[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-394-gb565cc6
Wed Aug 11 07:28:29 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  b565cc631df71e8e8081a747e5dd211c486e2f35 (commit)
       via  6f9afe7e25c561ebcc0cdc009d305133cf2bb279 (commit)
       via  ec3f582abbf9d22d07338521317f8ab94d144c29 (commit)
      from  d3f5c2e14c450ee0ca8f7f8dbd30f1f1b8ce1ae0 (commit)
revisions in full, below.
commit b565cc631df71e8e8081a747e5dd211c486e2f35
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Aug 10 13:58:18 2021 +0200
    Rewrite GetFaceContainingPoint in C
    Closes #4962
diff --git a/liblwgeom/liblwgeom_topo.h b/liblwgeom/liblwgeom_topo.h
index 665e9c5..c49ba0b 100644
--- a/liblwgeom/liblwgeom_topo.h
+++ b/liblwgeom/liblwgeom_topo.h
@@ -18,7 +18,7 @@
- * Copyright (C) 2015-2017 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2015-2021 Sandro Santilli <strk at kbt.io>
@@ -357,20 +357,6 @@ typedef struct LWT_BE_CALLBACKS_T {
   LWT_ISO_FACE *(*getFaceById)(const LWT_BE_TOPOLOGY *topo, const LWT_ELEMID *ids, uint64_t *numelems, int fields);
-   * Get face containing point
-   * @param topo the topology to act upon
-   * @param pt the query point
-   * @return a face identifier (0 if no face contains the point)
-   *         or -1 on error (@see lastErrorMessage)
-  LWT_ELEMID (*getFaceContainingPoint) (
-      const LWT_BE_TOPOLOGY* topo,
-      const LWPOINT* pt
    * Update TopoGeometry objects after an edge split event
@@ -846,6 +832,27 @@ typedef struct LWT_BE_CALLBACKS_T {
       LWT_ELEMID rem_edge
+   * Get closest edge to a given point
+   * @param topo the topology to act upon
+   * @param pt the query point
+   * @param numelems output parameter, gets number of elements found
+   *                 or UINT64_MAX on error (@see lastErrorMessage)
+   * @param fields fields to be filled in the returned structure, see
+   *               LWT_COL_EDGE_* macros
+   * @return an array of 1 edges or null in the following cases:
+	 *				 - no edges are in the topology ("numelems" is set to 0)
+   *         - error ("numelems" is set to UINT64_MAX)
+  LWT_ISO_EDGE *(*getClosestEdge)(const LWT_BE_TOPOLOGY *topo,
+					   const LWPOINT *pt,
+					   uint64_t *numelems,
+					   int fields);
 } LWT_BE_CALLBACKS;
@@ -993,7 +1000,20 @@ LWT_ELEMID lwt_GetEdgeByPoint(LWT_TOPOLOGY *topo, LWPOINT *pt, double tol);
  *         or edge).
  *         The liblwgeom error handler will be invoked in case of error.
-LWT_ELEMID lwt_GetFaceByPoint(LWT_TOPOLOGY *topo, LWPOINT *pt, double tol);
+LWT_ELEMID lwt_GetFaceByPoint(LWT_TOPOLOGY *topo, const LWPOINT *pt, double tol);
+ * Find the face-id of the face properly containing a given point
+ * @param topo the topology to operate on
+ * @param point the point to use for query
+ * @return a face identifier if one is found (0 if universe), -1
+ *         on error (point intersects non-dangling edge).
+ *         The liblwgeom error handler will be invoked in case of error.
