[postgis-tickets] [PostGIS] #4890: ST_Transform large slow down from upgrade to 3.1.1 from 2.4
PostGIS trac at osgeo.org
Tue Apr 27 16:08:10 PDT 2021
  Reporter:  SAbernethy  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.1.2
 Component:  postgis     |    Version:  3.1.x
Resolution:              |   Keywords:
Comment (by pramsey):
 With respect to ST_Area(geometry::geography) I have confirmed that the
 **cast** portion of the query hits the same object cache as the
 ST_Transform() function, so it is also subject to initialization overhead.
 (Because in order to case to geography you have to confirm that the SRID
 is in fact a geographic CRS, so you need to look it up, and that requires
 initializing the proj database, which incurs the cost.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4890#comment:12>
