[postgis-tickets] [PostGIS] #4901: Regress failure on GEOS 3.10+
PostGIS trac at osgeo.org
Tue Apr 27 15:13:50 PDT 2021
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.2.0
Component:  postgis  |    Version:  master
 Keywords:           |
 test_lwgeom_clip_by_rect ...FAILED
 15:11:14     1. cu_clip_by_rect.c:72  - CU_ASSERT_PTR_NULL(out)
 Both debbie and winnie are showing this error and I tested with winnie's
 geos build and also showed the error.
 This is with geos version:
 https://git.osgeo.org/gitea/geos/geos/commit/f3dfbdc949dbe954c818e63abceb4e493ab396ff
 Will close this out if @pramsey commit of 5 minutes ago fixes the issue
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4901>