+LWT_ELEMID lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt);
diff --git a/liblwgeom/liblwgeom_topo_internal.h b/liblwgeom/liblwgeom_topo_internal.h
index de26433..cbd7ade 100644
--- a/liblwgeom/liblwgeom_topo_internal.h
+++ b/liblwgeom/liblwgeom_topo_internal.h
@@ -66,7 +66,7 @@ int lwt_be_ExistsEdgeIntersectingPoint(LWT_TOPOLOGY* topo, LWPOINT* pt);
 LWT_ELEMID lwt_be_getNextEdgeId(LWT_TOPOLOGY* topo);
 LWT_ISO_EDGE *lwt_be_getEdgeById(LWT_TOPOLOGY *topo, const LWT_ELEMID *ids, uint64_t *numelems, int fields);
 LWT_ISO_EDGE *lwt_be_getEdgeWithinDistance2D(LWT_TOPOLOGY *topo,
-					     LWPOINT *pt,
 					     double dist,
 					     uint64_t *numelems,
 					     int fields,
@@ -77,8 +77,6 @@ lwt_be_updateEdges(LWT_TOPOLOGY* topo, const LWT_ISO_EDGE* sel_edge, int sel_fie
 int
 lwt_be_deleteEdges(LWT_TOPOLOGY* topo, const LWT_ISO_EDGE* sel_edge, int sel_fields);
-LWT_ELEMID lwt_be_getFaceContainingPoint(LWT_TOPOLOGY* topo, LWPOINT* pt);
 int lwt_be_updateTopoGeomEdgeSplit(LWT_TOPOLOGY* topo, LWT_ELEMID split_edge, LWT_ELEMID new_edge1, LWT_ELEMID new_edge2);
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 8b7e2cd..427aad8 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -248,7 +248,7 @@ lwt_be_getNodeByFace(LWT_TOPOLOGY *topo, const LWT_ELEMID *ids, uint64_t *numele
 LWT_ISO_EDGE *
-			       LWPOINT *pt,
 			       double dist,
 			       uint64_t *numelems,
 			       int fields,
@@ -319,13 +319,6 @@ lwt_be_deleteEdges(LWT_TOPOLOGY* topo,
   CBT2(topo, deleteEdges, sel_edge, sel_fields);
-LWT_ELEMID
-lwt_be_getFaceContainingPoint(LWT_TOPOLOGY* topo, LWPOINT* pt)
-  CBT1(topo, getFaceContainingPoint, pt);
 int
@@ -387,9 +380,6 @@ lwt_be_getRingEdges(LWT_TOPOLOGY *topo, LWT_ELEMID edge, uint64_t *numedges, uin
   CBT3(topo, getRingEdges, edge, numedges, limit);
-/* wrappers of backend wrappers... */
 int
 lwt_be_ExistsCoincidentNode(LWT_TOPOLOGY* topo, LWPOINT* pt)
@@ -416,6 +406,12 @@ lwt_be_ExistsEdgeIntersectingPoint(LWT_TOPOLOGY* topo, LWPOINT* pt)
   return exists;
+static LWT_ISO_EDGE *
+lwt_be_getClosestEdge(const LWT_TOPOLOGY *topo, const LWPOINT *pt, uint64_t *numelems, int fields)
+  CBT3(topo, getClosestEdge, pt, numelems, fields);
  * Utility functions
@@ -554,7 +550,7 @@ _lwt_AddIsoNode( LWT_TOPOLOGY* topo, LWT_ELEMID face,
   if ( checkFace && ( face == -1 || ! skipISOChecks ) )
-    foundInFace = lwt_be_getFaceContainingPoint(topo, pt); /*x*/
+    foundInFace = lwt_GetFaceContainingPoint(topo, pt); /*x*/
     if ( foundInFace == -1 ) {
       lwerror("Backend error: %s", lwt_be_lastErrorMessage(topo->be_iface));
       return -1;
@@ -3632,7 +3628,7 @@ lwt_MoveIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID nid, LWPOINT *pt)
   /* Check that the new point is in the same containing face !
    * See https://trac.osgeo.org/postgis/ticket/3232 */
-  newPointFace = lwt_be_getFaceContainingPoint(topo, pt);
+  newPointFace = lwt_GetFaceContainingPoint(topo, pt);
   if ( newPointFace == -1 ) {
     return -1;
@@ -4803,7 +4799,7 @@ lwt_GetEdgeByPoint(LWT_TOPOLOGY *topo, LWPOINT *pt, double tol)
 LWT_ELEMID
-lwt_GetFaceByPoint(LWT_TOPOLOGY *topo, LWPOINT *pt, double tol)
+lwt_GetFaceByPoint(LWT_TOPOLOGY *topo, const LWPOINT *pt, double tol)
   LWT_ELEMID id = 0;
   LWT_ISO_EDGE *elem;
@@ -4814,7 +4810,7 @@ lwt_GetFaceByPoint(LWT_TOPOLOGY *topo, LWPOINT *pt, double tol)
              LWT_COL_EDGE_FACE_RIGHT;
   LWGEOM *qp = lwpoint_as_lwgeom(pt);
-  id = lwt_be_getFaceContainingPoint(topo, pt);
+  id = lwt_GetFaceContainingPoint(topo, pt);
   if ( id == -1 ) {
     return -1;
@@ -7054,3 +7050,238 @@ lwt_Polygonize(LWT_TOPOLOGY* topo)
