[postgis-tickets] [PostGIS] #4972: debbie failing on regress PostGIS 2.4 +WARNING: 'postgis.backend' is already set and cannot be changed
PostGIS trac at osgeo.org
Sun Aug 15 18:25:57 PDT 2021
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 2.4.10
Component:  buildbots  |    Version:  2.4.x
 Keywords:             |
 Now that have cunit issues cleared out of the way, sadly debbie is still
 unhappy with 2.4.  Now it's failing at regress - but looks to be the
 upgrade regress - earlier passed fine
  -------------- Dependencies --------------
 20:52:23   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.7w64/bin/geos-config
 20:52:23   GEOS version:         3.7.4dev
 20:52:23   GDAL config:
 /var/lib/jenkins/workspace/gdal/rel-2.4w64/bin/gdal-config
 20:52:23   GDAL version:         2.4.4
 20:52:23   SFCGAL config:        /usr/bin/sfcgal-config
 20:52:23   SFCGAL version:       1.3.8
 20:52:23   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg10w64/bin/pg_config
 20:52:23   PostgreSQL version:   PostgreSQL 10.18
 20:52:23   PROJ4 version:        72
 20:52:23   Libxml2 config:       /usr/bin/xml2-config
 20:52:23   Libxml2 version:      2.9.12
 20:52:23   JSON-C support:       yes
 20:52:23   protobuf-c support:   yes
 20:52:23   protobuf-c version:   1003003
 20:52:23   PCRE support:         no
 20:52:23   Perl:                 /usr/bin/perl
 20:52:23
 20:52:23  --------------- Extensions ---------------
 20:52:23   PostGIS Raster:       enabled
 20:52:23   PostGIS Topology:     enabled
 20:52:23   SFCGAL support:       enabled
 20:52:23   Address Standardizer support:       disabled
 20:52:23
 20:52:23  -------- Documentation Generation --------
 20:52:23   xsltproc:             /usr/bin/xsltproc
 20:52:23   xsl style sheets:     /usr/share/xml/docbook/stylesheet
 /docbook-xsl
 20:52:23   dblatex:              /usr/bin/dblatex
 20:52:23   convert:              /usr/bin/convert
 20:52:23   mathml2.dtd:
 /usr/share/xml/schema/w3c/mathml/dtd/mathml2.dtd
 21:10:59  legacy .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10w64/test_47_diff)
 21:10:59
 21:10:59 --- legacy_expected    2019-10-31 14:10:38.264865818 +0000
 21:10:59 +++
 /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10w64/test_47_out
 2021-08-16 01:10:59.874336674 +0000
 21:10:59 @@ -1,3 +1,4 @@
 21:10:59 +WARNING:  'postgis.backend' is already set and cannot be changed
 until you reconnect at character 192
 21:10:59  Starting up MapServer/Geoserver tests...
 21:10:59  Setting up the data table...
 21:10:59  public.wmstest.pt SRID:4326 TYPE:POLYGON DIMS:2
 21:10:59
 21:11:57  sfcgal/legacy .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10w64/test_127_diff)
 21:11:58
 21:11:58 --- sfcgal/legacy_expected     2019-10-31 14:10:38.364864952
 +0000
 21:11:58 +++
 /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10w64/test_127_out
 2021-08-16 01:11:58.756509908 +0000
 21:11:58 @@ -1,3 +1,4 @@
 21:11:58 +WARNING:  'postgis.backend' is already set and cannot be changed
 21:11:58  Starting up MapServer/Geoserver tests...
 21:11:58  Setting up the data table...
 21:11:58  public.wmstest.pt SRID:4326 TYPE:POLYGON DIMS:2
 21:11:58
 maybe it's just an intermittent that will go away if I retest. Although
 her 2.4 has been broken for a while because of the cunit issue so it might
 have been something else introduced in PostGIS or PostgreSQL proper
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4972>
