[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.5-20-gad02524
Sun Aug 15 16:22:52 PDT 2021
the project "PostGIS".
The branch, stable-2.5 has been updated
       via  ad02524990e605271f73731b4e509b9db81660be (commit)
      from  447e6ee9ab961d6d5566699b2a880a66b6eaf609 (commit)
revisions in full, below.
commit ad02524990e605271f73731b4e509b9db81660be
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Aug 15 19:22:47 2021 -0400
    Backport Raúl Marín CUnit fixes.  References #4971 for PostGIS 2.5.6
diff --git a/NEWS b/NEWS
index c98c44e..10d569a 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,7 @@ YYYY/MM/DD
   - #4769, Fix segfault in st_addband (Raúl Marín)
   - #4863, Update bboxes after affine/scale operations (Paul Ramsey)
   - #4326, Fix CircularPolygon area calculation (Paul Ramsey)
+  - #4971, Cunit fixes for newer CUnit (Raúl Marín, Regina Obe)
 PostGIS 2.5.5
diff --git a/liblwgeom/cunit/cu_tester.h b/liblwgeom/cunit/cu_tester.h
index c5e6ccf..862bc09 100644
--- a/liblwgeom/cunit/cu_tester.h
+++ b/liblwgeom/cunit/cu_tester.h
@@ -10,6 +10,9 @@
+#ifndef _CU_TESTER_H
+#define _CU_TESTER_H 1
 #include "liblwgeom.h"
 #define MAX_CUNIT_ERROR_LENGTH 512
@@ -17,7 +20,7 @@
 #define PG_ADD_TEST(suite, testfunc) CU_add_test(suite, #testfunc, testfunc)
 /* Contains the most recent error message generated by lwerror. */
-char cu_error_msg[MAX_CUNIT_ERROR_LENGTH+1];
+extern char cu_error_msg[];
 /* Resets cu_error_msg back to blank. */
 void cu_error_msg_reset(void);
@@ -87,3 +90,5 @@ typedef void (*PG_SuiteSetup)(void);
 /* Utility functions */
 void do_fn_test(LWGEOM* (*transfn)(LWGEOM*), char *input_wkt, char *expected_wkt);
+#endif /* _CU_TESTER_H */
Summary of changes:
 NEWS                        | 1 +
 liblwgeom/cunit/cu_tester.h | 7 ++++++-
 2 files changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