   return 0;
+LWT_ELEMID
+lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
+  LWT_ISO_EDGE* closestEdge;
+  LWT_ISO_EDGE* edges;
+  uint64_t numedges;
+  LWGEOM *shortestLine;
+  const POINT2D *shortestLineP0, *shortestLineP1;
+  int closestSegmentIndex;
+  int closestSegmentSide;
+  const POINT2D *closestSegmentP0, *closestSegmentP1;
+  double shortestLineAzimuth;
+  LWPOINT *closestPointOnEdge;
+  LWPOINT *closestEdgeEndpoint;
+  LWT_ELEMID closestNode = 0;
+  double dist;
+  int containingFace = -1;
+  int i;
+  closestEdge = lwt_be_getClosestEdge( topo, pt, &numedges,
+    LWT_COL_EDGE_GEOM|
+    LWT_COL_EDGE_EDGE_ID|
+    LWT_COL_EDGE_START_NODE|
+    LWT_COL_EDGE_END_NODE|
+    LWT_COL_EDGE_FACE_LEFT|
+    LWT_COL_EDGE_FACE_RIGHT
+  if (numedges == UINT64_MAX)
+	  lwerror("Backend error: %s", lwt_be_lastErrorMessage(topo->be_iface));
+    /* cberror(topo->be_data, "Error from cb_getClosestEdge"); */
+	  return -1;
+  if (numedges == 0)
+    /* If there are no edges the point is in the universal face */
+    return 0;
+  /* Compute shortest line from query point to closest edge */
+  shortestLine = lwgeom_closest_line(lwline_as_lwgeom(closestEdge->geom), lwpoint_as_lwgeom(pt));
+  LWDEBUGGF(1, shortestLine, "Shortest line to closest edge %d", closestEdge->edge_id);
+  /* Check if the closest point on the edge is an edge endpoint */
+  closestPointOnEdge = lwline_get_lwpoint(lwgeom_as_lwline(shortestLine), 0);
+  LWDEBUGG(1, lwpoint_as_lwgeom(closestPointOnEdge), "Closest point on closest edge");
+  closestEdgeEndpoint = lwline_get_lwpoint(closestEdge->geom, 0);
+  if ( lwpoint_same(closestEdgeEndpoint, closestPointOnEdge) ) {
+    closestNode = closestEdge->start_node;
+  } else if ( ! lwline_is_closed(closestEdge->geom) ) {
+    lwpoint_free(closestEdgeEndpoint);
+    closestEdgeEndpoint = lwline_get_lwpoint(closestEdge->geom, closestEdge->geom->points->npoints - 1);
+      closestNode = closestEdge->end_node;
+  lwpoint_free(closestPointOnEdge);
+  if ( closestNode != 0 )
+    LWDEBUGF(1, "Closest point is node %d", closestNode);
+    dist = lwgeom_length(shortestLine);
+    if ( dist == 0 )
+      lwgeom_free(shortestLine);
+      LWDEBUGF(1, "Query point is node %d", closestNode);
+      /* Query point is the node
+       * If all edges incident to the node are
+       * dangling, we can return their common
+       * side face, otherwise the point will be
+       * on multiple face boundaries
+      if ( closestEdge->face_left != closestEdge->face_right )
+        _lwt_release_edges(closestEdge, 1);
+        lwerror("Two or more faces found");
+        return -1;
+      containingFace = closestEdge->face_left;
+      /* Check other incident edges */
+      numedges = 1;
+      edges = lwt_be_getEdgeByNode( topo, &closestNode, &numedges, LWT_COL_EDGE_FACE_LEFT|LWT_COL_EDGE_FACE_RIGHT );
+        lwerror("Backend error from getEdgeByNode: %s", lwt_be_lastErrorMessage(topo->be_iface));
+        return -1;
+      for (i=0; i<numedges; ++i)
+        if ( edges[i].face_left != containingFace ||
+             edges[i].face_right != containingFace )
+          _lwt_release_edges(edges, numedges);
+          return -1;
+      if (numedges < 1 )
+        lwerror("Unexpected backend return: getEdgeByNode(%d) returns no edges when we previously found edge %d ending on that node",
+          closestNode, closestEdge->edge_id);
+        return -1;
+      LWDEBUGF(1, "lwt_be_getEdgeByNode returned %d edges", numedges);
+      return containingFace;
+    /* Closest point is a node, but query point is NOT on the node */
+    /* let's do azimuth computation */
