[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-407-g1c03eb6
Fri Aug 20 11:27:27 PDT 2021
the project "PostGIS".
       via  1c03eb65188d33db061d7d9d91243d0e6e848022 (commit)
       via  6624a9f94887b81cb60efbe0ef73f4186081f6d5 (commit)
      from  5272174764c2d8c304612c85ef33d3dcf758682d (commit)
revisions in full, below.
commit 1c03eb65188d33db061d7d9d91243d0e6e848022
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Aug 20 14:27:22 2021 -0400
    Fix proto should be a 4 point with 4th geometry being optional. Closes #4976
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 1635b3f..c59ae82 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -212,7 +212,7 @@ SELECT degrees(ST_Azimuth( ST_Point(25, 45),  ST_Point(75, 100))) AS degA_B,
 			  <paramdef><type>geometry </type><parameter>point1</parameter></paramdef>
 			  <paramdef><type>geometry </type><parameter>point2</parameter></paramdef>
 			  <paramdef><type>geometry </type><parameter>point3</parameter></paramdef>
-			  <paramdef choice="opt"><type>geometry </type><parameter>point4=POINT(EMPTY)</parameter></paramdef>
+			  <paramdef choice="opt"><type>geometry </type><parameter>point4</parameter></paramdef>
 			</funcprototype>
 			<funcprototype>
 			  <funcdef>float <function>ST_Angle</function></funcdef>
commit 6624a9f94887b81cb60efbe0ef73f4186081f6d5
Date:   Fri Aug 20 14:25:25 2021 -0400
    Fix proto should be a 4  point with 4th geometry being optional and defaulting to point empty
index 223a21b..1635b3f 100644
@@ -212,13 +212,7 @@ SELECT degrees(ST_Azimuth( ST_Point(25, 45),  ST_Point(75, 100))) AS degA_B,
-			</funcprototype>
-			<funcprototype>
-			  <funcdef>float <function>ST_Angle</function></funcdef>
-			  <paramdef><type>geometry </type><parameter>point1</parameter></paramdef>
-			  <paramdef><type>geometry </type><parameter>point2</parameter></paramdef>
-			  <paramdef><type>geometry </type><parameter>point3</parameter></paramdef>
-			  <paramdef><type>geometry </type><parameter>point4</parameter></paramdef>
+			  <paramdef choice="opt"><type>geometry </type><parameter>point4=POINT(EMPTY)</parameter></paramdef>
 			</funcprototype>
 			<funcprototype>
Summary of changes:
 doc/reference_measure.xml | 8 +-------
 1 file changed, 1 insertion(+), 7 deletions(-)
hooks/post-receive
