTRING(9 14,9 18)
 crossover|E|LINESTRING(9 18,9 20)
 crossover_again|4
-contains|25
+contains|-25
 contains|46
 contains|47
 contains|N||POINT(7 36)
@@ -139,7 +139,7 @@ iso_ex_2segs|28
 #1650.2|N||POINT(0 0)
 #1650.2|N||POINT(0 1)
 #1650.2|E|LINESTRING(0 0,0 1)
-#1650.3|65
+#1650.3|-65
 #1650.3|66
 #1650.3|N||POINT(10 0)
 #1650.3|E|LINESTRING(0 0,10 0)
diff --git a/topology/test/regress/totopogeom.sql b/topology/test/regress/totopogeom.sql
index 91bb7cf..f72d58d 100644
--- a/topology/test/regress/totopogeom.sql
+++ b/topology/test/regress/totopogeom.sql
@@ -221,6 +221,25 @@ SELECT '#3359.area.1', ST_Area(toTopoGeom('POLYGON ((0 0,1 0,1 1,0 1,0 0))'
 SELECT '#3359.area.2', ST_Area(toTopoGeom('POLYGON ((0 0,1 0,1 2,0 2,0 0))'
 ::geometry, 'tt', 4));
+-- http://trac.osgeo.org/postgis/ticket/4884
+TRUNCATE tt.relation CASCADE;
+TRUNCATE tt.edge_data CASCADE;
+TRUNCATE tt.node CASCADE;
+DELETE FROM tt.face WHERE face_id > 0;
+SELECT '#4884.setval',
+       setval('tt.edge_data_edge_id_seq', 1, false),
+       -- face_id is intentionally set to 2
+       setval('tt.face_face_id_seq', 2, false),
+       setval('tt.node_node_id_seq', 1, false);
+SELECT '#4884.l2r', ST_AsText(toTopoGeom('LINESTRING (0 0,1 0)' ::geometry, 'tt', 3));
+SELECT '#4884.r2l', ST_AsText(toTopoGeom('LINESTRING (1 0,0 0)' ::geometry, 'tt', 3));
+-- Cleanups
 DROP TABLE tt.f_coll;
 DROP TABLE tt.f_areal;
 DROP TABLE tt.f_lineal;
diff --git a/topology/test/regress/totopogeom_expected b/topology/test/regress/totopogeom_expected
index bda0c3a..6ba1e0a 100644
--- a/topology/test/regress/totopogeom_expected
+++ b/topology/test/regress/totopogeom_expected
@@ -49,4 +49,7 @@ tgup1.3|5|200|4
 #3359.line.2|2
 #3359.area.1|1
 #3359.area.2|2
+#4884.setval|1|2|1
+#4884.l2r|MULTILINESTRING((0 0,1 0))
+#4884.r2l|MULTILINESTRING((1 0,0 0))
 Topology 'tt' dropped
commit fea3aac3989348b85c20a7e59f4d90bd83198035
Date:   Fri Mar 12 09:20:11 2021 +0100
    Rewrite TopoGeometry::geometry cast for lineals to retain direction
    Includes test
    Closes #4881 in main branch (3.2.0dev)
diff --git a/topology/test/regress/geometry_cast.sql b/topology/test/regress/geometry_cast.sql
index 5e65870..6ec9d07 100644
--- a/topology/test/regress/geometry_cast.sql
+++ b/topology/test/regress/geometry_cast.sql
@@ -4,35 +4,35 @@ set client_min_messages to WARNING;
 select NULL FROM createtopology('tt', 4326);
 -- layer 1 is PUNTUAL
-CREATE TABLE tt.f_point(id serial);
+CREATE TABLE tt.f_point(lbl text primary key);
 SELECT NULL FROM AddTopoGeometryColumn('tt', 'tt', 'f_point', 'g', 'POINT');
 -- layer 2 is LINEAL
-CREATE TABLE tt.f_line(id serial);
+CREATE TABLE tt.f_line(lbl text primary key );
 SELECT NULL FROM AddTopoGeometryColumn('tt', 'tt', 'f_line', 'g', 'LINE');
 -- layer 3 is AREAL
-CREATE TABLE tt.f_area(id serial);
+CREATE TABLE tt.f_area(lbl text primary key);
 SELECT NULL FROM AddTopoGeometryColumn('tt', 'tt', 'f_area', 'g', 'POLYGON');