+    shortestLineP0 = getPoint2d_cp(((LWLINE *)shortestLine)->points, 0);
+    shortestLineP1 = getPoint2d_cp(((LWLINE *)shortestLine)->points, 1);
+    if ( ! azimuth_pt_pt(shortestLineP0, shortestLineP1, &shortestLineAzimuth) ) {
+      lwerror("error computing azimuth of shortestLine [%.15g %.15g,%.15g %.15g]",
+              shortestLineP0->x, shortestLineP0->y,
+              shortestLineP1->x, shortestLineP1->y);
+      return -1;
+    LWDEBUGF(1, "ShortestLine azimuth is %g", shortestLineAzimuth);
+    edgeend ee;
+    ee.myaz = shortestLineAzimuth;
+    int found = _lwt_FindAdjacentEdges( topo, closestNode, &ee, NULL, -1 );
+    if ( ! found ) {
+        lwerror("Unexpected backend return: _lwt_FindAdjacentEdges(%d) found no edges when we previously found edge %d ending on that node",
+        return -1;
+    return ee.cwFace;
+  LWDEBUGF(1, "Closest point is NOT a node", closestNode);
+  /* If this edge has the same face on the left and right sides
+   * we found the face containing our query point */
+  if ( closestEdge->face_left == closestEdge->face_right )
+  if ( dist == 0 )
+    /* We checked the dangling case above */
+    return -1;
+  /* find closest segment on closestEdge and use lw_segment_side
+   * to determine on which side our query point falls */
+  shortestLineP0 = getPoint2d_cp(((LWLINE *)shortestLine)->points, 1);
+  closestSegmentIndex = ptarray_closest_segment_2d(closestEdge->geom->points, shortestLineP0, NULL);
+  LWDEBUGF(1, "Closest segment to edge %d is %d", closestEdge->edge_id, closestSegmentIndex);
+  closestSegmentP0 = getPoint2d_cp(closestEdge->geom->points, closestSegmentIndex);
+  closestSegmentP1 = getPoint2d_cp(closestEdge->geom->points, ++closestSegmentIndex);
+  LWDEBUGF(1, "Closest segment to edge %d is LINESTRING(%g %g, %g %g)",
+    closestEdge->edge_id,
+    closestSegmentP0->x,
+    closestSegmentP0->y,
+    closestSegmentP1->x,
+    closestSegmentP1->y
+  /* Find on which side of the segment the query point lays */
+  do {
+    containingFace = -1;
+    LWDEBUGF(1, "Calling lw_segment_side((%g,%g),(%g,%g),(%g,%g)",
+      closestSegmentP1->y,
+      shortestLineP1->y
+    closestSegmentSide = lw_segment_side(closestSegmentP0, closestSegmentP1, shortestLineP1);
+    LWDEBUGF(1, "Side of closest segment query point falls on: %d", closestSegmentSide);
+    if ( closestSegmentSide == -1 ) /* left */
+      break;
+    else if ( closestSegmentSide == 1 ) /* right */
+      containingFace = closestEdge->face_right;
+      break;
+    /* If the point was collinear to the closest segment
+     * we need to check the next segment, as if this was
+     * the last one we would have entered a previous branch
+     * selecting the case in which the closest point is
+     * a NODE, and ptarray_closest_segment_2d should be
+     * always returning the *first* segment so there must
+     * be a next one.
+    closestSegmentP0 = closestSegmentP1;
+  } while (1);
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index d23831d..9f0756d 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -3,7 +3,7 @@
  * PostGIS - Spatial Types for PostgreSQL
  * http://postgis.net
- * Copyright (C) 2015 Sandro Santilli <strk at kbt.io>
  * This is free software; you can redistribute and/or modify it under
  * the terms of the GNU General Public Licence. See the COPYING file.
@@ -2976,66 +2976,85 @@ cb_updateTopoGeomEdgeHeal ( const LWT_BE_TOPOLOGY* topo,
   return 1;
-static LWT_ELEMID
-cb_getFaceContainingPoint( const LWT_BE_TOPOLOGY* topo, const LWPOINT* pt )
+/* Return pointer to closest edge.
+ * NULL if no edges are in the topology (*numelems=0).
