[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-387-g177de9c
Thu Aug 5 11:31:44 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  177de9ca1c1f4fa6cc57271c5810bcc26ebade84 (commit)
      from  876e74cd8617cd75b79b2708867fcc70ffa75b01 (commit)
revisions in full, below.
commit 177de9ca1c1f4fa6cc57271c5810bcc26ebade84
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Aug 5 20:28:41 2021 +0200
    Run more population functions, support for --nodrop
diff --git a/topology/test/check_multiprocess_topology_population.sh b/topology/test/check_multiprocess_topology_population.sh
index 7a93f1f..c685568 100755
--- a/topology/test/check_multiprocess_topology_population.sh
+++ b/topology/test/check_multiprocess_topology_population.sh
@@ -2,35 +2,79 @@
 # TODO: turn to perl ?
+KEEPTOPO=0
+if test "$1" = "--nodrop"; then
+  KEEPTOPO=1
+fi
 export PGOPTIONS='-c client_min_messages=WARNING';
 PSQL_OPTS="-tA"
 cleanup() {
-  #echo 'Cleaning up'
-  psql ${PSQL_OPTS} -c "SELECT NULL FROM DropTopology('mt_topo');" | grep -v '^$'
+  echo 'Cleaning up'
+  if test "$KEEPTOPO" = 0; then
+    psql ${PSQL_OPTS} -c "SELECT NULL FROM DropTopology('mt_topo');" | grep -v '^$'
+  fi
+  rm -f pids.$$
 trap cleanup EXIT
+#psql ${PSQL_OPTS} -c "SELECT NULL FROM DropTopology('mt_topo');" | grep -v '^$'
 psql ${PSQL_OPTS} -c "SELECT NULL FROM CreateTopology('mt_topo')" > /dev/null
 # $RANDOM: random integer between 0 and 32767
-for x in `seq 1 4`; do
-  for y in `seq 1 4`; do
-    cat <<EOF | psql ${PSQL_OPTS} | grep -v '^$' &
+for x in `seq 0 10 40`; do
+  for y in `seq 0 10 40`; do
+      # Add polygon
+      cat <<EOF | psql ${PSQL_OPTS} | grep -v '^$' &
+SELECT NULL FROM
+    topology.TopoGeo_addPolygon(
+      'mt_topo',
+      ST_Buffer(
+        ST_MakePoint(
+          ${x},
+          ${y}
+        8
+EOF
+      echo $! >> pids.$$
+      # Add horizontal edge
+SELECT NULL FROM
+    topology.TopoGeo_addLineString(
+      'mt_topo',
+       ST_MakeLine(
+         ST_MakePoint(
+            ${x} - 6,
+            ${y} + 1
+         ST_MakePoint(
+            ${x} + 6,
+            ${y} + 1
+EOF
+      # Add isolated node in the middle of the polygon added before
 SELECT NULL FROM
-  topology.TopoGeo_addPolygon(
-    'mt_topo',
-    ST_Buffer(
-      ST_MakePoint(
-        ${x} ,
-        ${y}
-      10000
+    topology.TopoGeo_addPoint(
+      'mt_topo',
+       ST_MakePoint(
+          ${x},
+          ${y}
 EOF
-    echo $! >> pids.$$
   done
 done
@@ -41,5 +85,7 @@ done
 rm -f pids.$$
 psql ${PSQL_OPTS} -c "SELECT TopologySummary('mt_topo')" | grep -v '^$'
-psql ${PSQL_OPTS} -c "SELECT 'INVALIDITY', * FROM ValidateTopology('mt_topo')" | grep -v '^$'
+echo "-- INVALIDITIES START --"
+psql ${PSQL_OPTS} -c "SELECT * FROM ValidateTopology('mt_topo')" | grep -v '^$'
+echo "-- INVALIDITIES END --"
Summary of changes:
 .../test/check_multiprocess_topology_population.sh | 80 +++++++++++++++++-----
 1 file changed, 63 insertions(+), 17 deletions(-)
hooks/post-receive
