[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-388-g6eeee12
Tue Aug 10 06:27:48 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  6eeee128815a61c6ad08635c4586d5f6f58a010d (commit)
      from  177de9ca1c1f4fa6cc57271c5810bcc26ebade84 (commit)
revisions in full, below.
commit 6eeee128815a61c6ad08635c4586d5f6f58a010d
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Aug 10 15:27:19 2021 +0200
    Fix PROTOBUF_LDFLAGS in absence of pkg-config
    Closes #4964
diff --git a/configure.ac b/configure.ac
index 95f92d3..2356ab7 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1025,7 +1025,7 @@ if test "$CHECK_PROTOBUF" != "no"; then
 	AC_ARG_WITH([protobuf-lib],
 		[AS_HELP_STRING([--with-protobuf-lib=PATH], [libprotobuf-c.so/dll/dylib library installation directory])], [
-			PROTOBUF_LDFLAGS="-L$withval -lprotobuf-c"
+			PROTOBUF_LDFLAGS="-L$withval"
 	if test -n "$PROTOBUF_CPPFLAGS"; then
@@ -1043,7 +1043,8 @@ if test "$CHECK_PROTOBUF" != "no"; then
 	dnl confirm that discovered/configured library path works
-	AC_CHECK_LIB([protobuf-c], [protobuf_c_message_init], [],
+	AC_CHECK_LIB([protobuf-c], [protobuf_c_message_init],
+		[PROTOBUF_LDFLAGS="-lprotobuf-c"],
 		AC_MSG_ERROR([unable to link protobuf-c using $LDFLAGS. You can disable MVT and Geobuf support using --without-protobuf])
 		HAVE_PROTOBUF=no
Summary of changes:
 configure.ac | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