+ * or there's an error (*numedges=UINT64_MAX)
+cb_getClosestEdge( const LWT_BE_TOPOLOGY* topo, const LWPOINT* pt, uint64_t *numedges, int fields )
   MemoryContext oldcontext = CurrentMemoryContext;
+  HeapTuple row;
   int spi_result;
   StringInfoData sqldata;
   StringInfo sql = &sqldata;
-  bool isnull;
-  Datum dat;
-  LWT_ELEMID face_id;
   GSERIALIZED *pts;
-  Datum values[2];
-  Oid argtypes[2];
-  text *toponameText;
-  initStringInfo(sql);
+  Datum values[1];
+  Oid argtypes[1];
   pts = geometry_serialize(lwpoint_as_lwgeom(pt));
   if ( ! pts )
     cberror(topo->be_data, "%s:%d: could not serialize query point",
             __FILE__, __LINE__);
-    return -1;
+    *numedges = UINT64_MAX;
+    return NULL;
-  appendStringInfo(sql, "SELECT topology.GetFaceContainingPoint($1, $2)");
-  toponameText = cstring_to_text(topo->name);
-  values[0] = PointerGetDatum(toponameText);
-  argtypes[0] = TEXTOID;
+  initStringInfo(sql);
-  values[1] = PointerGetDatum(pts);
-  argtypes[1] = topo->geometryOID;
+  /* TODO: avoid executing ST_ShortestLine twice (to be confirmed it
+   *       if it is called twice
+  appendStringInfoString(sql, "SELECT ");
+  addEdgeFields(sql, fields, 0);
+  appendStringInfo(sql, " FROM \"%s\".edge_data ORDER BY ", topo->name);
+#if POSTGIS_PGSQL_VERSION < 95
+  appendStringInfo(sql, "ST_Length(ST_ShortestLine(geom, $1))");
+#else
+  appendStringInfo(sql, "geom <-> $1");
+#endif
-  spi_result = SPI_execute_with_args(sql->data, 2, argtypes, values, NULL,
+  appendStringInfo(sql, " ASC, edge_id ASC LIMIT 1");
+  POSTGIS_DEBUGF(1, "cb_getClosestEdge query: %s", sql->data);
+  values[0] = PointerGetDatum(pts);
+  argtypes[0] = topo->geometryOID;
+  spi_result = SPI_execute_with_args(sql->data, 1, argtypes, values, NULL,
                                      !topo->be_data->data_changed, 1);
   MemoryContextSwitchTo( oldcontext ); /* switch back */
   pfree(pts); /* not needed anymore */
-  if ( spi_result != SPI_OK_SELECT || SPI_processed != 1 )
+  if ( spi_result != SPI_OK_SELECT )
     cberror(topo->be_data, "unexpected return (%d) from query execution: %s",
             spi_result, sql->data);
     pfree(sqldata.data);
-    return -1;
+    return NULL;
-  dat = SPI_getbinval( SPI_tuptable->vals[0],
-                       SPI_tuptable->tupdesc, 1, &isnull );
-  if ( isnull )
+  if ( SPI_processed == 0 )
-    SPI_freetuptable(SPI_tuptable);
-    cberror(topo->be_data, "unexpected return (%d) from query execution: %s",
-            spi_result, sql->data);
+    /* No edges in topology, point is in universal face */
-    return -1;
+    *numedges = 0;
+    return NULL;
-  pfree(sqldata.data);
-  face_id = DatumGetInt32(dat);
+  /* Got closest edge, return it */
+  *numedges = 1;
+  edges = palloc( sizeof(LWT_ISO_EDGE) );
+  row = SPI_tuptable->vals[0];
+  fillEdgeFields(edges, row, SPI_tuptable->tupdesc, fields);
-  return face_id;
+  return edges;
 static int
@@ -3389,7 +3408,6 @@ static LWT_BE_CALLBACKS be_callbacks =
   cb_insertEdges,
   cb_updateEdges,
   cb_getFacesById,
-  cb_getFaceContainingPoint,
   cb_updateTopoGeomEdgeSplit,
   cb_deleteEdges,
   cb_getNodeWithinBox2D,
@@ -3415,7 +3433,8 @@ static LWT_BE_CALLBACKS be_callbacks =
   cb_updateTopoGeomEdgeHeal,
   cb_getFaceWithinBox2D,
   cb_checkTopoGeomRemIsoNode,
-  cb_checkTopoGeomRemIsoEdge
+  cb_checkTopoGeomRemIsoEdge,
+  cb_getClosestEdge
 static void
@@ -5314,3 +5333,64 @@ Datum GetRingEdges(PG_FUNCTION_ARGS)
   SRF_RETURN_NEXT(funcctx, result);
+/*  GetFaceContainingPoint(atopology, point) */
+Datum GetFaceContainingPoint(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(GetFaceContainingPoint);
+  text* toponame_text;
+  char* toponame;
+  LWT_ELEMID face_id;
+  GSERIALIZED *geom;
+  LWGEOM *lwgeom;
+  LWPOINT *pt;
+  LWT_TOPOLOGY *topo;
+  toponame_text = PG_GETARG_TEXT_P(0);
+  toponame = text_to_cstring(toponame_text);
+  PG_FREE_IF_COPY(toponame_text, 0);
+  geom = PG_GETARG_GSERIALIZED_P(1);
+  lwgeom = lwgeom_from_gserialized(geom);
+  pt = lwgeom_as_lwpoint(lwgeom);
+  if ( ! pt )
+    lwgeom_free(lwgeom);
+    PG_FREE_IF_COPY(geom, 1);
+    lwpgerror("Second argument must be a point geometry");
+    PG_RETURN_NULL();
+  if ( SPI_OK_CONNECT != SPI_connect() )
+    lwpgerror("Could not connect to SPI");
+    PG_RETURN_NULL();
