[postgis-tickets] [PostGIS] #4575: GRANT select on topology metadata tables to public
PostGIS trac at osgeo.org
Thu Aug 12 08:55:08 PDT 2021
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  reopened
  Priority:  medium    |  Milestone:  PostGIS 3.2.0
 Component:  topology  |    Version:  main
Resolution:            |   Keywords:
Comment (by strk):
 I'm thinking as an alternative we could make the CreateTopology function a
 SECURITY DEFINER and have the code check if the user has permission to
 create schemas (as creating a topology at the moment means creating a
 schema...).
 Everything is located under topology schema for cleanness (I'd love to
 also see "postgis" under a "postgis" schema, but PostGIS predates the time
 when PostgreSQL added support for schemas...)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4575#comment:12>