 -- layer 4 is MIXED
-CREATE TABLE tt.f_coll(id serial);
+CREATE TABLE tt.f_coll(lbl text primary key);
 SELECT NULL FROM AddTopoGeometryColumn('tt', 'tt', 'f_coll', 'g', 'COLLECTION');
 -- layer 5 is HIERARCHICAL PUNTUAL
-CREATE TABLE tt.f_hier_point(id serial);
+CREATE TABLE tt.f_hier_point(lbl text primary key);
 SELECT NULL FROM AddTopoGeometryColumn('tt', 'tt', 'f_hier_point', 'g', 'POINT', 1);
 -- layer 6 is HIERARCHICAL LINEAL
-CREATE TABLE tt.f_hier_line(id serial);
+CREATE TABLE tt.f_hier_line(lbl text primary key);
 SELECT NULL FROM AddTopoGeometryColumn('tt', 'tt', 'f_hier_line', 'g', 'LINE', 2);
 -- layer 7 is HIERARCHICAL AREAL
-CREATE TABLE tt.f_hier_area(id serial);
+CREATE TABLE tt.f_hier_area(lbl text primary key);
 SELECT NULL FROM AddTopoGeometryColumn('tt', 'tt', 'f_hier_area', 'g', 'POLYGON', 3);
 -- layer 8 is HIERARCHICAL MIXED
-CREATE TABLE tt.f_hier_coll(id serial);
+CREATE TABLE tt.f_hier_coll(lbl text primary key);
 SELECT NULL FROM AddTopoGeometryColumn('tt', 'tt', 'f_hier_coll', 'g', 'COLLECTION', 4);
@@ -47,5 +47,80 @@ SELECT 'empty', 'hier', 'lineal', ST_AsEWKT(CreateTopoGeom('tt', 2, 6)::geometry
 SELECT 'empty', 'hier', 'areal', ST_AsEWKT(CreateTopoGeom('tt', 3, 7)::geometry);
 SELECT 'empty', 'hier', 'mixed', ST_AsEWKT(CreateTopoGeom('tt', 4, 8)::geometry);
+-- Cast directed lineal
+-- See https://trac.osgeo.org/postgis/ticket/4881
+-- Insert 3 horizontal edge going in mixed directions
+-- Odd ids: left-to-right
+-- Even ids: right-to-left
+INSERT INTO tt.node(node_id, containing_face, geom) VALUES
+( 1, NULL, 'SRID=4326;POINT(1 0)' ),
+( 2, NULL, 'SRID=4326;POINT(2 0)' ),
+( 3, NULL, 'SRID=4326;POINT(3 0)' ),
+( 4, NULL, 'SRID=4326;POINT(4 0)' )
+SELECT NULL FROM setval('tt.node_node_id_seq', 3);
+INSERT INTO tt.edge(
+  edge_id, start_node, end_node,
+  next_left_edge, next_right_edge,
+  left_face, right_face,
+  geom
+VALUES (
+  1, 1, 2,
+  -2, 1,
+  0, 0,
+  'SRID=4326;LINESTRING(0 0, 1 0)'
+  2, 3, 2,
+  -1, 2,
+  0, 0,
+  'SRID=4326;LINESTRING(2 0, 1 0)'
+  3, 3, 4,
+  -3, 2,
+  0, 0,
+  'SRID=4326;LINESTRING(2 0, 3 0)'
+SELECT NULL FROM setval('tt.edge_data_edge_id_seq', 2);
+-- Insert two lines using the horizontal edge
+-- in opposite directions
+INSERT INTO tt.f_line(lbl, g) VALUES (
+  'dir.2r', CreateTopoGeom('tt', 2, 2, '{{1,2},{-2,2},{3,2}}')
+  'dir.2l', CreateTopoGeom('tt', 2, 2, '{{-1,2},{-3,2},{2,2}}')
+  'dir.multi.2r', CreateTopoGeom('tt', 2, 2, '{{1,2},{3,2}}')
+  'dir.multi.2l', CreateTopoGeom('tt', 2, 2, '{{-1,2},{-3,2}}')
+  'dir.multi.converge', CreateTopoGeom('tt', 2, 2, '{{1,2},{-3,2}}')
+  'dir.multi.diverge', CreateTopoGeom('tt', 2, 2, '{{-1,2},{3,2}}')
+-- Check out lines are rendered with direction
+-- based on their signed element_id
+SELECT
+  '#4881',
+  'E',
+  e.edge_id,
+  ST_AsText(e.geom)
+FROM tt.edge e
+ORDER BY e.edge_id;
+SELECT
+  '#4881',
+  l.lbl,
+  ST_AsEWKT(ST_CollectionHomogenize(l.g::geometry)),