+  topo = lwt_LoadTopology(be_iface, toponame);
+  pfree(toponame);
+  if ( ! topo )
+    /* should never reach this point, as lwerror would raise an exception */
+    SPI_finish();
+    PG_RETURN_NULL();
+  POSTGIS_DEBUG(1, "Calling lwt_GetFaceContainingPoint");
+  face_id = lwt_GetFaceContainingPoint(topo, pt);
+  POSTGIS_DEBUG(1, "lwt_GetFaceContainingPoint returned");
+  lwt_FreeTopology(topo);
+  if ( face_id == -1 )
+    SPI_finish();
+    PG_RETURN_NULL();
+  SPI_finish();
+  PG_RETURN_INT32(face_id);
diff --git a/topology/sql/query/GetFaceContainingPoint.sql.in b/topology/sql/query/GetFaceContainingPoint.sql.in
index 86c6337..bd48bd2 100644
--- a/topology/sql/query/GetFaceContainingPoint.sql.in
+++ b/topology/sql/query/GetFaceContainingPoint.sql.in
@@ -25,287 +25,6 @@ CREATE OR REPLACE FUNCTION topology.GetFaceContainingPoint(
   atopology text,
   apoint geometry
-RETURNS INT
-AS $BODY$
-DECLARE
-  closestEdge RECORD;
-  closestCWEdgeEnd RECORD;
-  rec RECORD;
-  closestNode INT;
-  azimuth FLOAT8;
-  closestVertex GEOMETRY;
-  lastDistance FLOAT8;
-  ringLeft GEOMETRY;
-  ringRight GEOMETRY;
-  sql TEXT;
-BEGIN
-  sql := format(
-  SELECT
-    edge_id,
-    geom, -- for Start/EndPoint query
-    start_node,
-    end_node,
-    left_face,
-    right_face,
-    ST_ShortestLine(geom, $1) AS shortestLine,
-    ST_Length(ST_ShortestLine(geom, $1)) AS dist
-  FROM %1$I.edge
-  ORDER BY
-#if POSTGIS_PGSQL_VERSION < 95
-#else
-    geom <-> $1
-#endif
-  ASC,
-  edge_id ASC
-  LIMIT 1
-    atopology
-#ifdef POSTGIS_TOPOLOGY_DEBUG
-  RAISE DEBUG 'Query: %', sql;
-  RAISE DEBUG 'Point: %', ST_AsEWKT(apoint);
-#endif
-  EXECUTE sql
-  USING apoint
-  INTO closestEdge;
-  IF closestEdge IS NULL
-  THEN
-    -- If no edge is found the point
-    -- is in the universal face
-    RETURN 0;
-  END IF;
-  -- Check if the closest vertex is a node
-  closestVertex := ST_StartPoint(closestEdge.shortestLine);
-  IF ST_Equals(closestVertex, ST_StartPoint(closestEdge.geom))
-  THEN
-    closestNode := closestEdge.start_node;
-  ELSIF ST_Equals(closestVertex, ST_EndPoint(closestEdge.geom))
-  THEN
-    closestNode := closestEdge.end_node;
-  END IF;
-  RAISE DEBUG 'Closest edge is %, shortest line is % (length %)',
-    closestEdge.edge_id,
-    ST_AsEWKT(closestEdge.shortestLine),
-    closestEdge.dist
-#endif
-  IF closestNode IS NOT NULL
-  THEN --{ Closest point is a node
-    RAISE DEBUG 'Closest point is node %', closestNode;
-    IF closestEdge.dist = 0
-    THEN --{ Query point is the node
-      -- If all edges incident to the node are
-      -- dangling, we can return their common
-      -- side face, otherwise the point will be
-      -- on multiple face boundaries
-      -- early exit if the closest edge has
-      -- left_face != right_face, don't bother
-      -- fetching more edges
-      IF closestEdge.left_face != closestEdge.right_face THEN
-        RAISE EXCEPTION 'Two or more faces found';
-      END IF;
-      sql := format(
-          SELECT
-            left_face,
-            right_face
-          FROM %1$I.edge_data
-          WHERE (
-            start_node = $1
-            OR end_node = $1
-          AND (
-            left_face != $2
-            OR right_face != $2
-          LIMIT 1
-        atopology
-      RAISE DEBUG 'SQL: %', sql;
-#endif
-      EXECUTE sql USING closestNode, closestEdge.left_face INTO rec;
-      IF FOUND
-      THEN
-      END IF;
-      RETURN closestEdge.left_face;
-    END IF; --} query point is the node
-    -- Compute azimuth of segment going from node to query point
-    azimuth := ST_Azimuth(
-      ST_StartPoint( closestEdge.shortestLine),
-      ST_EndPoint(closestEdge.shortestLine)
-    RAISE DEBUG 'Closest point is disjoint from node %, shortestLine has azimuth %',
-      closestNode,
-      azimuth;
-    sql := format(
-        WITH incident_edges AS (
-          SELECT
-            edge_id,
-            start_node,
-            end_node,
-            left_face,
-            right_face,
-            ST_RemoveRepeatedPoints(geom) as geom
-          WHERE start_node = $1
-          OR end_node = $1
-        ), incident_edges_with_azdiff AS (
-          SELECT
-            edge_id,
-            left_face,
-            right_face,
-            ST_Azimuth(ST_StartPoint(geom), ST_PointN(geom, 2)) - %2$L as azdiff
