[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-391-gd3f5c2e
Wed Aug 11 03:49:12 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  d3f5c2e14c450ee0ca8f7f8dbd30f1f1b8ce1ae0 (commit)
      from  db1d141fa287987a0526a1d9b08939ce523965cf (commit)
revisions in full, below.
commit d3f5c2e14c450ee0ca8f7f8dbd30f1f1b8ce1ae0
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 11 12:14:21 2021 +0200
    Add regress test for GetFaceContainingPoint near collinear incoming segment
diff --git a/topology/test/regress/getfacecontainingpoint.sql b/topology/test/regress/getfacecontainingpoint.sql
index 8f23503..9763a2d 100644
--- a/topology/test/regress/getfacecontainingpoint.sql
+++ b/topology/test/regress/getfacecontainingpoint.sql
@@ -48,6 +48,9 @@ SELECT 't7', topology.GetFaceContainingPoint('city_data', 'POINT(32 16.9)');
 -- Query point in hole touching shell, near edge having hole on the right
 SELECT 't8', topology.GetFaceContainingPoint('city_data', 'POINT(24 16.9)');
+-- Query point collinear with closest incoming segment (right of next one)
+SELECT 't9', topology.GetFaceContainingPoint('city_data', 'POINT(7.1 31)');
 -- Query point on a node incident to multiple faces
 SELECT 'e1', topology.GetFaceContainingPoint('city_data', 'POINT(21 14)');
@@ -61,4 +64,5 @@ SELECT 'e3', topology.GetFaceContainingPoint('city_data', 'POINT(28 14)');
 SELECT 'e4', topology.GetFaceContainingPoint('city_data', 'POINT(28 22)');
 SELECT NULL FROM topology.DropTopology('city_data');
diff --git a/topology/test/regress/getfacecontainingpoint_expected b/topology/test/regress/getfacecontainingpoint_expected
index 65bc5a8..251363c 100644
--- a/topology/test/regress/getfacecontainingpoint_expected
+++ b/topology/test/regress/getfacecontainingpoint_expected
@@ -17,6 +17,7 @@ t5|2
 t6|0
 t7|11
 t8|4
+t9|1
 ERROR:  Two or more faces found
Summary of changes:
 topology/test/regress/getfacecontainingpoint.sql      | 4 ++++
 topology/test/regress/getfacecontainingpoint_expected | 1 +
 2 files changed, 5 insertions(+)
hooks/post-receive