+  array_agg(r.element_id ORDER BY abs(r.element_id))
+FROM tt.f_line l, tt.relation r
+WHERE lbl like 'dir.%'
+AND r.topogeo_id = id(l.g)
+GROUP BY 1,2,3
+ORDER BY lbl;
 -- Cleanup
 SELECT NULL FROM DropTopology('tt');
diff --git a/topology/test/regress/geometry_cast_expected b/topology/test/regress/geometry_cast_expected
index b692443..4ef94e4 100644
--- a/topology/test/regress/geometry_cast_expected
+++ b/topology/test/regress/geometry_cast_expected
@@ -6,3 +6,12 @@ empty|hier|puntal|SRID=4326;MULTIPOINT EMPTY
 empty|hier|lineal|SRID=4326;MULTILINESTRING EMPTY
 empty|hier|areal|SRID=4326;MULTIPOLYGON EMPTY
 empty|hier|mixed|SRID=4326;GEOMETRYCOLLECTION EMPTY
+#4881|E|1|LINESTRING(0 0,1 0)
+#4881|E|2|LINESTRING(2 0,1 0)
+#4881|E|3|LINESTRING(2 0,3 0)
+#4881|dir.2l|SRID=4326;LINESTRING(3 0,2 0,1 0,0 0)|{-1,2,-3}
+#4881|dir.2r|SRID=4326;LINESTRING(0 0,1 0,2 0,3 0)|{1,-2,3}
+#4881|dir.multi.2l|SRID=4326;MULTILINESTRING((1 0,0 0),(3 0,2 0))|{-1,-3}
+#4881|dir.multi.2r|SRID=4326;MULTILINESTRING((0 0,1 0),(2 0,3 0))|{1,3}
+#4881|dir.multi.converge|SRID=4326;MULTILINESTRING((0 0,1 0),(3 0,2 0))|{1,-3}
+#4881|dir.multi.diverge|SRID=4326;MULTILINESTRING((1 0,0 0),(2 0,3 0))|{-1,3}
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index aa3383f..4f01bc0 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1343,15 +1343,30 @@ AND element_type = 3
   ELSIF topogeom.type = 2 THEN -- [multi]line -- }{
-    sql :=
-      'SELECT st_multi(ST_LineMerge(ST_Collect(e.geom))) as g FROM '
-      || quote_ident(toponame) || '.edge e, '
-      || quote_ident(toponame) || '.relation r '
-         ' WHERE r.topogeo_id = ' || topogeom.id
-      || ' AND r.layer_id = ' || topogeom.layer_id
-      || ' AND r.element_type = 2 '
-         ' AND abs(r.element_id) = e.edge_id';
-    EXECUTE sql INTO geom;
+    sql := format(
+SELECT
+  st_multi(
+    ST_LineMerge(
+      ST_Collect(
+        CASE
+          WHEN r.element_id > 0 THEN
+            e.geom
+          ELSE
+            ST_Reverse(e.geom)
+        END
+  ) as g
+FROM %1$I.edge e, %1$I.relation r
+WHERE r.topogeo_id = id($1)
+AND r.layer_id = layer_id($1)
+AND r.element_type = 2
+AND abs(r.element_id) = e.edge_id
+      toponame
+    EXECUTE sql USING topogeom INTO geom;
   ELSIF topogeom.type = 1 THEN -- [multi]point -- }{
Summary of changes:
 NEWS                                               |  4 +-
 liblwgeom/lwgeom_topo.c                            | 62 +++++++++++++--
 topology/test/regress/geometry_cast.sql            | 91 ++++++++++++++++++++--
 topology/test/regress/geometry_cast_expected       |  9 +++
 .../test/regress/topogeo_addlinestring_expected    |  4 +-
 topology/test/regress/totopogeom.sql               | 19 +++++
 topology/test/regress/totopogeom_expected          |  3 +
 topology/topology.sql.in                           | 33 +++++---
 8 files changed, 197 insertions(+), 28 deletions(-)
hooks/post-receive