-          FROM
-            incident_edges WHERE start_node = $1
-          UNION ALL
-          SELECT
-            -edge_id,
-            left_face,
-            right_face,
-            ST_Azimuth(ST_EndPoint(geom), ST_PointN(geom, ST_NumPoints(geom)-1)) - %2$L
-          FROM incident_edges WHERE end_node = $1
-        SELECT
-          edge_id,
-          left_face,
-          right_face,
-          CASE WHEN azdiff < 0 THEN
-            azdiff + 2 * PI()
-          ELSE
-            azdiff
-          END az
-        FROM incident_edges_with_azdiff
-        ORDER BY az ASC
-        LIMIT 1
-      atopology,
-      azimuth
-    EXECUTE sql USING closestNode INTO closestCWEdgeEnd;
-    RAISE DEBUG 'Adjiacent edge in CW direction is %, with azimuth %',
-      closestCWEdgeEnd.edge_id,
-      closestCWEdgeEnd.az
-    -- Return the face on the appropriate side of the
-    -- most adjiacent edge end
-    IF closestCWEdgeEnd.edge_id > 0 THEN --{{
-      -- Edge starts on given node, so we pick its left face
-      RETURN closestCWEdgeEnd.left_face;
-    ELSE -- }{
-      -- Edge ends on given node, so we pick its right face
-      RETURN closestCWEdgeEnd.right_face;
-    END IF; -- }}
-  END IF; --} closest point is a node
-  -- If this edge has the same face on the left and right sides
-  -- we found the face containing our query point
-  IF closestEdge.left_face = closestEdge.right_face
-  THEN
-  END IF;
-  -- The query point intersects an edge
-  IF closestEdge.dist = 0 THEN
-    -- We checked the dangling case above
-  END IF;
-  -- TODO: use ST_LineCrossingDirection instead of building rings ?
-  -- Beware of https://trac.osgeo.org/postgis/ticket/4935
-  -- Compute rings on the left and on the right of the closest edge
-  sql := format(
-      WITH ring AS (
-        SELECT * FROM topology.GetRingEdges(%1$L, $1)
-      ), edges AS (
-        SELECT
-          r.sequence,
-          CASE WHEN r.edge > 0 THEN
-            e.geom
-          ELSE
-            ST_Reverse(e.geom)
-          END as geom
-        FROM
-          ring r,
-          %1$I.edge e
-        WHERE e.edge_id = abs(r.edge)
-      SELECT ST_MakePolygon(
-        ST_MakeLine(
-          geom
-          ORDER BY sequence
-      FROM edges
-    atopology
-  BEGIN
-    EXECUTE sql USING closestEdge.edge_id INTO ringLeft;
-  EXCEPTION WHEN OTHERS THEN
-    IF SQLERRM like '%shell must have at least%' THEN
-      RAISE EXCEPTION 'Corrupted topology: ring on the left side of edge % is invalid: %',
-        closestEdge.edge_id, SQLERRM;
-    ELSE
-      RAISE EXCEPTION 'Could not build ring on the left side of edge %: %',
-    END IF;
-  END;
-  BEGIN
-    EXECUTE sql USING -closestEdge.edge_id INTO ringRight;
-      RAISE EXCEPTION 'Corrupted topology: ring on the right side of edge % is invalid: %',
-    ELSE
-      RAISE EXCEPTION 'Could not build ring on the right side of edge %: %',
-    END IF;
-  END;
-  IF ST_IsPolygonCCW(ringLeft) THEN -- ring on left is a shell
-    IF ST_Contains(ringLeft, apoint) THEN
-    ELSE
-      RETURN closestEdge.right_face;
-    END IF;
-  ELSE -- ring on the right is a shell
-    IF ST_Contains(ringRight, apoint) THEN
-    ELSE
-    END IF;
-  END IF;
-  RETURN 0; -- anything not in a face is in the universal face
-END;
-$BODY$ LANGUAGE 'plpgsql';
+RETURNS INT AS
+	'MODULE_PATHNAME', 'GetFaceContainingPoint'
+LANGUAGE 'c' STABLE;
commit 6f9afe7e25c561ebcc0cdc009d305133cf2bb279
Date:   Wed Aug 11 11:26:13 2021 +0200
    Add ptarray_closest_segment_2d lwgeom API function
    Includes unit test
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index 01b1f46..c393577 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -685,6 +685,43 @@ static void test_ptarray_closest_vertex_2d()
   lwline_free(line);
+static void test_ptarray_closest_segment_2d()
+	LWLINE *line;
+	POINTARRAY *pa;
+	double dist;
+	POINT2D qp;
+	const char *wkt;
+	int rv;
+	wkt = "LINESTRING (0 0 0, 1 0 0, 2 0 0, 3 0 10)";
+	line = lwgeom_as_lwline(lwgeom_from_text(wkt));
+	pa = line->points;
+	qp.x = qp.y = 0;
+	rv = ptarray_closest_segment_2d(pa, &qp, &dist);
+	ASSERT_INT_EQUAL(rv, 0);
+	ASSERT_DOUBLE_EQUAL(dist, 0);
+	qp.x = 1;
+	qp.y = 1;
+	ASSERT_DOUBLE_EQUAL(dist, 1);
+	qp.x = 5; qp.y = 0;
+	ASSERT_INT_EQUAL(rv, 2);
+	ASSERT_DOUBLE_EQUAL(dist, 2);
+  lwline_free(line);
 ** Used by the test harness to register the tests in this file.
@@ -704,4 +741,5 @@ void ptarray_suite_setup(void)
 	PG_ADD_TEST(suite, test_ptarray_scale);
 	PG_ADD_TEST(suite, test_ptarray_scroll);
 	PG_ADD_TEST(suite, test_ptarray_closest_vertex_2d);
+	PG_ADD_TEST(suite, test_ptarray_closest_segment_2d);
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index f2a148c..c074d8b 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1097,6 +1097,16 @@ extern POINTARRAY *ptarray_substring(POINTARRAY *pa, double d1, double d2,
 extern int ptarray_closest_vertex_2d(const POINTARRAY *pa,
                                      const POINT2D *qp, double *dist);
+ * @param pa the subject pointarray
+ * @param qp the query point
+ * @param dist optional output for actual distance from segment
+ * @return 0-based segment index for the closest segment
+ *         (earliest segment in case of same distance)
+extern int ptarray_closest_segment_2d(const POINTARRAY *pa,
+                                      const POINT2D *qp, double *dist);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index db99148..b58c8b2 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -1296,6 +1296,39 @@ closest_point_on_segment(const POINT4D *p, const POINT4D *A, const POINT4D *B, P
 int
+ptarray_closest_segment_2d(const POINTARRAY *pa, const POINT2D *qp, double *dist)
+	const POINT2D *start = getPoint2d_cp(pa, 0), *end = NULL;
+	uint32_t t, seg=0;
+	double mindist=DBL_MAX;
+	/* Loop through pointarray looking for nearest segment */
+	for (t=1; t<pa->npoints; t++)
+		double dist_sqr;
+		end = getPoint2d_cp(pa, t);
+		dist_sqr = distance2d_sqr_pt_seg(qp, start, end);
+		if (dist_sqr < mindist)
+			mindist = dist_sqr;
+			seg=t-1;
+			if ( mindist == 0 )
+				LWDEBUG(3, "Breaking on mindist=0");
+				break;
+		start = end;
+	if ( dist ) *dist = sqrt(mindist);
+	return seg;
+int
 ptarray_closest_vertex_2d(const POINTARRAY *pa, const POINT2D *qp, double *dist)
 	uint32_t t, pn=0;
commit ec3f582abbf9d22d07338521317f8ab94d144c29
Date:   Wed Aug 11 15:15:20 2021 +0200
    Ensure getEdgeByNode correctly initializes the "geom" field
index 7374e89..d23831d 100644
@@ -809,6 +809,10 @@ fillEdgeFields(LWT_ISO_EDGE* edge, HeapTuple row, TupleDesc rowdesc, int fields)
       edge->geom = NULL;
+  else
+      edge->geom = NULL;
 static void
Summary of changes:
 liblwgeom/cunit/cu_ptarray.c                     |  38 +++
 liblwgeom/liblwgeom.h.in                         |  10 +
 liblwgeom/liblwgeom_topo.h                       |  52 ++--
 liblwgeom/liblwgeom_topo_internal.h              |   4 +-
 liblwgeom/lwgeom_topo.c                          | 261 +++++++++++++++++++--
 liblwgeom/ptarray.c                              |  33 +++
 topology/postgis_topology.c                      | 150 +++++++++---
 topology/sql/query/GetFaceContainingPoint.sql.in | 287 +----------------------
 8 files changed, 484 insertions(+), 351 deletions(-)
hooks/post-receive
